#1 2021-01-02 19:28
[Solved] Krusader refuses to unmount removable device.
This is probably a bug in Krusader.
When you mount a removable drive, then try to unmount (attachment 1), system returns an error, even if there is nothing has been copied to the device. (attachment 2)
#2 2021-01-04 11:16
Re: [Solved] Krusader refuses to unmount removable device.
#3 2021-01-04 11:42
You need to go away from the mounted media subdirectory in Krusader as well as other file managers to be able to unmount the device. While you have a mounted subdirectory opened in any way, you will not be allowed to unmount it, as it's still active and might not be synchronized.
