#1 2021-01-20 05:35
hoobershaggus
laptop, number of things do not work, brightness, volume keys, touchp
I liked q4os so much I finally installed it on real hardware. a Lenovo ThinkPad Edge 20C6008SUS (A haswell i5 laptop)
But I cannot get a number of things to work.
- My touchpad is very jerky, and the scrolling does not work. there's no option to configure it under the relevant settings menu.
- Volume keys do not work, I figured this wouldn't be an issue, since they worked out of the box on openbsd and solaris 10.
- Brightness keys, also does not seem to work. The monitor is stuck at 100% brightness and doesn't change depending on battery, or ac power state.
my laptop bios is not configured to use the fn key for brightness/volume, but I enabled that and tried using it with the fn key anyways and it still didn't work.
This is the ONE distro that has actually installed properly without self destr
ucting within an hour of use, and i'm really liking it otherwise, so i'd love to get it working. q4os truly is a hidden gem, as is the trinity desktop.
#2 2021-01-20 06:08
hoobershaggus
Re: laptop, number of things do not work, brightness, volume keys, touchp
im  currently scouring the forums for hw info commands to run. heres the first one:
inxi -f
CPU:
  Topology: Dual Core model: Intel Core i5-4200M bits: 64 type: MT MCP
  L2 cache: 3072 KiB
  Speed: 2993 MHz min/max: 800/3100 MHz Core speeds (MHz): 1: 2993 2: 2994
  3: 2992 4: 3082
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
  bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
  dtherm dts epb ept ept_ad erms est f16c flexpriority fma fpu fsgsbase fxsr
  ht ida invpcid invpcid_single lahf_lm lm mca mce mmx monitor movbe msr
  mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
  pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep smep ss
  sse sse2 sse4_1 sse4_2 ssse3 syscall tm tm2 t
#3 2021-01-20 06:46
hoobershaggus
Looks like the volume key is working in the mixer visually but doesnt actually do anything.
Looks like also my wifi disconnects if i open too many tabs...
Just forget it, linux as buggy as ever. I am formatting this and going back to openbsd, some things never change.
It is not even your fualt linux just fucking sucks.
#4 2021-01-20 10:16
Unfortunately, there are a few bugs in Trinity desktop version 14.0.6, what is used Q4OS Centaurus, they affect laptop hardware keys, so you likely encountered them. These bugs should be resolved in the coming Trinity desktop version 14.0.10, what will be deployed in Q4OS 4 Gemini.
