#1 2021-06-14 09:59
alexsunny123
After update cannot change the Konsole colour theme ?
Hello,
Previously I was able to change the default Konsole colour scheme. Now, I change colour scheme to 'Black on white' for example, hit 'Save parameters', but colour scheme is changing only to current session. When I close Konsole and open it again, colour scheme is reverted to default white on black scheme. It does not save anymore
thanks
alexsunny
https://t.me/pump_upp
#2 2021-06-14 16:01
commanddotcom
Re: After update cannot change the Konsole colour theme ?
I'm not sure what kind of answer do you need, but I think it is worth mentioning that ~/.bashrc file is responsible for most of the styles in your terminal window.
#3 2021-06-15 05:46
Once you've got it looking how you want you need to go to Settings>Save as Default  (that's in TDE - not sure if that's the case in Plasma)
