#1 2020-10-13 08:12
cpcnw
Weird Intermittent Buzzing Sound [SOLVED]
Hi All,
I have a pair of mains powered speakers plugged into the headphone jack. On first install sound worked fine. The mixer in the system tray would change the volume. Somethings happened and I don't know what? All I did was run latest updates which included a kernel and switch off system sounds in the control panel applet.
Now, I get a loud popping at times, sometimes just before or just after sound but worse is that after a short while of no sound the speakers start buzzing loudly. If I then start to play say some quiet music all is fine?
I've also noticed that the volume in the system tray now does nothing and is labeled 01001001 ??
Any tips?
sysadmin@q4os-desktop:~$ cat /proc/asound/cards
0 [HDMI           ]: HDA-Intel - HDA Intel HDMI
                      HDA Intel HDMI at 0xf7d34000 irq 30
1 [PCH            ]: HDA-Intel - HDA Intel PCH
                      HDA Intel PCH at 0xf7d30000 irq 27
System:
     Host: q4os-desktop Kernel: 4.19.0-11-amd64 x86_64 bits: 64 compiler: gcc v: 8.3.0 Desktop: Trinity R14.0.6 tk: Qt 3.5.0 wm: Twin dm: TDM Distro: Q4OS 3.12.1-n1 base: Debian GNU/Linux 10 (buster)
Machine:
     Type: Desktop System: LENOVO product: 10AAS1NM01 v: ThinkCentre M93p serial:
     Mobo: LENOVO model: SHARKBAY v: NOK serial: BIOS: LENOVO v: FBKTDBAUS date: 12/24/2019
Memory:
     RAM: total: 6.73 GiB used: 1.11 GiB (16.5%)
CPU:
     Topology: Dual Core model: Intel Core i5-4570T bits: 64 type: MT MCP arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 27 L2 cache: 4096 KiB
     flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23146
     Speed: 2218 MHz min/max: 800/3600 MHz Core speeds (MHz): 1: 2218 2: 1535 3: 2851 4: 1337
     Type: tsx_async_abort status: Not affected
Graphics:
     Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0412
     Display: x11 server: X.Org 1.20.4 driver: modesetting unloaded: fbdev,vesa resolution: 1920x1200~60Hz
     Message: Unable to show advanced data. Required tool glxinfo missing.
Audio:
     Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:03.0 chip ID: 8086:0c0c
     Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
     Sound Server: ALSA v: k4.19.0-11-amd64
Network:
     Device-1: Intel Ethernet I217-LM vendor: Lenovo driver: e1000e v: 3.2.6-k port: f060 bus ID: 00:19.0 chip ID: 8086:153a
     IF: eno1 state: down mac: 00:23:24:71:16:cf
     Device-2: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel port: 0580 bus ID: 02:00.0 chip ID: 8086:0888
     IF: wlp2s0 state: up mac: 68:17:29:be:6c:1b
Drives:
     Local Storage: total: 111.79 GiB used: 4.29 GiB (3.8%)
     ID-1: /dev/sda type: USB model: External USB3.0 size: 111.79 GiB block size: physical: 4096 B logical: 512 B serial: 201703310007F
     Optical-1: /dev/sr0 vendor: Slimtype model: eBAU108 6 L rev: PL03 dev-links: cdrom,cdrw,dvd,dvdrw
     Features: speed: 24 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
Partition:
     ID-1: / raw size: 104.87 GiB size: 102.72 GiB (97.95%) used: 4.29 GiB (4.2%) fs: ext4 dev: /dev/sda1 label: N/A uuid: 17d1a665-2a0d-4e16-becd-6b57dfac4e09
     ID-2: swap-1 size: 6.92 GiB used: 0 KiB (0.0%) fs: swap swappiness: 60 (default) cache pressure: 100 (default) dev: /dev/sda5 label: N/A uuid: c3e861d2-4b9e-43ba-b1ac-26eece0732dc
Unmounted:
     ID-1: /dev/sda2 size: 1 KiB fs: label: N/A uuid: N/A
USB:
     Hub: 1-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0 chip ID: 1d6b:0002
     Hub: 1-1:2 info: Intel ports: 6 rev: 2.0 chip ID: 8087:8008
     Hub: 2-0:1 info: Full speed (or root) Hub ports: 15 rev: 2.0 chip ID: 1d6b:0002
     Hub: 2-3:3 info: Genesys Logic Hub ports: 4 rev: 2.0 chip ID: 05e3:0608
     Device-1: 2-3.1:5 info: Logitech Unifying Receiver type: Keyboard,Mouse driver: hid-generic,usbhid rev: 2.0 chip ID: 046d:c534
     Device-2: 2-3.2:7 info: Lite-On type: Keyboard,HID,Mouse driver: hid-generic,usbhid rev: 2.0 chip ID: 04ca:0064
     Device-3: 2-6:4 info: Intel type: Bluetooth driver: btusb rev: 2.0 chip ID: 8087:07da
     Device-4: 2-9:6 info: Philips & Lite-ON Digital Solutions type: Mass Storage driver: usb-storage rev: 2.0 chip ID: 1c6b:a223
     Hub: 3-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0 chip ID: 1d6b:0002
     Hub: 3-1:2 info: Intel ports: 8 rev: 2.0 chip ID: 8087:8000
     Hub: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 chip ID: 1d6b:0003
     Device-5: 4-1:2 info: JMicron / JMicron USA JMS567 SATA 6Gb/s bridge type: Mass Storage driver: uas rev: 3.0 chip ID: 152d:0578
Sensors:
     Missing: Required tool sensors not installed. Check --recommends
Info:
     Processes: 147 Uptime: 43m Init: systemd v: 241 runlevel: 5 target: graphical.target Compilers: gcc: N/A Shell: Unknown Client: cpuqinfo.exu running in: systemd inxi: 3.0.32
#2 2020-10-13 08:36
cpcnw
Re: Weird Intermittent Buzzing Sound [SOLVED]
OK so I have just right clicked on master volume control in system tray and chosen "Select Master Channel" as HDA Intel PCH and now that control is working...
#3 2020-10-13 21:05
cpcnw
In Control Centre > Configure there is an option 'Auto-Suspend'
Un-ticking the box seems to have cured the issue?
