#1 2021-02-17 19:00
maximorus
error code 70
Desktop profiler ends with error code 70 while installin q4os on virtualbox 6.1 @ubuntu 18x64
installed from iso q4os-3.14-x64-instcd.r2.iso                                        │475136K
e84496ccff793c34b079567d85e642d1  q4os-3.14-x64-instcd.r2.iso
installed ok. Asked about installing virtualbox tools with detailed instructions.
Upon reboot, tried to install packages with Desktop profiler.
-------------------------error like Hash Sum mismatch
Fetched 87.2 MB in 1min 45s (831 kB/s)
Failed to fetch 0debian10.0.0+0~a_amd64.deb Hash Sum mismatch
Hashes of expected file:
- SHA256:9c8fd548fb79831e2ad96889f6f341ac4de659c5d2c423d2ffb314a4a38c25aa
- SHA1:efc29ec7d4310bb05e6313536a6d3d39d476b704 [weak]
- MD5Sum:1f7dc93289ce48a810172e804363fd5a [weak]
- Filesize:1873696 [weak]
Hashes of received file:
- SHA256:fc63ad62938b4e05fd69861d14c8e584c3374fc421a2c070eead51ba0572aaa8
- SHA1:f5e4ab417c08343b4e51b38ba1e798c8c67753f1 [weak]
- MD5Sum:0e17cc5b89eda0ac2362fcb02a00051c [weak]
Last modification reported: Mon, 16 Mar 2020 21:50:36 +0000
E: Failed to fetch debian/pool/main/o/oxygen-icons5/oxygen-icon-theme_5.54.0-1_all.deb Hash Sum mismatch
- SHA256:c8a905c87922dc95b0a32e8f57432eeb6fe4dd8b003029caa5b779d14986cc1c
- MD5Sum:d84d4bf620cd92b288c88be83b84d3f6 [weak]
- Filesize:31266944 [weak]
- SHA256:8aa36912ae20443870b57cde061b936e33002557f0b5dcae9915d345c0bf0730
Last modification reported: Fri, 18 Jan 2019 03:13:27 +0000
E: Failed to fetch ool/main/l/ldb/python-ldb_1.5.1+really1.4.6-3_amd64.deb Hash Sum mismatch
- SHA256:dd0515a81aafe7ac3d38e19ee5eb6eee48f5a54123a305892b12934dd32f98c1
- MD5Sum:9fe3e86b53ab583152e2e3b6017836f6 [weak]
- Filesize:37908 [weak]
- SHA256:9d66d8190c92f087eeb39772702864b2ff9d767e743d301194d4f766c076984f
Last modification reported: Sat, 30 Mar 2019 20:48:20 +0000
E: Some files failed to download
Error: Packages couldn't be retreived.
Please re-login active session as soon as possible.
somehow got invalid characters in /var/lib/dpkg/status
deleted entry about package (gstreamer1.0-libav)
dpkg -i /var/cache/apt/archives/*.deb
I relate this to problems with virt io drivers of kernel with virtualbox, after reinstalling virtualbox tools and several reboots works fine/
#2 2021-02-17 21:14
Re: error code 70
Findings below are based on the information you sent via e-mail. The installation didn't proceed correctly, there are bunch of segmentation faults and errors in the installation "syslog" file. Desktop profiler failed as a result of the corrupted install process. We conclude, the Virtual machine doesn't work properly for your Q4OS installation. You could try to change some setup parameters of the virtual machine.
We are not able to reproduce the issue, did anyone else encounter such Desktop profiler errors ?
Your account has been promoted to be able to post hyperlinks and attach files. Click "Post reply" > Attachment > Choose file
