#1 2021-09-07 01:05
theMezz
How to totally remove qBittorrent
I tried to remove qBittorrent and also remove all related config and settings.
I tried this: https://installlion.com/ubuntu/vivid/un … index.html
and I tried the remove functiomn on DISCOVER
Neither one removes all the related config and settings.
I know this because when I reinstall qBitorrent - I see all the settings the same as before.
My intent is to try to install qBittorrent with factory default settings.
Suggestions?
#2 2021-09-07 04:29
Re: How to totally remove qBittorrent
apt purge qbitorrent will completely erase the program and all GLOBAL configurations.
To delete your personal settings, you'll need to delete the configs in your /home directory.  Probably either ~/.config/qbittorrent or ~/.qbittorrent
