#1 2021-07-15 23:05
mayybe
Problem with nvidia driver
So today i wanted to install graphics card driver and when i went to nvidia x server settings i got this: "You dont appear to be using the NVIDIA X driver. Please edit your X configuration file (just run 'nvidia-xconfig' as root) and restart the X server.".
My graphics card: gt 520mx
#2 2021-07-16 00:02
Re: Problem with nvidia driver
Do as the message says: Launch the terminal(konsole)and type
sudo nvidia-xconfig
press Enter, type in your password when asked, hit Enter again, wait for the process to be finished, and reboot.
#3 2021-07-16 11:13
mayybe
i typed this and i got this:
WARNING: Unable to locate/open X configuration file.
New X configuration file written to '/etc/X11/xorg.conf'
after reboot im stuck in tty1
ctrl + alt + f7 is not working
#4 2021-07-16 13:05
Can you log in to your account in tty1? If you can, type in
startx
to see if you can get to the desktop. If the desktop doesn't start, you will need to check X.org logs. FWIW, Nvidia has historically been a pain to use in Linux. I remember having a similar issue some years ago with an integrated nvidia GPU, and if I recall correctly, I had to delete the  "New X configuration file written to '/etc/X11/xorg.conf" to get a working desktop. I bought an AMD GPU, that worked beautifully from day 1. smile
#5 2021-07-16 13:11
mayybe
after startx i got this:
xf86EnableIOPorts: failed to set IOPL for I/O (operation not permitted)\
fatal server error: (EE) no screens found (EE) Please consult the X.org Foundation support
xinit: giving up
xinit: unable to connect to x server: Connection refused
xinit: server error
#6 2021-07-16 13:28
xinit: giving up
xinit: server error
OK. Try this:
1. Log in to you account in tty1.
2. Run
sudo cp  /etc/X11/xorg.conf /etc/X11/xorg.conf.bak
this will create a backup of the file.
3. Delete the file with
sudo rm /etc/X11/xorg.conf
4. Reboot.
If on reboot you're still getting no desktop, log in in TTY1, and run
startx
again.
EDIT: Forgot to ask, but, which Q4OS version are you using? Centaurus(Debian Buster) or Gemini(Debian Bullseye)?
#7 2021-07-16 13:35
mayybe
Thank you, i got my desktop back but shame that nvidia x server settings is still not working.
#8 2021-07-16 13:37
Good. Forgot to ask, but, which Q4OS version are you using? Centaurus(Debian Buster) or Gemini(Debian Bullseye)? By the way, a search on the web indicates that this particular Nvidia card is particularly problematic to make it work under Linux. Some solutions suggest installing bumblebee drivers. https://wiki.debian.org/Bumblebee
https://www.nvidia.com/en-us/geforce/fo … 20m-linux/
https://forums.linuxmint.com/viewtopic.php?t=308603
https://www.reddit.com/r/linux/comments … r_to_work/
#9 2021-07-16 13:41
mayybe
Centaurus with debian buster
#10 2021-07-16 13:44
Ok. Then you may try installing bumblebee following instructions from Debian wiki for Buster. https://wiki.debian.org/Bumblebee
#11 2021-07-16 13:49
mayybe
I need to ask
why my sources.list file is empty?
#12 2021-07-16 14:01
mayybe wrote:
I need to ask
Q4OS doesn't use the sources.list, instead, all the repositories are in /etc/sources.list.d directory. You'll find a few "sources.list" files there:
10_q4os.list
12_qtde.list
20_debian.list
30_debian_backports.list
Are you in "make sure the contrib and non-free components are enabled in your SourcesList file" as stated in that bumblebee wiki?
The file  20_debian.list is where you need to look, here I got this:
# Q4OS essential repository
# **** !!! NEVER touch this CRITICAL system file **** !!!
deb http://deb.debian.org/debian/ bullseye main contrib non-free
#deb-src http://deb.debian.org/debian/ testing main contrib non-free
deb http://deb.debian.org/debian/ bullseye-updates main contrib non-free
#deb-src http://deb.debian.org/debian/ testing-updates main contrib non-free
deb http://deb.debian.org/debian-security bullseye-security main
#deb-src http://deb.debian.org/debian-security testing-security main
##deb http://ftp.debian.org/debian/ buster-proposed-updates main contrib non-free
##deb-src http://ftp.debian.org/debian/ buster-proposed-updates main contrib non-free
# mirror chooser service - experimental
##deb http://deb.debian.org/debian/ buster main contrib non-free
##deb-src http://deb.debian.org/debian/ buster main contrib non-free
As you can see, both contrib and non-free are enabled. Check on you're side, and if they're not(but I think they should be), then enable them - delete the "#" symbol.
#13 2021-07-16 14:15
mayybe
here is 20_debian.list
is here everything ok?
deb http://ftp.debian.org/debian/ buster main contrib non-free
##deb-src http://ftp.debian.org/debian/ buster main contrib non-free
deb http://security.debian.org/debian-security/ buster/updates main contrib non-free
##deb-src http://security.debian.org/debian-security/ buster/updates main contrib non-free
# buster-updates, previously known as 'volatile'
deb http://ftp.debian.org/debian/ buster-updates main contrib non-free
##deb-src http://ftp.debian.org/debian/ buster-updates main contrib non-free
#14 2021-07-16 15:11
Yes, everything looks fine. By the way, I would recommend installing timeshift
sudo apt-get install timeshift
once installed, launch the app, and create a snapshot of the system, just in case something goes wrong, you can restore your system to a previous working state. Also, try to save the snapshot in a different location/disk/partition with an ext4 filesystem.
#15 2021-07-16 15:13
mayybe
Nice.
I installed this bumblebee driver.
How i should check that he is working?
#16 2021-07-16 15:20
mayybe wrote:
Nice.
Have you already rebooted? Is everything working? Launch konsole(terminal)and run
inxi -G
this will display graphics information. If inxi is not installed, you may install it with
sudo apt-get install inxi
once it is, run the above command. Another way is
lspci | grep -i --color 'vga\|3d\|2d'
this works without installing anything else.
#17 2021-07-16 15:27
mayybe
After reboot i think everything works fine.
runned inxi -G:
Graphics:
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
  driver: i915 v: kernel
  Device-2: NVIDIA GF119M [GeForce GT 520MX] driver: nvidia v: 390.143
  Display: tty server: X.Org 1.20.4 driver: modesetting unloaded: fbdev,vesa
  resolution: 1600x900~60Hz
  Message: Unable to show advanced data. Required tool glxinfo missing
#18 2021-07-16 16:15
mayybe
Is there power management that i can install?
#19 2021-07-16 16:39
runned inxi -G:
Graphics:
Well, inxi output shows that the GPU is using the nvidia driver: driver: nvidia v: 390.143 so I guess it worked.
Both Q4OS versions; Trinity and Plasma, have an integrated power manager tool, in Plasma it is in system setting > hardware can't remember where it is in Trinity, sorry, I use Plasma. However, you can install a different one too:
1. xfce4-power-manager https://docs.xfce.org/xfce/xfce4-power- … references
sudo apt-get install xfce4-power-manager
2. lxqt-powermanagement https://manual.lubuntu.me/stable/3/3.2/ … ement.html
sudo apt-get install lxqt-powermanagement
#20 2021-07-16 22:48
mayybe
Bumblebee have own power management for graphics card?
If yes how i can run him?
#21 2021-07-17 08:39
aluma
Here it is written https://wiki.debian.org/Bumblebee
The technology Optimus is well described in the Ubuntu wiki, but I have a link only in Russian  https://help.ubuntu.ru/wiki/bumblebee
