#1 2021-01-07 18:55
MFaklis
konsole toolbar
I'd like to use the konsole toolbar, which is available in other linux distros.  This allows me to create multiple konsole profiles, colors, size, and other options.  It also allows multiple tabs and multiple views.
#2 2021-01-08 06:39
Re: konsole toolbar
Do you mean the menu bar? if so right click anywhere in the konsole window and click Show Menubar then click Settings>Save as default.
Then you can easily access all the schemas and other tools
#3 2021-01-08 16:48
MFaklis
Re: konsole toolbar
Thank you.  It seems so easy now.
