#1 2021-10-19 19:43
carbon_dragon
The Q4OS Development pack install
I've recently installed this "application." It went fine. It looks like it installed gcc (and probably other stuff). Is there an orientation file I could read to see what was installed? Furthermore, is there a tutorial for how to use the tools to write and compile simple programs (I'm guessing in C, though I guess C++ is also possible?)?
Every UNIX I've ever used in the past used a different set of windowing libraries to do things like put up windows, add menus, and so on. It would be useful to know what to look for and what to research. Thanks.
#2 2021-10-20 09:12
Re: The Q4OS Development pack install
Does this link help?
#3 2021-10-20 10:33
@carbon_dragon
What way did you install the devpack ? Did you install Plasma or Trinity devpack version ?
In general, Q4OS devpack is QT5 or TQt oriented, so you need to read up on using KDevelop or QTCreator or TDevelop applications.
#4 2021-10-20 13:06
carbon_dragon
That link looks helpful, thanks. I'm pretty sure I installed the trinity version since that is what I have. I did it through the install applications ability. Plus I have a very weak machine so I'm not envisioning it as a development machine really. I just want to see what is available and do something simple.
