#1 2021-10-06 16:15
Shyguy
Can't open some applications under Gemini
Under Centaurus I used freeoffice2018 without any issue on my Asus EeePC. After a fresh install of Gemini and freeoffice the application won't open. A blank window titled "freeoffice" appears and spontaneously closes after half a second. Also vivaldi - installed from the repo indicated by qrepoadd --gui - refuses to open. Any idea?
#2 2021-10-06 19:34
Re: Can't open some applications under Gemini
Vivaldi for Debian opens fine here, you could try to use the dedicated installer, download it here https://github.com/q4os-installers/viva … a2_all.esh
Freeoffice was never directly supported in Q4OS, however you can try to install it according to Debian installation instructions. If it works under Debian, it will work in Q4OS as well. You can also try to run it from terminal and check the messages printed.
#3 2021-10-07 22:32
Shyguy
Thanks for your advice but both vivaldi and freeoffice still failed to open. The vivaldi installer indicated that the programme was successfully installed, there was no error notification.
During the installation of freeoffice a warning "Missing charsets in String to FontSet conversion" appeared several times. But I'm not sure if this explains the failure. I can't exclude that the same warning showed up when I installed freeoffice under Centaurus. I just don't remember.
#4 2021-10-07 22:53
Please run both Vivaldi and Freeoffice binaries in terminal and post the output here.
#5 2021-10-08 22:58
Shyguy
After installing Vivaldi via the .esh link and launching it in terminal I get
...@q4os-desktop:~$ vivaldi-stable
The Widevine CDM is not installed. Attempting to fix this for the next restart.
(vivaldi-stable:3683): Gtk-WARNING **: 23:50:16.614: Theme parsing error: gtk-widgets.css:153:27: The style property GtkButton:image-spacing is deprecated and shouldn't be used anymore. It will be removed in a future version
(vivaldi-stable:3683): Gtk-WARNING **: 23:50:16.615: Theme parsing error: gtk-widgets.css:154:26: The style property GtkButton:inner-border is deprecated and shouldn't be used anymore. It will be removed in a future version
(vivaldi-stable:3683): Gtk-WARNING **: 23:50:16.623: Theme parsing error: gtk-widgets.css:578:27: The style property GtkButton:image-spacing is deprecated and shouldn't be used anymore. It will be removed in a future version
(vivaldi-stable:3683): Gtk-WARNING **: 23:50:16.624: Theme parsing error: gtk-widgets.css:579:28: The style property GtkWidget:interior-focus is deprecated and shouldn't be used anymore. It will be removed in a future version
(vivaldi-stable:3683): Gtk-WARNING **: 23:50:16.625: Theme parsing error: gtk-widgets.css:580:28: The style property GtkButton:default-border is deprecated and shouldn't be used anymore. It will be removed in a future version
(vivaldi-stable:3683): Gtk-WARNING **: 23:50:16.627: Theme parsing error: gtk-widgets.css:581:26: The style property GtkButton:inner-border is deprecated and shouldn't be used anymore. It will be removed in a future version
(vivaldi-stable:3683): Gtk-WARNING **: 23:50:16.643: Theme parsing error: gtk-widgets.css:1357:25: The style property GtkRange:slider-width is deprecated and shouldn't be used anymore. It will be removed in a future version
(vivaldi-stable:3683): Gtk-WARNING **: 23:50:16.644: Theme parsing error: gtk-widgets.css:1358:25: The style property GtkRange:stepper-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(vivaldi-stable:3683): Gtk-WARNING **: 23:50:16.644: Theme parsing error: gtk-widgets.css:1359:34: The style property GtkScrollbar:min-slider-length is deprecated and shouldn't be used anymore. It will be removed in a future version
(vivaldi-stable:3683): Gtk-WARNING **: 23:50:16.644: Theme parsing error: gtk-widgets.css:1360:28: The style property GtkRange:stepper-spacing is deprecated and shouldn't be used anymore. It will be removed in a future version
(vivaldi-stable:3683): Gtk-WARNING **: 23:50:16.645: Theme parsing error: gtk-widgets.css:1361:34: The style property GtkRange:trough-under-steppers is deprecated and shouldn't be used anymore. It will be removed in a future version
../../chromium/sandbox/linux/seccomp-bpf-helpers/sigsys_handlers.cc:**CRASHING**:seccomp-bpf failure in syscall 0403
[3735:3735:1008/235026.038731:ERROR:angle_platform_impl.cc(43)] Display.cpp:832 (initialize): ANGLE Display::initialize error 12289: OpenGL ES 2.0 is not supportable.
[3735:3735:1008/235026.039392:ERROR:gl_surface_egl.cc(774)] EGL Driver message (Critical) eglInitialize: OpenGL ES 2.0 is not supportable.
[3735:3735:1008/235026.040166:ERROR:gl_surface_egl.cc(1329)] eglInitialize OpenGL failed with error EGL_NOT_INITIALIZED, trying next display type
[3735:3735:1008/235026.117089:ERROR:angle_platform_impl.cc(43)] Display.cpp:832 (initialize): ANGLE Display::initialize error 12289: Intel or NVIDIA OpenGL ES drivers are not supported.
[3735:3735:1008/235026.117570:ERROR:gl_surface_egl.cc(774)] EGL Driver message (Critical) eglInitialize: Intel or NVIDIA OpenGL ES drivers are not supported.
[3735:3735:1008/235026.118074:ERROR:gl_surface_egl.cc(1329)] eglInitialize OpenGLES failed with error EGL_NOT_INITIALIZED
[3735:3735:1008/235026.118487:ERROR:gl_initializer_linux_x11.cc(182)] GLSurfaceEGL::InitializeOneOff failed.
[3735:3735:1008/235026.396242:ERROR:viz_main_impl.cc(150)] Exiting GPU process due to errors during initialization
libva error: /usr/lib/i386-linux-gnu/dri/iHD_drv_video.so init failed
libva error: /usr/lib/i386-linux-gnu/dri/i965_drv_video.so init failed
[3683:3766:1008/235028.852473:ERROR:object_proxy.cc(621)] Failed to call method: org.freedesktop.DBus.Properties.Get: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
[3683:3766:1008/235028.868401:ERROR:object_proxy.cc(621)] Failed to call method: org.freedesktop.UPower.GetDisplayDevice: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
[3683:3766:1008/235028.878922:ERROR:object_proxy.cc(621)] Failed to call method: org.freedesktop.UPower.EnumerateDevices: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
[3683:3683:1008/235029.053037:ERROR:vivaldi_ui_web_contents_delegate.cc(42)] UI Process abnormally terminates with status 3 after running for 2.33033 seconds!
[3683:3683:1008/235029.087251:ERROR:vivaldi_ui_web_contents_delegate.cc(73)] Quiting Vivaldi
[3683:3713:1008/235029.405205:ERROR:browser_gpu_channel_host_factory.cc(154)] Failed to launch GPU process.
#6 2021-10-08 23:29
Shyguy
and if I install Freeoffice via
sudo apt install -f ./softmaker-freeoffice-2018_982-01_i386.deb
and launch the word processor I get
...@q4os-desktop:~$ textmaker18free %F
Segmentation fault
