#1 2021-04-27 03:19
arcadianblue
Telegram App on Q4OS broke after updating
My friend updated his Telegram App on his Q4OS and now can't re-install it or run it. He keeps getting in terminal message "Q4standardpath: XTG_runtime_dir not set, defaulting to '/tmp/runtime-root".
We tried deleting and freshly re-running the telegram application. Anyone know what is the fix for this?
He is running Trinity desktop Scorpion 2.7.
Thanks
#2 2021-04-27 08:23
Re: Telegram App on Q4OS broke after updating
Which way did you install and update the Telegram application ?
#3 2021-04-29 21:21
arcadianblue
It is working again. I did get update and i removed old installation and downloaded the older package . Quickly disabled Telegram from automatically updating and it now works again. Thanks all!
