#1 2021-08-10 02:36
Q4OS 4 TDE Software Center installation of ProtonVPN
Does not have libglib2.0-bin marked as a dependency, it is required to launch the GUI for ProtonVPN.
Library is not pre-installed if you choose the "pure" profile upon OS installation.
#2 2021-08-11 09:54
Re: Q4OS 4 TDE Software Center installation of ProtonVPN
Thanks, we will check and fix the installer.
#3 2021-08-22 14:52
Fixed in the 3.2 installer version.
