#1 2021-05-22 20:32
aluma
Pdf files.
There is a problem with pdf newer versions of files in linux.
I have to periodically print several such files of the same format and not all of them I can open in Linux.
But there is a pdfsam program in the repository.
With all its antediluvian interface, it works great!
Combines, extracts, and converts to a readable Linux version.
#2 2021-05-23 05:22
Re: Pdf files.
When it comes to pdf files I feel your pain. Usually some 'creative' types have gone mad with Adobe Illustrator and produced a mahoosive file for a logo the size of a penny!!!!
I find that good old ghostview is often a good standby too.
On the subject of printing pdfs I used to run in to problems with the standard CUPS driver, but with the same ppd CUPS+gutenprint does the job just right.
#3 2021-05-23 23:38
LanceHaverkamp
Re: Pdf files.
Okular is an OK reader.  If you need to fill in government forms or other such stuff; there's a great tool at the following url:
code-industry.net/masterpdfeditor/
Which I can't link for you because of poorly executed forum security.
#4 2021-05-29 12:52
Re: Pdf files.
I also use Master PDF Editor. I my opinion, currently it is the best PDF viewer and editor for Linux.
https://code-industry.net/masterpdfeditor/
#5 2021-05-29 12:54
Re: Pdf files.
What do you mean by "poorly executed forum security"?
#6 2021-05-31 20:37
LanceHaverkamp
Re: Pdf files.
The forum software is designed to let users insert linked URLs for the convenience of readers.  But later, when someone goes to the trouble to track-down the correct link, provide it with the correct tags--so it will be easy for others to access; the form software says linked URL's have been disallowed.
I don't know if breaking the ability to have working links is security theater, or an attempt to avoid spam, or done for some other reason; but such intentional breakage doesn't seem to make users more secure, rather they're just an inconvenience for the users.
Some days I'm just curmudgeonly ;-)
#7 2021-06-01 19:34
aluma
Re: Pdf files.
...I find that good old ghostview is often a good standby too...
There is no perfection in life! smile
Kpdf has the awesome feature to select part of a document and save it as text or drawing.
But unfortunately it cannot open the latest versions of * .pdf documents.
You have to keep a "menagerie" of programs on your computer.
