#1 2021-01-24 11:31
crsov
Bios UEFI 64bit plasma | no graphical session started during the instl
Hi
Yesterday i tried install the most newer plasma 64bit q4os version on my notebook
I flashed .iso file to 2gb usb stick reboot into live media successfully and picked first option, doesn't see any fatal error when pseudo fs & etc loads, but there was no graphical loaded.
Today i re-flashed .iso to usb stick and again reboot in installation media successfully, but again i am in terminal no graphical live loaded, first i think this is problem with graphical drivers but on my notebook i had intel and i know intel have many open source drivers and i never installed drivers for him on many different Linux'ses, second i tried to run: startx and looked into xorg log and i saw "Cannot run in framebuffer mode. Please specify the busIDs for all framebuffer devices" global/fatal error and some font warns, next i searchs what does this fatal error mean in the internet, and i founded some info about its may be problem with firmwares, found NetworkManager preinstalled and used it to connect my home wifi and install firmwares, but all off them are already preinstalled, i also found some info about xorg fatal error its may be problem with Debian version, and i updated all by "sudo apt update && sudo apt upgrade" and i reboot live media but again no graphical session loaded and i am in the terminal, i again tried startx and looked into xorg log and saw same fatal error, but i also saw a change xorg now doesn't compiles his modules to modules versions, maybe updating all isnt good idea, but its easy to re-flash .iso again.
Cpu architecture: x86_64
Bios mode: UEFI
Windows 10 installed: yes i wanna a dualboot
Ram: 8
Disk unsed space: over 800gb
So i dont know how to paste some outputs to pastebin.com or others in the terminal.
#2 2021-01-24 11:41
crsov
Re: Bios UEFI 64bit plasma | no graphical session started during the instl
Lspci output http://imgur.com/gallery/AwDT6aT file too big to attach
#3 2021-01-24 11:46
Your account has been promoted to be able to post hyperlinks and attach files. Click "Post reply" > Attachment > Choose file
#4 2021-01-24 11:47
crsov
#5 2021-01-24 11:48
crsov
I can create git repo and paste paste outputs to the files abd files to repo from terminal only
#6 2021-01-24 11:58
crsov
http://imgur.com/gallery/Q6vuN0e look this
After  i reboot into failsave
