#1 2021-10-23 09:25
globetrotterdk
(Solved) Grub refuses to detect Windows bootloader - Q4OS Gemini.
Grub refuses to detect the Windows boot loader in connection with my Q4OS Gemini install.  I have tried running
# grub-mkconfig -o /boot/grub/grub.cfg
# update-grub
but that doesn't seem to help. Any ideas?
I’ve had a perfectly wonderful evening, but this wasn’t it. - Groucho Marx
#2 2021-10-23 10:09
Re: (Solved) Grub refuses to detect Windows bootloader - Q4OS Gemini.
Please run:
$ sudo os-prober
and post the output here.
#3 2021-10-23 15:19
globetrotterdk
Thanks for the quick reply.
$ sudo os-prober
/dev/nvme0n1p2@/efi/Microsoft/Boot/bootmgfw.efi:Windows Boot Manager:Windows:efi
#4 2021-10-23 16:38
Well, now run:
$ sudo update-grub -o /tmp/grub-test.cfg
post output and attach the generated file "/tmp/grub-test.cfg" here.
#5 2021-10-23 18:48
globetrotterdk
OK, here is the file.
#6 2021-10-23 22:53
The correct Windows menu item appears to be available in grub.cfg. Is the Grub boot table displayed ? What does the early boot process print on the screen ?
Please edit the "/etc/default/grub", search and set the following variables:
GRUB_TIMEOUT_STYLE=menu
GRUB_TIMEOUT=10
Furthermore run in terminal:
$ sudo update-grub
Reboot and check the result.
#7 2021-10-24 07:58
globetrotterdk
Not sure what a Grub boot table is. Do you mean Grub boot menu? If so, the answer is, yes.
I get the following errors:
error: no such device: 8A70-33E6
error: `/efi/Microsoft/Boot/bootmgfw.efi` not found
I edited "/etc/default/grub" as recommended, but no change in the results.
#8 2021-10-27 17:50
globetrotterdk
After having backed up the M.2 SSD and then migrated the backup to a new, larger M.2 SSD, as well as updating Windows 10, and running:
$ sudo grub-mkconfig -o /boot/grub/grub.cfg
$ sudo update-grub
again, Grub menu seems to be working fine now.
#9 2021-10-27 17:52
globetrotterdk
Windows 10 appears to be working fine on the new M.2 SSD. My problem with the Grub menu also appears to have disappeared after updating Windows 10.
