Centaurus TDE
I have been trying - unsuccessfully - to use a different theme for TDM.
Once upon a time in the days of KDE 3 there was a theme change utility and I have installed tdmtheme-trinity.
However if you go to Administrator mode it just crashes when you hit Enable Themes.
Is it just not possible with the modern TDM?
What system do you use ?
Umm..sorry, not exactly sure what you need to know.
TDE Centaurus - 3.13.1 14.06 64bit Intel - currently testing this in a VM but that shouldn't make any difference.
Yes, that's what we needed, we are going to test it as well.
We are not able to reproduce the issue, changing TDM theme is working fine in Virtualbox as well as on a real hardware.
Testing procedure:
- Virtualbox 6, 2GB RAM
- Clean installation Q4OS 3 Centaurus TDE from the live media, q4os-3.13-x64-tde.r1.iso
- Install "tdmtheme-trinity" package
- Run the Control panel from the start menu > System administration > TDM theme manager > Administrator mode > Enable TDM themes > Select a "O2 enterprise" theme > Apply > Ok
- Reboot and check the TDM screen
What could be a different from your configuration ?
Probably it's because I'm a twit
What I was doing was just checking Enable Themes>Apply
I then expected to be able to access the list and pick a theme.
Following your method of Enable and the pick theme at the same time does of course work perfectly.
Sorry to have been a pain - lockdown is getting to the old brain cell!
No problem with that, any meaningful reporting is appreciated. Thanks for contributing in this forum.
