#1 2020-12-24 20:53
[Solved] VLC sometimes does not closes correctly.
I use Q4OS Centaurus Trinity 3.13.
When I start playing video and close VLC while video is still playing, the VLC window disappears, but the application itself sometimes does not closes. As result I can not play another video or audio. I must first "kill" VLC, and only after that, I can play another video or audio. Please watch video: https://drive.google.com/file/d/1kxdY6f … sp=sharing
I have not experienced such issue on other Linuxes, so it is not hardware related.
#2 2020-12-24 21:14
Re: [Solved] VLC sometimes does not closes correctly.
Once you close the VLC screen, if you wait a bit longer does it eventually resolve itself or does VLC never close? Are you running any other apps at the same time that could slow the VLC process?
I dont run TDE but this doesnt happen in KDE version as I use VLC all the time.
I have seen comments in many forums about this issue on a variety of OS including Windows.
I also use to have an issue where the screensaver caused problems similar to this so havent used a screensaver since.
#3 2020-12-24 21:25
This is an old known bug https://forum.videolan.org/viewtopic.php?t=149762 Make sure to stop whatever media's been played in VLC before closing it, that is, hit the stop button or S key on your keyboard, then close it by clicking the x. For some reason if you don't, then it'll keep running as a zombie process. According to one VLC's dev is a bug in mesa's drivers, and they can't do anything about it.
Hope this helps! smile
#4 2020-12-24 21:34
Whats interesting is Im running VLC on a number of KDE based distros on a variety of hardware and havent had it happen since I stopped using a screensaver.
#5 2020-12-24 21:58
Thank you for fast responding!
No, VLC does not closes. I have been waiting for 15 minutes. There are still many vlc processes in Htop (attachment).
No, VLC is the only one app, I am running.
I have read about it a bit. One of the solutions is to select XCB as the video output. I have selected XVideo (XCB) and this problem looks like disappeared. But this makes some videos choppy (at least people say that.)
Also, there is a VLC Developer post in that forum: https://forum.videolan.org/viewtopic.ph … 62#p500511
If selecting XCB fixes stuff, then that almost certainly means your display drivers are buggy or missing. If you think this is a problem with your distro, you'd better raise the issue with the distro than on the VLC forum.
And that is exactly, what I am doing now. Maybe installing some driver will fix this issue...
I have Mesa 18.3.6 (attachment).
#6 2020-12-24 22:06
They need to look into further as changing drivers that work for most apps to solve an issue with one app, seems a bit silly.
#7 2020-12-24 22:25
OK, for now, I have choosen XVideo (XCB) as video output. I hope, I will not have this issue anymore.
I am not sure, which video output VLC uses as default in Q4OS.
P.S. Look at this post smile https://forum.videolan.org/viewtopic.ph … 25#p502721
#8 2020-12-24 22:38
I have set up video output on automatic again and run VLC from terminal as
qvlc
And got bunch of errors, and of course the closing problem (attachment).
#9 2020-12-24 22:38
Its an interesting post but glad you found a temporary solution.
#10 2020-12-24 22:55
One person in that forum said, that this issue goes away if he uses Wayland.
#11 2020-12-24 23:21
Interesting, but Ive got a huge number of systems old and new with a variety of drivers and havent had an issue. Appears that a certain system configuration does it for some but VLC needs to figure this out from their end.
#12 2020-12-25 06:57
You could always use smplayer + smtube for most stuff. I find it just as good as VLC for day to day use.
#13 2020-12-25 15:36
Thank you bin, but after installing proprietary NVIDIA drivers, the problem seems like disappeared. I will continue testing.
My system info is in attachment.
#14 2020-12-25 15:58
Like I said above "According to one VLC's dev is a bug in mesa's drivers, and they can't do anything about it." So yes, if you installed Nvidia drivers the problem should be no more and if you read that thread in its entirety, you'd have noticed that VLC's dev himself said "I can't reproduce the issue because i use Nvidia drivers and the problem is when using mesa's" The "solution" is to stop the media before closing VLC, that is, don't close VLC abruptly by clicking the x while is playing some media as this will cause the mesa drivers and X to hang, which IMO seems logical, after all this is just what happens when you close most processes before they finish whatever task they're doing, instead, hit the Stop button on VLC's playback bar or S key on your keyboard and then click the x. I can confirm this works. Q4OS team has nothing to do about it since this is not a Q4OS bug but rather some combination of misuse, OpenGL not handling some stuff properly and an aging X window system.
This is a bad idea. Again, in that same thread it is mentioned this as a "workaround" and while it "works"; VLC close properly, you have to sacrifice performance and playback quality like you just experienced.
