#1 2021-09-19 14:07
gefin
Installed 3.15 but it will not first boot
I downloaded 3.15 (did a donation too )  Had to install using fail safe, it installed ok but  the first boot stalled after login ( adminq ) and will not continue.   ??
#2 2021-09-19 16:26
Re: Installed 3.15 but it will not first boot
That doesn't sound right unless you set your user account as adminq.
You'll need to give us a bit more to go on - Plasma or Trinity?
It may be you had a bad download or bad burn
I'd start again with the live version and run inxi -F then copy the results back here as that may prove useful.
The fact you had to install using failsafe is a little worrying but hopefully getting the spec of your machine will help.
#3 2021-09-19 18:47
gefin
solved it by downloading and installing KDE version instead of TDE  works great now
