I'm running Gemini PLasma. A few times when trying to accomplish something else, I saw a popup come up with options to share my monitor screen. I would close the popup... it was getting in the way. Today I plugged in my HDMI cable that goes to the TV. The TV is set to receive a signal. When I had linuxmint XFCE on this laptop, I used it frequently. But now that I'm ready... there's no popup. I don't know what the program was called, and I can't find it.
So how can I do this, with this OS?
In my laptop, I press F4 and the popup menu appears. You can also find this setting in System settings > Display & monitor
That didn't work for me. But just now doing another search I found the key combo to bring up the popup: the meta key +p
Or the Windows key +p.
This brings up the popup but only the close button works. None of the other configurations work. :-(
On XFCE I installed Lxrandr, a GUI front-end for Xrandr. They have some Debian Bulleye packages listed here:
https://packages.debian.org/bullseye/lxrandr
The page says it's a LXDE monitor configuration tool, but I'm hoping one of them will work for Plasma. If you think one of these packages could work, could you point me to the right one?
Or the Windows key +p.This brings up the popup but only the close button works. None of the other configurations work. :-(
You mean this popup, right?
It does work for me here. How are you trying to "share" the screen? This works if there's a second display connected either via HDMI or VGA, no via Wi-Fi a la chomecast, but wired. If you're trying to cast the screen via W-FI to a smart display, this won't work. You'll need gnome-network-displays To install, read here https://flathub.org/apps/details/org.gn … rkDisplays and here https://blog.paultelles.com/2020/03/how … plays.html
https://packages.debian.org/bullseye/lxrandrThe page says it's a LXDE monitor configuration tool, but I'm hoping one of them will work for Plasma. If you think one of these packages could work, could you point me to the right one?
No idea sorry, you might try them, and if they do work, good, if they don't, remove them.
Yes, that's the popup I was talking about. I have my smart TV plugged into the laptop by HDMI cable. This worked fine with Linuxmint XFCE but not Gemini. It's the same TV and same cable, and same laptop. I'll see what kind of luck I have with gnome-network-displays .
What graphics card is used in the laptop?
Please provide output from
inxi -G
Connect your smart TV with the HDMI cable, launch konsole and run this command
xrandr
output should be something like this
Screen 0: minimum 320 x 200, current 1366 x 768, maximum 8192 x 8192
LVDS connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
1366x768 59.99*+ 39.94
1280x720 59.97
1152x768 59.95
1024x768 59.95
800x600 59.96
848x480 59.94
720x480 59.94
640x480 59.94
HDMI-0 disconnected (normal left inverted right x axis y axis)
VGA-0 disconnected (normal left inverted right x axis y axis)
In your case, HDMI-0 should say "connected", mine's disconnected now.
Looks like the laptop doesn't see the TV.
LVDS connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
1366x768 60.04*+
1280x720 59.97
1152x768 59.95
1024x768 59.95
800x600 59.96
848x480 59.94
720x480 59.94
640x480 59.94
The cable is plugged in, and the TV is on. So how do I make the laptop see the TV?
Screen 0: minimum 320 x 200, current 1366 x 768, maximum 8192 x 8192 VGA-0 disconnected (normal left inverted right x axis y axis) LVDS connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 193mm 1366x768 60.04*+ 1280x720 59.97 1152x768 59.95 1024x768 59.95 800x600 59.96 848x480 59.94 720x480 59.94 640x480 59.94
Run these commands, 1 at a time:
xrandr
while the smart TV and the HDMI cable are disconnected, copy the output and save it to a file. Next, run
sudo udevadm monitor
and then plug and unplug the HDMI cable, copy the output and save it to a file. Lastly, run
cat /sys/class/drm/card0/*HDMI*/status
copy the output and save it to a file, then post the output from all commands.
With the HDMI cable unplugged and the TV turned off, this is the data I collected. The sudo udevadm monitor command had to be stopped manually.
stevem@steve-linux:~$ xrandr
1366x768 60.04*+
1280x720 59.97
1152x768 59.95
1024x768 59.95
800x600 59.96
848x480 59.94
720x480 59.94
640x480 59.94
stevem@steve-linux:~$ sudo udevadm monitor
monitor will print the received events for:
UDEV - the event which udev sends out after rule processing
KERNEL - the kernel uevent
KERNEL[642.553506] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[642.638243] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [642.645661] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [642.668938] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[695.097306] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[695.182731] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [695.190167] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [695.217900] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[747.641441] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[747.726464] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [747.733794] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [747.752646] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[798.169366] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[798.254147] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [798.261492] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [798.285812] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[850.713383] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[850.798257] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [850.805576] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [850.826129] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[903.257386] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[903.342161] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [903.349618] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [903.376140] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[932.634697] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
UDEV [932.638372] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
KERNEL[935.334578] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
UDEV [935.337562] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
KERNEL[953.785470] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[953.870321] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [953.877661] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [953.900521] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1006.329380] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1006.414902] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1006.421569] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1006.443950] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1058.873403] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1058.958886] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1058.966396] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1058.987508] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1109.401381] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1109.490157] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1109.497697] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1109.522596] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1151.213693] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
UDEV [1151.217243] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
KERNEL[1155.940671] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
UDEV [1155.946450] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
KERNEL[1161.945480] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1162.030892] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1162.038429] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1162.061170] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1214.489395] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1214.574860] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1214.582243] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1214.604317] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1265.017502] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1265.102312] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1265.109781] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1265.131958] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1317.561361] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1317.646936] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1317.654400] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1317.676306] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1370.105517] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1370.190933] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1370.197457] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1370.217887] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1385.381450] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
UDEV [1385.387078] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
KERNEL[1388.779643] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
UDEV [1388.783327] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
KERNEL[1420.633500] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1420.718683] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1420.726093] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1420.750517] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1473.177489] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1473.263067] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1473.270467] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1473.296266] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1525.721453] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1525.806318] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1525.813874] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1525.834264] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1576.249458] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1576.334101] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1576.341403] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1576.363437] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1613.002527] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
UDEV [1613.006120] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
KERNEL[1615.880178] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
UDEV [1615.883176] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
KERNEL[1628.793337] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1628.878991] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1628.886364] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1628.910337] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1681.337513] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1681.426242] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1681.433702] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1681.454062] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1731.865414] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1731.950947] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1731.958148] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1731.980111] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1767.088107] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
UDEV [1767.091716] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
KERNEL[1770.416488] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
UDEV [1770.422097] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
KERNEL[1784.409449] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1784.493838] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1784.501465] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1784.523662] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1836.953450] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1837.042909] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1837.050351] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1837.075152] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1887.481414] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1887.566296] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1887.573731] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1887.597731] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1940.025483] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1940.110961] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1940.118397] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1940.139243] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1977.884146] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
UDEV [1977.890290] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
KERNEL[1988.229453] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
UDEV [1988.235490] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
KERNEL[1992.569433] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[1992.654650] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1992.661422] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [1992.686286] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[2043.097459] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[2043.182894] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [2043.190158] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [2043.213277] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[2095.641425] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[2095.726947] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [2095.734293] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [2095.756218] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[2148.185452] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[2148.270999] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [2148.278348] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [2148.299530] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[2198.713476] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[2198.798873] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [2198.806328] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [2198.830625] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
Above command wouldn't stop even after waiting for 15 minutes. I closed the window to stop it.
stevem@steve-linux:~$ cat /sys/class/drm/card0/*HDMI*/status
cat: '/sys/class/drm/card0/*HDMI*/status': No such file or directory
With the HDMI cable plugged in and the TV turned on, this is the data I collected. The sudo udevadm monitor command had to be stopped manually.
1366x768 60.04*+
1280x720 59.97
1152x768 59.95
1024x768 59.95
800x600 59.96
848x480 59.94
720x480 59.94
640x480 59.94
[sudo] password for stevem:
KERNEL[4482.809520] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[4482.894926] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [4482.902453] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [4482.925187] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[4533.337464] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[4533.458208] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [4533.465622] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [4533.491410] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[4585.913360] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[4585.998121] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [4586.005567] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [4586.029062] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[4610.272222] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
UDEV [4610.277440] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
KERNEL[4613.368809] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
UDEV [4613.372004] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
KERNEL[4638.457505] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[4638.541869] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [4638.549326] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [4638.573351] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[4688.985573] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[4689.107106] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [4689.114562] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [4689.136383] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[4741.561461] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[4741.646264] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [4741.653880] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [4741.680807] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[4764.614125] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
UDEV [4764.617659] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
KERNEL[4794.105404] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[4794.190203] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [4794.197615] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [4794.218065] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[4839.639283] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
UDEV [4839.642773] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
KERNEL[4844.633442] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[4844.754180] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [4844.761613] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [4844.783528] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[4897.209389] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[4897.294256] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [4897.301402] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [4897.322220] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[4902.669706] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
UDEV [4902.675462] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
KERNEL[4949.753420] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[4949.838984] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [4949.846373] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [4949.869494] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[5000.281466] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[5000.402268] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [5000.409673] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [5000.431203] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[5052.857472] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[5052.943937] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [5052.951140] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [5052.978408] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[5053.426333] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
UDEV [5053.427745] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
KERNEL[5066.556331] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
UDEV [5066.559423] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight)
KERNEL[5105.401420] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[5105.486386] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [5105.493924] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [5105.515064] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[5155.929380] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
KERNEL[5156.051160] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [5156.058434] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
UDEV [5156.080458] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block)
This command would't stop running and had to be shut down
stevem@steve-linux:~$ xrandr Screen 0: minimum 320 x 200, current 1366 x 768, maximum 8192 x 8192 VGA-0 disconnected (normal left inverted right x axis y axis) LVDS connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 193mm 1366x768 60.04*+ 1280x720 59.97 1152x768 59.95 1024x768 59.95 800x600 59.96 848x480 59.94 720x480 59.94 640x480 59.94 stevem@steve-linux:~$ sudo udevadm monitor [sudo] password for stevem: monitor will print the received events for: UDEV - the event which udev sends out after rule processing KERNEL - the kernel uevent KERNEL[4482.809520] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[4482.894926] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [4482.902453] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [4482.925187] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[4533.337464] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[4533.458208] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [4533.465622] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [4533.491410] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[4585.913360] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[4585.998121] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [4586.005567] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [4586.029062] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[4610.272222] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight) UDEV [4610.277440] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight) KERNEL[4613.368809] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight) UDEV [4613.372004] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight) KERNEL[4638.457505] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[4638.541869] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [4638.549326] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [4638.573351] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[4688.985573] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[4689.107106] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [4689.114562] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [4689.136383] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[4741.561461] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[4741.646264] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [4741.653880] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [4741.680807] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[4764.614125] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight) UDEV [4764.617659] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight) KERNEL[4794.105404] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[4794.190203] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [4794.197615] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [4794.218065] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[4839.639283] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight) UDEV [4839.642773] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight) KERNEL[4844.633442] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[4844.754180] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [4844.761613] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [4844.783528] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[4897.209389] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[4897.294256] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [4897.301402] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [4897.322220] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[4902.669706] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight) UDEV [4902.675462] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight) KERNEL[4949.753420] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[4949.838984] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [4949.846373] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [4949.869494] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[5000.281466] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[5000.402268] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [5000.409673] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [5000.431203] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[5052.857472] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[5052.943937] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [5052.951140] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [5052.978408] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[5053.426333] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight) UDEV [5053.427745] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight) KERNEL[5066.556331] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight) UDEV [5066.559423] change /devices/pci0000:00/0000:00:02.0/0000:02:00.0/backlight/acpi_video1 (backlight) KERNEL[5105.401420] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[5105.486386] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [5105.493924] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [5105.515064] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[5155.929380] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) KERNEL[5156.051160] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [5156.058434] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) UDEV [5156.080458] change /devices/pci0000:00/0000:00:16.2/usb3/3-2/3-2:1.0/host4/target4:0:0/4:0:0:0/block/sdb (block) This command would't stop running and had to be shut down stevem@steve-linux:~$ cat /sys/class/drm/card0/*HDMI*/status cat: '/sys/class/drm/card0/*HDMI*/status': No such file or directory stevem@steve-linux:~$
Yes, udev monitor had to be stopped manually with Ctrl + c Launch konsole and run this, please
grep . /sys/class/drm/*/status
and
ls /sys/class/drm
and post the output from both commands here.
stevem@steve-linux:~$ grep . /sys/class/drm/*/status
/sys/class/drm/card0-LVDS-1/status:connected
/sys/class/drm/card0-VGA-1/status:disconnected
/sys/class/drm/card1-HDMI-A-1/status:disconnected
/sys/class/drm/card1-LVDS-2/status:disconnected
/sys/class/drm/card1-VGA-2/status:disconnected
and
stevem@steve-linux:~$ ls /sys/class/drm
card0 card0-VGA-1 card1-HDMI-A-1 card1-VGA-2 renderD129 version
card0-LVDS-1 card1 card1-LVDS-2 renderD128 ttm
stevem@steve-linux:~$ grep . /sys/class/drm/*/status /sys/class/drm/card0-LVDS-1/status:connected /sys/class/drm/card0-VGA-1/status:disconnected /sys/class/drm/card1-HDMI-A-1/status:disconnected /sys/class/drm/card1-LVDS-2/status:disconnected /sys/class/drm/card1-VGA-2/status:disconnected
and
stevem@steve-linux:~$ ls /sys/class/drm card0 card0-VGA-1 card1-HDMI-A-1 card1-VGA-2 renderD129 version card0-LVDS-1 card1 card1-LVDS-2 renderD128 ttm
Connect the HDMI cable and run
cat /sys/class/drm/card1/*HDMI*/status
again, then post the output.
stevem@steve-linux:~$ cat /sys/class/drm/card1/*HDMI*/status
disconnected
There's only the one HDMI port on this old laptop. The other end is still plugged into HDMI 1 (ARC) -- just as it was when I was using XFCE on the laptop.
stevem@steve-linux:~$ cat /sys/class/drm/card1/*HDMI*/status disconnected
xrandr --listproviders
and post the output here, please. Also, it'd be helpful if you could share the output of this too
inxi -SMCGFx
I don't think the desktop has anything to do with this, but something else.
stevem@steve-linux:~$ xrandr --listproviders
Providers: number : 2
Provider 0: id: 0x53 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 2 outputs: 2 associated providers: 0 name:ATI Mobility Radeon HD 4200 @ pci:0000:01:05.0
Provider 1: id: 0x82 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 4 outputs: 3 associated providers: 0 name:ATI Mobility Radeon HD 5000 Series @ pci:0000:02:00.0
and
stevem@steve-linux:~$ inxi -SMCGFx
System:
Host: steve-linux Kernel: 5.10.0-9-amd64 x86_64 bits: 64 compiler: gcc
v: 10.2.1 Desktop: KDE Plasma 5.20.5 Distro: Q4OS 4.6.1-n1
base: Debian GNU/Linux 11 (bullseye)
Machine:
Type: Laptop System: Hewlett-Packard product: HP Pavilion dv6 Notebook PC
v: 058B110000242B10000020100 serial: <superuser required>
Mobo: Hewlett-Packard model: 1441 v: 67.33 serial: <superuser required>
BIOS: Hewlett-Packard v: F.28 date: 04/11/2011
Battery:
ID-1: BAT0 charge: 49.4 Wh condition: 49.4/49.4 Wh (100%)
model: Hewlett-Packard Primary status: Full
CPU:
Info: Triple Core model: AMD Phenom II P840 bits: 64 type: MCP arch: K10
rev: 3 L2 cache: 1.5 MiB
flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 11371
Speed: 800 MHz min/max: 800/1900 MHz Core speeds (MHz): 1: 800 2: 800
3: 800
Graphics:
Device-1: AMD RS880M [Mobility Radeon HD 4225/4250] vendor: Hewlett-Packard
driver: radeon v: kernel bus ID: 01:05.0
Device-2: AMD Park [Mobility Radeon HD 5430/5450/5470]
vendor: Hewlett-Packard driver: radeon v: kernel bus ID: 02:00.0
Device-3: Realtek 2SF022 type: USB driver: uvcvideo bus ID: 1-3:2
Display: x11 server: X.Org 1.20.11 driver: loaded: ati,radeon
unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
OpenGL: renderer: AMD RS880 (DRM 2.50.0 / 5.10.0-9-amd64 LLVM 11.0.1)
v: 3.3 Mesa 20.3.5 direct render: Yes
Audio:
Device-1: AMD SBx00 Azalia vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus ID: 00:14.2
Device-2: AMD Cedar HDMI Audio [Radeon HD 5400/6300/7300 Series]
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 02:00.1
Sound Server: ALSA v: k5.10.0-9-amd64
Network:
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter
vendor: Hewlett-Packard U98Z062.12 802.11bgn driver: ath9k v: kernel
port: 3000 bus ID: 03:00.0
IF: wlo2 state: up mac: 4c:0f:6e:34:83:f4
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel port: 2000 bus ID: 04:00.0
IF: enp4s0 state: down mac: 60:eb:69:58:9b:cd
Drives:
Local Storage: total: 465.76 GiB used: 18.44 GiB (4.0%)
ID-1: /dev/sda vendor: Seagate model: ST9500420AS size: 465.76 GiB
Partition:
ID-1: / size: 449.61 GiB used: 18.44 GiB (4.1%) fs: ext4 dev: /dev/sda1
Swap:
ID-1: swap-1 type: partition size: 7.89 GiB used: 0 KiB (0.0%)
dev: /dev/sda2
Sensors:
System Temperatures: cpu: 61.5 C mobo: N/A gpu: radeon temp: 53.0 C
Fan Speeds (RPM): N/A
Info:
Processes: 180 Uptime: 6m Memory: 3.59 GiB used: 1.5 GiB (41.8%)
Init: systemd runlevel: 5 Compilers: gcc: 10.2.1 Packages: 2381 Shell: Bash
v: 5.1.4 inxi: 3.3.01
Ok. Let's try this: connect the TV via the HDMI cable, launch konsole and run this
xrandr --output HDMI-A-1 --auto
looks like xrandr isn't picking the HDMI display up, but the LVDS only, hopefully, this will try and do that.
stevem@steve-linux:~$ xrandr --output HDMI-A-1 --auto
warning: output HDMI-A-1 not found; ignoring
stevem@steve-linux:~$ xrandr --output HDMI-A-1 --auto warning: output HDMI-A-1 not found; ignoring
Ok. Try this: launch konsole and run
xrandr --auto
As far as I can tell, I don't think this did anything.
stevem@steve-linux:~$ xrandr --auto
We will perform some testing with the secondary display port and possibly report here, if we find something related.
stevem@steve-linux:~$ xrandr --auto stevem@steve-linux:~$
Ok. At this point, I suggest you try and check whether the cable/port is working fine, you could download a different distro's iso file, or even use Q4OS', write the .iso to a USB, and boot the live OS, then try connecting your smart TV, and if it works, then something's wrong with Debian's/Q4OS' settings in Plasma, and if it doesn't, then you should probably try/get a new HDMI cable, if after confirming that a new cable didn't make any difference, then something might be wrong with the HDMI port. In short, discarding possible reasons(hardware or software related)that explain why it is not working.
I think I replaced XFCE with Plasma four days ago. The HDMI was working fine. The connection is tight on the TV, and there is only one HDMI cable port on this laptop. I have Linuxmint on a live USB -- I can give that a try.
Edit a little later:
I plugged in the Linuxmint live USB. It only took about 5 seconds and I had the laptop screen displaying on the TV. It must be Plasma that has a problem.
You mean you installed XFCE in Q4OS? Or was it another distro? The xrandr command runs at a system level, it doesn't have to do anything with Plasma specifically. I think something might be wrong with Debian's/Q4OS' settings in Plasma, some missing configuration file ... I don't know. It works just fine for me, tho.
The laptop had Linuxmint XFCE on it. This is what I was using a few days ago. Then I replaced it with Q4IS Gemini, and it no longer works. To test it today, I used a Linux mint, live USB, to login to the laptop with Gemini on it. Linux mint live USB had no problem with sharing the screen to the TV. That's why I think it must be Debian's/Q4OS that's the problem
