#1 2021-03-07 19:52
Gemini and Kernel versions.
I recently installed Gemini, and it's working great, however, after an update/upgrade kernel 5.9.15 got upgraded to 5.10.13 and noticed the system got slowed down a bit, I tried a few things to no avail, so I just decided to use 5.9 and that fixed it. Has anybody else seen this?
This is the machine specs
CPU: 2 × AMD E-300 APU with Radeon(tm) HD Graphics
RAM: 2 GiB
GPU: AMD PALM
I know it's a low spec machine but Centaurus with KDE runs great; RAM usage is around 400mb in idle. With Gemini is around 500mb, using kernel 5.9, while with 5.10 it used around 700-800mb.
#2 2021-03-19 16:00
Re: Gemini and Kernel versions.
Ive had no issues the 5.10 kernel with both my older or newer hardware and I run it mainly on laptops.
#3 2021-03-19 23:09
Actually, 5.10 has been working fine for the last couple of weeks now. Not sure what happened, maybe it wasn't that after all but rather some other thing/setting.
