#1 2021-08-24 03:15
diyako
Request Oracle Virtualbox Install Script
I was wondering if it would be possible to provide an install script similar to the ones in the Q4OS Software Centre in order to be able to install Oracle Virtualbox. The option to install the guest additions is already available, being able to install the actual virtualbox itself I think it would make sense.
Thank you.
#2 2021-08-24 08:28
Re: Request Oracle Virtualbox Install Script
Yes, it's possible. We will take a look and post back on updates.
#3 2021-08-27 22:16
diyako
That sounds awesome! Thank you for considering it.
#4 2021-08-31 12:16
You can now download Virtualbox 6.1.22 installer https://sourceforge.net/projects/q4os/f … ntal_apps/ . It's available for Q4OS 4 Gemini only, if you want install Virtualbox for Q4OS 3 Centaurus, use the "qrepoadd" command, see https://www.q4os.org/dqa007.html#extrepo
