#1 2015-12-11 18:42
timerider
Updater-issue
Hello Peoples,
when running the updater, I get an error-message saying this:
  firmware-linux-nonfree: Hängt ab von: firmware-misc-nonfree (= 20151018-2~bpo8+1) but it is not going to be installed
                          Empfiehlt: intel-microcode but it is not going to be installed
                          Empfiehlt: amd64-microcode but it is not going to be installed
Is this severe?
Thanks in advance!
#2 2015-12-12 09:34
timerider
Re: Updater-issue
Thank you for the quick answer.
But if theres an update of some other programs necessary one day, what should I do then?
Is it better to update through Synaptic Package Manager?
#3 2015-12-13 13:05
Re: Updater-issue
Run in terminal:
$ sudo apt-get update
and try to launch updater again. Does issue persist ?
