Hi, Forum.
I've installt Q4OS-Centaurus-Trinity-32bit in VirtualBox.
Runs fine sofare.
But boot takes extreamly long time, because there are two startjobs witch delays for 90 sec.
(1 of 2 ) startjob is runnning for Wait Until Kernel Time Synchronized (12/1min 30s )
(2 of 2 ) startjob is runnning for /sys/subsystem/net/dev/devices/multi/user (26/1min 30s)
Inxi Fzxxx
System:
Host: q4os-desktop Kernel: 4.19.0-17-686-pae i686 bits: 32 compiler: gcc
v: 8.3.0 Desktop: Trinity R14.0.6 tk: Qt 3.5.0 info: kicker wm: Twin 3.0
dm: TDM Distro: Q4OS 3.15.2-n1 base: Debian GNU/Linux 10 (buster)
Machine:
Type: Virtualbox System: innotek product: VirtualBox v: 1.2
serial: <filter> Chassis: Oracle Corporation type: 1 serial: <filter>
Mobo: Oracle model: VirtualBox v: 1.2 serial: <filter> BIOS: innotek
v: VirtualBox date: 12/01/2006
CPU:
Topology: Single Core model: Intel Core i5-3470S bits: 32 type: MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 19
L2 cache: 6144 KiB
flags: nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 5786
Speed: 2893 MHz min/max: N/A Core speed (MHz): 1: 2893
Vulnerabilities: Type: itlb_multihit status: KVM: Vulnerable
Type: l1tf mitigation: PTE Inversion
Type: mds mitigation: Clear CPU buffers; SMT Host state unknown
Type: meltdown mitigation: PTI
Type: spec_store_bypass status: Vulnerable
Type: spectre_v1
mitigation: usercopy/swapgs barriers and __user pointer sanitization
Type: spectre_v2
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Type: srbds status: Unknown: Dependent on hypervisor status
Type: tsx_async_abort status: Not affected
Graphics:
Device-1: InnoTek Systemberatung VirtualBox Graphics Adapter
driver: vboxvideo v: 5.2.36 r135684 bus ID: 00:02.0 chip ID: 80ee:beef
Display: x11 server: X.Org 1.20.4 driver: modesetting unloaded: fbdev,vesa
alternate: vboxvideo resolution: 1280x693~60Hz
OpenGL: renderer: llvmpipe (LLVM 7.0 256 bits) v: 3.3 Mesa 18.3.6
compat-v: 3.1 direct render: Yes
Audio:
Device-1: Intel 82801AA AC97 Audio vendor: Dell driver: snd_intel8x0
v: kernel bus ID: 00:05.0 chip ID: 8086:2415
Sound Server: ALSA v: k4.19.0-17-686-pae
Network:
Device-1: Intel 82540EM Gigabit Ethernet driver: e1000 v: 7.3.21-k8-NAPI
port: d010 bus ID: 00:03.0 chip ID: 8086:100e
IF: enp0s3 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel 82371AB/EB/MB PIIX4 ACPI type: network bridge driver: N/A
port: d200 bus ID: 00:07.0 chip ID: 8086:7113
Drives:
Local Storage: total: 20.06 GiB used: 8.37 GiB (41.7%)
ID-1: /dev/sda vendor: VirtualBox model: VBOX HARDDISK size: 20.06 GiB
block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
serial: <filter> rev: 1.0 scheme: MBR
Partition:
ID-1: / raw size: 18.91 GiB size: 18.48 GiB (97.77%)
used: 8.37 GiB (45.3%) fs: ext4 block size: 4096 B dev: /dev/sda1
ID-2: swap-1 size: 1.12 GiB used: 0 KiB (0.0%) fs: swap
swappiness: 60 (default) cache pressure: 100 (default) dev: /dev/sda2
Sensors:
Message: No sensors data was found. Is sensors configured?
Repos:
No active apt repos in: /etc/apt/sources.list
Active apt repos in: /etc/apt/sources.list.d/10_q4os.list
1: deb http://q4os.org/q4repo/ q4os-3-0-cn main
Active apt repos in: /etc/apt/sources.list.d/12_qtde.list
1: deb http://q4os.org/qtderepo/ buster main
Active apt repos in: /etc/apt/sources.list.d/20_debian.list
1: deb http://ftp.debian.org/debian/ buster non-free contrib main
2: deb http://security.debian.org/debian-security/ buster/updates main contrib non-free
3: deb http://ftp.debian.org/debian/ buster-updates non-free contrib main
No active apt repos in: /etc/apt/sources.list.d/30_debian_backports.list
Active apt repos in: /etc/apt/sources.list.d/dvpck_q4os-libreoffice.list
1: deb http://q4os.org/qextrepo/ buster-libreoffice-cn main
No active apt repos in: /etc/apt/sources.list.d/linuxthebest_net-ubuntu-remastersys-impish.list
No active apt repos in: /etc/apt/sources.list.d/nemh-ubuntu-systemback-impish.list
Info:
Processes: 157 Uptime: 1h 01m Memory: 1.48 GiB used: 416.6 MiB (27.4%)
Init: systemd v: 241 target: graphical.target Compilers: gcc: 8.3.0 alt: 8
Shell: bash v: 5.0.3 running in: konsole inxi: 3.0.32
For that problem i ask allready in MX-Forum, because i cold use German there.
xxxxxxxxhttps://forum.mxlinux.org/viewtopic.php?f=136&t=65992xxxxxxxx
But no solution.
If you follow the link you can see what i tryed o get over this.
And intresting, on the last Page at Post #21 another user writes, hat she's got the tsame problem.
Is ist a known problem ?
Is there a workaround to fix it ?
Really ?
No one got any idea to solve this problem ?
Hi, Forum.
Really ?
Really? You didn't even mention what the host OS is, is it Windows? Linux? macOS? Other? In any case, you should ask in the VirtualBox forum https://forums.virtualbox.org/
