#1 2020-12-05 17:26
[Solved]How to remove old Kernels?
Good afternoon!
After some updates, I have three kernels installed on my Q4OS Centaurus (attachment).
How can I remove (purge completely) old unused kernels?
I am ashamed to admit it, but I still don't know how to do it.
Also, how can I hold kernel to prevent it to be auto-updated?
#2 2020-12-05 18:01
Dave67
Re: [Solved]How to remove old Kernels?
The safest way is to use
sudo apt autoremove
Though today I saw on Q4OS a odd issue if I use uname -r  to check the kernel version I get 4.19.0.11. If I go on synaptic and search for  linux-image. I see that 4.19.0.12 is installed and 4.19.0.11 is not. now thats odd.
I hope I can solve your problem smile
#3 2020-12-05 18:09
sudo apt autoremove does not removes kernels completely.
Also I want to know how to manually remove them. For example, I have kernels A, B, C. Kernel C is newest and active. How can I completely remove (purge) kernels A and B?
And how can I hold kernel C to prevent future updates of it?
#4 2020-12-05 18:28
Dave67
Backup your system first. Search for linux-image example linux-image 4.19.0.11  in synaptic right click and select complete removal.
To freeze a package read this
https://www.snel.com/support/how-to-blo … in-debian/
#5 2020-12-05 18:59
Dave67
I recommend foxclone for backups and cloning. I used it to clone my HDD to a SDD on my laptop.
https://www.foxclone.com/
#6 2020-12-05 19:03
You need to run:
$ sudo apt --purge remove linux-image-4.19.0-9-amd64
#7 2020-12-05 19:49
Thank you Dave67 and q4osteam!
I have removed old kernels and their headers!
I use Timeshift and Clonezilla Live for system backups.
