#1 2020-10-08 16:07
Aeterna
Dev Pack Installer Problem
I downloaded the Q4OS Development Pack to start developing some GUI applications for Trinity but hit a small bump. It threw an error message about my internet connection being too slow (it wasn't and Chrome loaded sites just fine) and refused to continue, and then completely locked up apt and dpkg even after the installer program was closed. I was unable to find the process that had the lock on package management and trying to manually delete the lock as root or log out did nothing. I was only able to fix this and get it to install by rebooting the computer and trying again.
It would be awesome if the Developers page had a manual install guide that just listed the packages you need to install to get TDevelop and libraries and stuff. People who want to program on Q4OS probably know their way around Debian package management and might not need a special binary installer.
TDevelop works great by the way. It was only the installer that caused any issues.
#2 2020-10-09 08:09
Re: Dev Pack Installer Problem
Thanks for the report. We are not able to reproduce the issue, so it would be helpful, if would post the installer log here for us to be able to investigate it. You can find the log in "$HOME/.appsetup2/log/setup-q4os-devpack.log"
#3 2020-10-09 16:58
Aeterna
I checked the log file you mentioned but there are no errors in it. It must have been overwritten when I did the second successful install since I don't see another one in there. Here's the log anyways but I don't see anything of use in it.
Calculating progress ...
Testing Internet connection ...
Testing Internet connection ... OK
Extracting archive ...
Extracting archive ... Done
Checking package system ...
Reading package lists... 100%
Reading package lists... Done
Building dependency tree
Reading state information... 0%
Verified ... OK
Autofix not needed ... OK
Waiting to complete current operation ... Done
Adding security keys ...
Adding security keys ... OK
Preparing installation files ...
Preparing installation files ... OK
Partial update sw database ...
0% [Working]
Ign:1 copy:/tmp/tmp.7YtraK9d9q-q4appsetup tmp-setup-repo/ InRelease
0% [Working]
Ign:2 copy:/tmp/tmp.7YtraK9d9q-q4appsetup tmp-setup-repo/ Release
7% [Working]
Ign:3 copy:/tmp/tmp.7YtraK9d9q-q4appsetup tmp-setup-repo/ Packages
7% [Working]
Ign:4 copy:/tmp/tmp.7YtraK9d9q-q4appsetup tmp-setup-repo/ Translation-en_US.UTF-8
7% [Working]
Ign:5 copy:/tmp/tmp.7YtraK9d9q-q4appsetup tmp-setup-repo/ Translation-en_US
7% [Working]
Ign:6 copy:/tmp/tmp.7YtraK9d9q-q4appsetup tmp-setup-repo/ Translation-en
7% [Working]
7% [Working]
7% [Working]
7% [Working]
7% [Working]
7% [Working]
7% [Working]
7% [Working]
7% [Working]
Get:3 copy:/tmp/tmp.7YtraK9d9q-q4appsetup tmp-setup-repo/ Packages [1,158 B]
7% [3 Packages 0 B/1,158 B 0%]
87% [Working]
87% [Working]
87% [Working]
87% [Working]
87% [3 Packages store 0 B]
90% [Working]
90% [Working]
90% [Working]
90% [Working]
90% [Working]
93% [Working]
97% [Working]
100% [Working]
Fetched 1,158 B in 0s (93.7 kB/s)
Reading package lists... 6%
Partial update sw database ... Done
Testing installation ...
Reading package lists... 97%
The following packages were automatically installed and are no longer required:
libappindicator3-1 libindicator3-7
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
binfmt-support binutils-dev bzip2-doc checkinstall clang clang-7 cmake
cmake-data comerr-dev cvs gdb geoclue-2.0 gettext graphviz hspell
icu-devtools kdevdesigner-trinity kdiff3-trinity kdiff3-trinity-doc
khexedit-trinity krb5-multidev lib32gcc1 lib32stdc++6 libacl1-dev libapr1
libaprutil1 libart-2.0-dev libarts1-trinity-dev libartsc0-trinity-dev
libasound2-dev libaspell-dev libattr1-dev libaudio-dev libaudiofile-dev
libavahi-client-dev libavahi-common-dev libbabeltrace1 libblkid-dev
libbz2-dev libc6-dbg libc6-i386 libcdt5 libcgraph6 libclang-common-7-dev
libclang1-7 libcups2-dev libcupsfilters-dev libcupsimage2-dev
libcvsservice0-trinity libdbus-1-dev libdbus-1-tqt-dev libdrm-dev libdw1
libexpat1-dev libffi-dev libfontconfig1-dev libfontenc-dev libfreetype6-dev
libgl1-mesa-dev libgles1 libglib2.0-dev libglib2.0-dev-bin libglu1-mesa-dev
libglvnd-core-dev libglvnd-dev libgssrpc4 libgts-0.7-5 libgts-bin libgvc6
libgvpr2 libice-dev libicu-dev libidn11-dev libilmbase-dev libipt2
libjasper-dev libjbig-dev libjpeg-dev libjpeg62-turbo-dev libjsoncpp1
libkadm5clnt-mit11 libkadm5srv-mit11 libkdb5-9 libkrb5-dev liblab-gamut1
liblcms2-dev libltdl-dev liblua50 liblua50-dev liblualib50 liblualib50-dev
liblzma-dev libmad0-dev libmbim-glib4 libmbim-proxy libmng-dev libmount-dev
libncurses-dev libobjc-8-dev libogg-dev libomp-7-dev libomp5-7
libopenexr-dev libopengl0 libpathplan4 libpciaccess-dev libpcre16-3
libpcre3-dev libpcre32-3 libpcrecpp0v5 libpixman-1-dev libpng-dev
libpng-tools libqbscore1.12 libqbsqtprofilesetup1.12 libqmi-glib5
libqmi-proxy libqt5designer5 libqt5designercomponents5 libqt5help5
libqt5positioning5 libqt5quick5 libqt5quicktest5 libqt5quickwidgets5
libqt5sensors5 libqt5serialport5 libqt5webchannel5 libqt5webkit5
libqt5xmlpatterns5 libr-dev librhash0 libsasl2-dev libselinux1-dev
libsepol1-dev libserf-1-1 libsm-dev libssl-dev libsvn1 libtiff-dev
libtiffxx5 libtinfo-dev libtool libtqt3-compat-headers libtqt3-headers
libtqt3-mt-dev libtqtinterface-dev libudev-dev libutf8proc2 libuv1
libvorbis-dev libx11-xcb-dev libxcb-dri2-0-dev libxcb-dri3-dev
libxcb-glx0-dev libxcb-present-dev libxcb-randr0-dev libxcb-render0-dev
libxcb-shape0-dev libxcb-sync-dev libxcb-xfixes0-dev libxcomposite-dev
libxcursor-dev libxdamage-dev libxdot4 libxfixes-dev libxfont-dev libxft-dev
libxi-dev libxinerama-dev libxkbfile-dev libxml2-dev libxml2-utils
libxmu-dev libxmu-headers libxrandr-dev libxrender-dev libxshmfence-dev
libxslt1-dev libxt-dev libxxf86vm-dev llvm-7 llvm-7-dev llvm-7-runtime lua50
mc mc-data mesa-common-dev modemmanager pkg-config python3-distutils
python3-lib2to3 qbs-common qdoc-qt5 qml-module-qtgraphicaleffects
qml-module-qtqml-models2 qml-module-qtquick-controls
qml-module-qtquick-layouts qml-module-qtquick-window2 qml-module-qtquick2
qmlscene qt3d5-doc qt5-assistant qt5-doc qt5-qmltooling-plugins
qtbase5-dev-tools qtbase5-doc qtcharts5-doc qtconnectivity5-doc qtcreator
qtcreator-data qtcreator-doc qtdeclarative5-dev-tools qtdeclarative5-doc
qtgraphicaleffects5-doc qtlocation5-doc qtmultimedia5-doc
qtquickcontrols2-5-doc qtquickcontrols5-doc qtscript5-doc qtsensors5-doc
qtserialport5-doc qtsvg5-doc qttools5-dev-tools qttools5-doc
qtvirtualkeyboard5-doc qtwayland5-doc qtwebchannel5-doc qtwebengine5-doc
qtwebsockets5-doc qtwebview5-doc qtx11extras5-doc qtxmlpatterns5-dev-tools
qtxmlpatterns5-doc reprepro tdecachegrind-trinity tdelibs14-trinity-dev
tdevelop-data-trinity tdevelop-trinity tdevelop-trinity-doc tqt3-apps-dev
tqt3-assistant tqt3-designer tqt3-dev-tools tqt3-doc tqt3-linguist
tqt3-qtconfig uuid-dev valgrind valgrind-dbg x11proto-composite-dev
x11proto-damage-dev x11proto-fixes-dev x11proto-input-dev x11proto-randr-dev
x11proto-xf86vidmode-dev x11proto-xinerama-dev xfonts-terminus
xserver-xorg-dev zlib1g-dev
Suggested packages:
clang-7-doc cmake-doc ninja-build doc-base mksh rcs gdb-doc gdbserver
gettext-doc autopoint libasprintf-dev libgettextpo-dev graphviz-doc krb5-doc
libasound2-doc aspell-doc freetype2-doc libglib2.0-doc krb5-user libice-doc
icu-doc libtool-doc liblzma-doc ncurses-doc libomp-7-doc libsm-doc
libssl-doc gfortran | fortran95-compiler gcj-jdk libtqt3-i18n libxt-doc
llvm-7-doc arj catdvi | texlive-binaries dbview djvulibre-bin epub-utils gv
links | w3m | lynx odt2txt python-boto python-tz qtbase5-dev clazy git
kate-data subversion inoticoming lzip tdecachegrind-converters-trinity
tdesdk-trinity-doc-html sgmltools-lite kbabel-trinity tdeiconedit-trinity
tdesdk-scripts-trinity exuberant-ctags tdelibs14-trinity-doc
libtqtinterface-doc valgrind-mpi kcachegrind alleyoop valkyrie
xfonts-terminus-oblique
Recommended packages:
valgrind-callgrind-trinity | valgrind-calltree-trinity
python3-lib2to3 q4os-devpack qbs-common qdoc-qt5
qml-module-qtgraphicaleffects qml-module-qtqml-models2
qml-module-qtquick-controls qml-module-qtquick-layouts
qml-module-qtquick-window2 qml-module-qtquick2 qmlscene qt3d5-doc
qt5-assistant qt5-doc qt5-qmltooling-plugins qtbase5-dev-tools qtbase5-doc
qtcharts5-doc qtconnectivity5-doc qtcreator qtcreator-data qtcreator-doc
qtdeclarative5-dev-tools qtdeclarative5-doc qtgraphicaleffects5-doc
qtlocation5-doc qtmultimedia5-doc qtquickcontrols2-5-doc
qtquickcontrols5-doc qtscript5-doc qtsensors5-doc qtserialport5-doc
qtsvg5-doc qttools5-dev-tools qttools5-doc qtvirtualkeyboard5-doc
qtwayland5-doc qtwebchannel5-doc qtwebengine5-doc qtwebsockets5-doc
qtwebview5-doc qtx11extras5-doc qtxmlpatterns5-dev-tools qtxmlpatterns5-doc
reprepro tdecachegrind-trinity tdelibs14-trinity-dev tdevelop-data-trinity
tdevelop-trinity tdevelop-trinity-doc tqt3-apps-dev tqt3-assistant
tqt3-designer tqt3-dev-tools tqt3-doc tqt3-linguist tqt3-qtconfig uuid-dev
valgrind valgrind-dbg x11proto-composite-dev x11proto-damage-dev
0 upgraded, 260 newly installed, 0 to remove and 0 not upgraded.
Inst libqt5positioning5 (5.11.3+dfsg-2 Debian:10.6/stable [amd64])
Inst libqt5quick5 (5.11.3-4 Debian:10.6/stable [amd64])
Inst libqt5sensors5 (5.11.3-2 Debian:10.6/stable [amd64])
Inst libqt5webchannel5 (5.11.3-2 Debian:10.6/stable [amd64])
Inst libqt5webkit5 (5.212.0~alpha2-21 Debian:10.6/stable [amd64])
Inst qml-module-qtquick-window2 (5.11.3-4 Debian:10.6/stable [amd64])
Inst qml-module-qtquick2 (5.11.3-4 Debian:10.6/stable [amd64])
Inst qml-module-qtgraphicaleffects (5.11.3-2 Debian:10.6/stable [amd64])
Inst qml-module-qtquick-layouts (5.11.3-4 Debian:10.6/stable [amd64])
Inst qml-module-qtquick-controls (5.11.3-2 Debian:10.6/stable [amd64])
Inst binfmt-support (2.2.0-2 Debian:10.6/stable [amd64])
Inst binutils-dev (2.31.1-16 Debian:10.6/stable [amd64])
Inst bzip2-doc (1.0.6-9.2~deb10u1 Debian:10.6/stable [all])
Inst checkinstall (1.6.2+git20170426.d24a630-2~bpo10+1 localhost [amd64])
Inst libobjc-8-dev (8.3.0-6 Debian:10.6/stable [amd64])
Inst libc6-i386 (2.28-10 Debian:10.6/stable [amd64])
Inst lib32gcc1 (1:8.3.0-6 Debian:10.6/stable [amd64])
Inst lib32stdc++6 (8.3.0-6 Debian:10.6/stable [amd64])
Inst libclang-common-7-dev (1:7.0.1-8+deb10u2 Debian:10.6/stable [amd64])
Inst libclang1-7 (1:7.0.1-8+deb10u2 Debian:10.6/stable [amd64])
Inst clang-7 (1:7.0.1-8+deb10u2 Debian:10.6/stable [amd64])
Inst clang (1:7.0-47 Debian:10.6/stable [amd64])
Inst cmake-data (3.13.4-1 Debian:10.6/stable [all])
Inst libjsoncpp1 (1.7.4-3 Debian:10.6/stable [amd64])
Inst librhash0 (1.3.8-1 Debian:10.6/stable [amd64])
Inst libuv1 (1.24.1-1 Debian:10.6/stable [amd64])
Inst cmake (3.13.4-1 Debian:10.6/stable [amd64])
Inst comerr-dev (2.1-1.44.5-1+deb10u3 Debian:10.6/stable [amd64])
Inst cvs (2:1.12.13+real-27 Debian:10.6/stable [amd64])
Inst libdw1 (0.176-1.1 Debian:10.6/stable [amd64])
Inst libbabeltrace1 (1.5.6-2+deb10u1 Debian:10.6/stable [amd64])
Inst libipt2 (2.0-2 Debian:10.6/stable [amd64])
Inst gdb (8.2.1-2+b3 Debian:10.6/stable [amd64])
Inst geoclue-2.0 (2.5.2-1 Debian:10.6/stable [amd64])
Inst gettext (0.19.8.1-9 Debian:10.6/stable [amd64])
Inst libcdt5 (2.40.1-6 Debian:10.6/stable [amd64])
Inst libcgraph6 (2.40.1-6 Debian:10.6/stable [amd64])
Inst libgts-0.7-5 (0.7.6+darcs121130-4 Debian:10.6/stable [amd64])
Inst libpathplan4 (2.40.1-6 Debian:10.6/stable [amd64])
Inst libxdot4 (2.40.1-6 Debian:10.6/stable [amd64])
Inst libgvc6 (2.40.1-6 Debian:10.6/stable [amd64])
Inst libgvpr2 (2.40.1-6 Debian:10.6/stable [amd64])
Inst liblab-gamut1 (2.40.1-6 Debian:10.6/stable [amd64])
Inst graphviz (2.40.1-6 Debian:10.6/stable [amd64])
Inst hspell (1.4-3 Debian:10.6/stable [amd64])
Inst icu-devtools (63.1-6+deb10u1 Debian:10.6/stable, Debian-Security:10/stable [amd64])
Inst libapr1 (1.6.5-1+b1 Debian:10.6/stable [amd64])
Inst libcvsservice0-trinity (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Inst libaprutil1 (1.6.1-4 Debian:10.6/stable [amd64])
Inst libserf-1-1 (1.3.9-7+b10 Debian:10.6/stable [amd64])
Inst libutf8proc2 (2.3.0-1 Debian:10.6/stable [amd64])
Inst libsvn1 (1.10.4-1+deb10u1 Debian:10.6/stable, Debian-Security:10/stable [amd64])
Inst tdevelop-data-trinity (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [all])
Inst tdevelop-trinity (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Inst x11proto-randr-dev (2018.4-4 Debian:10.6/stable [all])
Inst libxrender-dev (1:0.9.10-1 Debian:10.6/stable [amd64])
Inst libxrandr-dev (2:1.5.1-1 Debian:10.6/stable [amd64])
Inst libice-dev (2:1.0.9-2 Debian:10.6/stable [amd64])
Inst libsm-dev (2:1.2.3-1 Debian:10.6/stable [amd64])
Inst libxt-dev (1:1.1.5-1+b3 Debian:10.6/stable [amd64])
Inst libxmu-headers (2:1.1.2-2 Debian:10.6/stable [all])
Inst libxmu-dev (2:1.1.2-2+b3 Debian:10.6/stable [amd64])
Inst x11proto-fixes-dev (1:2018.4-4 Debian:10.6/stable [all])
Inst libxfixes-dev (1:5.0.3-1 Debian:10.6/stable [amd64])
Inst libxcursor-dev (1:1.1.15-2 Debian:10.6/stable [amd64])
Inst uuid-dev (2.33.1-0.1 Debian:10.6/stable [amd64])
Inst x11proto-xinerama-dev (2018.4-4 Debian:10.6/stable [all])
Inst libxinerama-dev (2:1.1.4-2 Debian:10.6/stable [amd64])
Inst x11proto-input-dev (2018.4-4 Debian:10.6/stable [all])
Inst libxi-dev (2:1.7.9-1 Debian:10.6/stable [amd64])
Inst zlib1g-dev (1:1.2.11.dfsg-1 Debian:10.6/stable [amd64])
Inst libjpeg62-turbo-dev (1:1.5.2-2+b1 Debian:10.6/stable [amd64])
Inst libjpeg-dev (1:1.5.2-2 Debian:10.6/stable [all])
Inst liblcms2-dev (2.9-3 Debian:10.6/stable [amd64])
Inst libmng-dev (1.0.10+dfsg-3.1+b5 Debian:10.6/stable [amd64])
Inst libpng-dev (1.6.36-6 Debian:10.6/stable [amd64])
Inst libexpat1-dev (2.2.6-2+deb10u1 Debian:10.6/stable, Debian-Security:10/stable [amd64])
Inst libfreetype6-dev (2.9.1-3+deb10u1 Debian:10.6/stable [amd64])
Inst pkg-config (0.29-6 Debian:10.6/stable [amd64])
Inst libfontconfig1-dev (2.13.1-2 Debian:10.6/stable [amd64])
Inst libxft-dev (2.3.2-2 Debian:10.6/stable [amd64])
Inst libaudio-dev (1.9.4-6 Debian:10.6/stable [amd64])
Inst libjbig-dev (2.1-3.1+b2 Debian:10.6/stable [amd64])
Inst liblzma-dev (5.2.4-1 Debian:10.6/stable [amd64])
Inst libtiffxx5 (4.1.0+git191117-2~deb10u1 Debian:10.6/stable, Debian-Security:10/stable [amd64])
Inst libtiff-dev (4.1.0+git191117-2~deb10u1 Debian:10.6/stable, Debian-Security:10/stable [amd64])
Inst libcupsimage2-dev (2.2.10-6+deb10u3 Debian:10.6/stable [amd64]) []
Inst libcups2-dev (2.2.10-6+deb10u3 Debian:10.6/stable [amd64])
Inst libdrm-dev (2.4.97-1 Debian:10.6/stable [amd64])
Inst mesa-common-dev (18.3.6-2+deb10u1 Debian:10.6/stable [amd64])
Inst libglvnd-core-dev (1.1.0-1 Debian:10.6/stable [amd64])
Inst libgles1 (1.1.0-1 Debian:10.6/stable [amd64])
Inst libopengl0 (1.1.0-1 Debian:10.6/stable [amd64])
Inst libglvnd-dev (1.1.0-1 Debian:10.6/stable [amd64])
Inst libx11-xcb-dev (2:1.6.7-1+deb10u1 Debian:10.6/stable [amd64])
Inst libxcb-dri3-dev (1.13.1-2 Debian:10.6/stable [amd64])
Inst libxcb-render0-dev (1.13.1-2 Debian:10.6/stable [amd64])
Inst libxcb-randr0-dev (1.13.1-2 Debian:10.6/stable [amd64])
Inst libxcb-shape0-dev (1.13.1-2 Debian:10.6/stable [amd64])
Inst libxcb-xfixes0-dev (1.13.1-2 Debian:10.6/stable [amd64])
Inst libxcb-sync-dev (1.13.1-2 Debian:10.6/stable [amd64])
Inst libxcb-present-dev (1.13.1-2 Debian:10.6/stable [amd64])
Inst libxshmfence-dev (1.3-1 Debian:10.6/stable [amd64])
Inst libxcb-dri2-0-dev (1.13.1-2 Debian:10.6/stable [amd64])
Inst libxcb-glx0-dev (1.13.1-2 Debian:10.6/stable [amd64])
Inst x11proto-damage-dev (1:2018.4-4 Debian:10.6/stable [all])
Inst libxdamage-dev (1:1.1.4-3+b3 Debian:10.6/stable [amd64])
Inst x11proto-xf86vidmode-dev (2018.4-4 Debian:10.6/stable [all])
Inst libxxf86vm-dev (1:1.1.4-1+b2 Debian:10.6/stable [amd64])
Inst libgl1-mesa-dev (18.3.6-2+deb10u1 Debian:10.6/stable [amd64])
Inst libglu1-mesa-dev (9.0.0-2.1+b3 Debian:10.6/stable [amd64])
Inst libtqt3-headers (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Inst tqt3-dev-tools (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Inst libtqt3-mt-dev (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Inst tqt3-apps-dev (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Inst kdevdesigner-trinity (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Inst kdiff3-trinity (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Inst kdiff3-trinity-doc (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [all])
Inst khexedit-trinity (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Inst libgssrpc4 (1.17-3 Debian:10.6/stable [amd64])
Inst libkdb5-9 (1.17-3 Debian:10.6/stable [amd64])
Inst libkadm5srv-mit11 (1.17-3 Debian:10.6/stable [amd64])
Inst libkadm5clnt-mit11 (1.17-3 Debian:10.6/stable [amd64])
Inst krb5-multidev (1.17-3 Debian:10.6/stable [amd64])
Inst libattr1-dev (1:2.4.48-4 Debian:10.6/stable [amd64])
Inst libacl1-dev (2.2.53-4 Debian:10.6/stable [amd64])
Inst libart-2.0-dev (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Inst libffi-dev (3.2.1-9 Debian:10.6/stable [amd64])
Inst python3-lib2to3 (3.7.3-1 Debian:10.6/stable [all])
Inst python3-distutils (3.7.3-1 Debian:10.6/stable [all])
Inst libglib2.0-dev-bin (2.58.3-2+deb10u2 Debian:10.6/stable [amd64])
Inst libblkid-dev (2.33.1-0.1 Debian:10.6/stable [amd64])
Inst libmount-dev (2.33.1-0.1 Debian:10.6/stable [amd64])
Inst libpcre32-3 (2:8.39-12 Debian:10.6/stable [amd64])
Inst libpcrecpp0v5 (2:8.39-12 Debian:10.6/stable [amd64])
Inst libpcre3-dev (2:8.39-12 Debian:10.6/stable [amd64])
Inst libsepol1-dev (2.8-1 Debian:10.6/stable [amd64])
Inst libselinux1-dev (2.8-1+b1 Debian:10.6/stable [amd64])
Inst libglib2.0-dev (2.58.3-2+deb10u2 Debian:10.6/stable [amd64])
Inst libartsc0-trinity-dev (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Inst libasound2-dev (1.1.8-1 Debian:10.6/stable [amd64])
Inst libaudiofile-dev (0.3.6-5 Debian:10.6/stable [amd64])
Inst libogg-dev (1.3.2-1+b1 Debian:10.6/stable [amd64])
Inst libvorbis-dev (1.3.6-2 Debian:10.6/stable [amd64])
Inst libmad0-dev (0.15.1b-10 Debian:10.6/stable [amd64])
Inst libtqtinterface-dev (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Inst libarts1-trinity-dev (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Inst libaspell-dev (0.60.7~20110707-6 Debian:10.6/stable [amd64])
Inst libavahi-common-dev (0.7-4+b1 Debian:10.6/stable [amd64])
Inst libdbus-1-dev (1.12.20-0+deb10u1 Debian:10.6/stable [amd64])
Inst libavahi-client-dev (0.7-4+b1 Debian:10.6/stable [amd64])
Inst libbz2-dev (1.0.6-9.2~deb10u1 Debian:10.6/stable [amd64])
Inst libc6-dbg (2.28-10 Debian:10.6/stable [amd64])
Inst libcupsfilters-dev (1.21.6-5 Debian:10.6/stable [amd64])
Inst libdbus-1-tqt-dev (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Inst libfontenc-dev (1:1.1.3-1+b2 Debian:10.6/stable [amd64])
Inst libgts-bin (0.7.6+darcs121130-4 Debian:10.6/stable [amd64])
Inst libicu-dev (63.1-6+deb10u1 Debian:10.6/stable, Debian-Security:10/stable [amd64])
Inst libidn11-dev (1.33-2.2 Debian:10.6/stable [amd64])
Inst libilmbase-dev (2.2.1-2 Debian:10.6/stable [amd64])
Inst libjasper-dev (1.900.1-debian1-2.5debian10.0.0+5~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Inst libkrb5-dev (1.17-3 Debian:10.6/stable [amd64])
Inst libltdl-dev (2.4.6-9 Debian:10.6/stable [amd64])
Inst liblua50 (5.0.3-8+b1 Debian:10.6/stable [amd64])
Inst liblualib50 (5.0.3-8+b1 Debian:10.6/stable [amd64])
Inst lua50 (5.0.3-8+b1 Debian:10.6/stable [amd64])
Inst liblua50-dev (5.0.3-8+b1 Debian:10.6/stable [amd64])
Inst liblualib50-dev (5.0.3-8+b1 Debian:10.6/stable [amd64])
Inst libmbim-glib4 (1.18.0-1 Debian:10.6/stable [amd64])
Inst libmbim-proxy (1.18.0-1 Debian:10.6/stable [amd64])
Inst libncurses-dev (6.1+20181013-2+deb10u2 Debian:10.6/stable [amd64])
Inst libomp5-7 (1:7.0.1-8+deb10u2 Debian:10.6/stable [amd64])
Inst libomp-7-dev (1:7.0.1-8+deb10u2 Debian:10.6/stable [amd64])
Inst libopenexr-dev (2.2.1-4.1+deb10u1 Debian:10.6/stable, Debian-Security:10/stable [amd64])
Inst libpciaccess-dev (0.14-1 Debian:10.6/stable [amd64])
Inst libpixman-1-dev (0.36.0-1 Debian:10.6/stable [amd64])
Inst libpng-tools (1.6.36-6 Debian:10.6/stable [amd64])
Inst qbs-common (1.12.2+dfsg-2 Debian:10.6/stable [all])
Inst libqbscore1.12 (1.12.2+dfsg-2 Debian:10.6/stable [amd64])
Inst libqbsqtprofilesetup1.12 (1.12.2+dfsg-2 Debian:10.6/stable [amd64])
Inst libqmi-glib5 (1.22.0-1.2 Debian:10.6/stable [amd64])
Inst libqmi-proxy (1.22.0-1.2 Debian:10.6/stable [amd64])
Inst libqt5designer5 (5.11.3-4 Debian:10.6/stable [amd64])
Inst libqt5designercomponents5 (5.11.3-4 Debian:10.6/stable [amd64])
Inst libqt5help5 (5.11.3-4 Debian:10.6/stable [amd64])
Inst libqt5quicktest5 (5.11.3-4 Debian:10.6/stable [amd64])
Inst libqt5quickwidgets5 (5.11.3-4 Debian:10.6/stable [amd64])
Inst libqt5serialport5 (5.11.3-2 Debian:10.6/stable [amd64])
Inst libqt5xmlpatterns5 (5.11.3-2 Debian:10.6/stable [amd64])
Inst libsasl2-dev (2.1.27+dfsg-1+deb10u1 Debian:10.6/stable, Debian-Security:10/stable [amd64])
Inst libssl-dev (1.1.1d-0+deb10u3 Debian:10.6/stable, Debian-Security:10/stable [amd64])
Inst libtinfo-dev (6.1+20181013-2+deb10u2 Debian:10.6/stable [amd64])
Inst libtool (2.4.6-9 Debian:10.6/stable [all])
Inst libtqt3-compat-headers (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Inst libudev-dev (241-7~deb10u4 Debian:10.6/stable [amd64])
Inst x11proto-composite-dev (1:2018.4-4 Debian:10.6/stable [all])
Inst libxcomposite-dev (1:0.4.4-2 Debian:10.6/stable [amd64])
Inst libxfont-dev (1:2.0.3-1 Debian:10.6/stable [amd64])
Inst libxkbfile-dev (1:1.0.9-2+b11 Debian:10.6/stable [amd64])
Inst libxml2-dev (2.9.4+dfsg1-7+b3 Debian:10.6/stable [amd64])
Inst libxml2-utils (2.9.4+dfsg1-7+b3 Debian:10.6/stable [amd64])
Inst libxslt1-dev (1.1.32-2.2~deb10u1 Debian:10.6/stable [amd64])
Inst llvm-7-runtime (1:7.0.1-8+deb10u2 Debian:10.6/stable [amd64])
Inst llvm-7 (1:7.0.1-8+deb10u2 Debian:10.6/stable [amd64])
Inst llvm-7-dev (1:7.0.1-8+deb10u2 Debian:10.6/stable [amd64])
Inst mc-data (3:4.8.22-1 Debian:10.6/stable [all])
Inst mc (3:4.8.22-1 Debian:10.6/stable [amd64])
Inst modemmanager (1.10.0-1 Debian:10.6/stable [amd64])
Inst qdoc-qt5 (5.11.3-4 Debian:10.6/stable [amd64])
Inst qml-module-qtqml-models2 (5.11.3-4 Debian:10.6/stable [amd64])
Inst qmlscene (5.11.3-4 Debian:10.6/stable [amd64])
Inst qt3d5-doc (5.11.3+dfsg-2 Debian:10.6/stable [all])
Inst qt5-assistant (5.11.3-4 Debian:10.6/stable [amd64])
Inst qt5-qmltooling-plugins (5.11.3-4 Debian:10.6/stable [amd64])
Inst qtbase5-dev-tools (5.11.3+dfsg1-1+deb10u4 Debian:10.6/stable [amd64])
Inst qtbase5-doc (5.11.3+dfsg1-1+deb10u4 Debian:10.6/stable [all])
Inst qtcharts5-doc (5.11.3-2 Debian:10.6/stable [all])
Inst qtconnectivity5-doc (5.11.3-2 Debian:10.6/stable [all])
Inst qtcreator-data (4.8.2-1 Debian:10.6/stable [all])
Inst qtcreator (4.8.2-1 Debian:10.6/stable [amd64])
Inst qtcreator-doc (4.8.2-1 Debian:10.6/stable [all])
Inst qtdeclarative5-dev-tools (5.11.3-4 Debian:10.6/stable [amd64])
Inst qtdeclarative5-doc (5.11.3-4 Debian:10.6/stable [all])
Inst qtgraphicaleffects5-doc (5.11.3-2 Debian:10.6/stable [all])
Inst qtlocation5-doc (5.11.3+dfsg-2 Debian:10.6/stable [all])
Inst qtmultimedia5-doc (5.11.3-2 Debian:10.6/stable [all])
Inst qtquickcontrols2-5-doc (5.11.3+dfsg-2 Debian:10.6/stable [all])
Inst qtquickcontrols5-doc (5.11.3-2 Debian:10.6/stable [all])
Inst qtscript5-doc (5.11.3+dfsg-3 Debian:10.6/stable [all])
Inst qtsensors5-doc (5.11.3-2 Debian:10.6/stable [all])
Inst qtserialport5-doc (5.11.3-2 Debian:10.6/stable [all])
Inst qtsvg5-doc (5.11.3-2 Debian:10.6/stable [all])
Inst qttools5-dev-tools (5.11.3-4 Debian:10.6/stable [amd64])
Inst qttools5-doc (5.11.3-4 Debian:10.6/stable [all])
Inst qtvirtualkeyboard5-doc (5.11.3+dfsg-2 Debian:10.6/stable [all])
Inst qtwayland5-doc (5.11.3-2 Debian:10.6/stable [all])
Inst qtwebchannel5-doc (5.11.3-2 Debian:10.6/stable [all])
Inst qtwebengine5-doc (5.11.3+dfsg-2+deb10u1 Debian:10.6/stable [all])
Inst qtwebsockets5-doc (5.11.3-5 Debian:10.6/stable [all])
Inst qtwebview5-doc (5.11.3-2 Debian:10.6/stable [all])
Inst qtx11extras5-doc (5.11.3-2 Debian:10.6/stable [all])
Inst qtxmlpatterns5-dev-tools (5.11.3-2 Debian:10.6/stable [amd64])
Inst qtxmlpatterns5-doc (5.11.3-2 Debian:10.6/stable [all])
Inst reprepro (5.3.0-1 Debian:10.6/stable [amd64])
Inst tdecachegrind-trinity (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Inst libr-dev (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Inst tdelibs14-trinity-dev (4:14.0.6-0debian10.0.0+0~a.2 Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Inst tdevelop-trinity-doc (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [all])
Inst tqt3-doc (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [all])
Inst tqt3-assistant (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Inst tqt3-designer (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Inst tqt3-linguist (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Inst tqt3-qtconfig (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Inst valgrind (1:3.14.0-3 Debian:10.6/stable [amd64])
Inst valgrind-dbg (1:3.14.0-3 Debian:10.6/stable [amd64])
Inst xfonts-terminus (4.40-2 Debian:10.6/stable [all])
Inst xserver-xorg-dev (2:1.20.4-1+deb10u1 Debian:10.6/stable, Debian-Security:10/stable [amd64])
Inst q4os-devpack (3.3.1-a1 localhost [all])
Inst qt5-doc (5.11.3-1 Debian:10.6/stable [all])
Conf libqt5positioning5 (5.11.3+dfsg-2 Debian:10.6/stable [amd64])
Conf libqt5quick5 (5.11.3-4 Debian:10.6/stable [amd64])
Conf libqt5sensors5 (5.11.3-2 Debian:10.6/stable [amd64])
Conf libqt5webchannel5 (5.11.3-2 Debian:10.6/stable [amd64])
Conf libqt5webkit5 (5.212.0~alpha2-21 Debian:10.6/stable [amd64])
Conf qml-module-qtquick-window2 (5.11.3-4 Debian:10.6/stable [amd64])
Conf qml-module-qtquick2 (5.11.3-4 Debian:10.6/stable [amd64])
Conf qml-module-qtgraphicaleffects (5.11.3-2 Debian:10.6/stable [amd64])
Conf qml-module-qtquick-layouts (5.11.3-4 Debian:10.6/stable [amd64])
Conf qml-module-qtquick-controls (5.11.3-2 Debian:10.6/stable [amd64])
Conf binfmt-support (2.2.0-2 Debian:10.6/stable [amd64])
Conf binutils-dev (2.31.1-16 Debian:10.6/stable [amd64])
Conf bzip2-doc (1.0.6-9.2~deb10u1 Debian:10.6/stable [all])
Conf checkinstall (1.6.2+git20170426.d24a630-2~bpo10+1 localhost [amd64])
Conf libobjc-8-dev (8.3.0-6 Debian:10.6/stable [amd64])
Conf libc6-i386 (2.28-10 Debian:10.6/stable [amd64])
Conf lib32gcc1 (1:8.3.0-6 Debian:10.6/stable [amd64])
Conf lib32stdc++6 (8.3.0-6 Debian:10.6/stable [amd64])
Conf libclang-common-7-dev (1:7.0.1-8+deb10u2 Debian:10.6/stable [amd64])
Conf libclang1-7 (1:7.0.1-8+deb10u2 Debian:10.6/stable [amd64])
Conf clang-7 (1:7.0.1-8+deb10u2 Debian:10.6/stable [amd64])
Conf clang (1:7.0-47 Debian:10.6/stable [amd64])
Conf cmake-data (3.13.4-1 Debian:10.6/stable [all])
Conf libjsoncpp1 (1.7.4-3 Debian:10.6/stable [amd64])
Conf librhash0 (1.3.8-1 Debian:10.6/stable [amd64])
Conf libuv1 (1.24.1-1 Debian:10.6/stable [amd64])
Conf cmake (3.13.4-1 Debian:10.6/stable [amd64])
Conf comerr-dev (2.1-1.44.5-1+deb10u3 Debian:10.6/stable [amd64])
Conf cvs (2:1.12.13+real-27 Debian:10.6/stable [amd64])
Conf libdw1 (0.176-1.1 Debian:10.6/stable [amd64])
Conf libbabeltrace1 (1.5.6-2+deb10u1 Debian:10.6/stable [amd64])
Conf libipt2 (2.0-2 Debian:10.6/stable [amd64])
Conf gdb (8.2.1-2+b3 Debian:10.6/stable [amd64])
Conf geoclue-2.0 (2.5.2-1 Debian:10.6/stable [amd64])
Conf gettext (0.19.8.1-9 Debian:10.6/stable [amd64])
Conf libcdt5 (2.40.1-6 Debian:10.6/stable [amd64])
Conf libcgraph6 (2.40.1-6 Debian:10.6/stable [amd64])
Conf libgts-0.7-5 (0.7.6+darcs121130-4 Debian:10.6/stable [amd64])
Conf libpathplan4 (2.40.1-6 Debian:10.6/stable [amd64])
Conf libxdot4 (2.40.1-6 Debian:10.6/stable [amd64])
Conf libgvc6 (2.40.1-6 Debian:10.6/stable [amd64])
Conf libgvpr2 (2.40.1-6 Debian:10.6/stable [amd64])
Conf liblab-gamut1 (2.40.1-6 Debian:10.6/stable [amd64])
Conf graphviz (2.40.1-6 Debian:10.6/stable [amd64])
Conf hspell (1.4-3 Debian:10.6/stable [amd64])
Conf icu-devtools (63.1-6+deb10u1 Debian:10.6/stable, Debian-Security:10/stable [amd64])
Conf libapr1 (1.6.5-1+b1 Debian:10.6/stable [amd64])
Conf libcvsservice0-trinity (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Conf libaprutil1 (1.6.1-4 Debian:10.6/stable [amd64])
Conf libserf-1-1 (1.3.9-7+b10 Debian:10.6/stable [amd64])
Conf libutf8proc2 (2.3.0-1 Debian:10.6/stable [amd64])
Conf libsvn1 (1.10.4-1+deb10u1 Debian:10.6/stable, Debian-Security:10/stable [amd64])
Conf tdevelop-data-trinity (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [all])
Conf tdevelop-trinity (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Conf x11proto-randr-dev (2018.4-4 Debian:10.6/stable [all])
Conf libxrender-dev (1:0.9.10-1 Debian:10.6/stable [amd64])
Conf libxrandr-dev (2:1.5.1-1 Debian:10.6/stable [amd64])
Conf libice-dev (2:1.0.9-2 Debian:10.6/stable [amd64])
Conf libsm-dev (2:1.2.3-1 Debian:10.6/stable [amd64])
Conf libxt-dev (1:1.1.5-1+b3 Debian:10.6/stable [amd64])
Conf libxmu-headers (2:1.1.2-2 Debian:10.6/stable [all])
Conf libxmu-dev (2:1.1.2-2+b3 Debian:10.6/stable [amd64])
Conf x11proto-fixes-dev (1:2018.4-4 Debian:10.6/stable [all])
Conf libxfixes-dev (1:5.0.3-1 Debian:10.6/stable [amd64])
Conf libxcursor-dev (1:1.1.15-2 Debian:10.6/stable [amd64])
Conf uuid-dev (2.33.1-0.1 Debian:10.6/stable [amd64])
Conf x11proto-xinerama-dev (2018.4-4 Debian:10.6/stable [all])
Conf libxinerama-dev (2:1.1.4-2 Debian:10.6/stable [amd64])
Conf x11proto-input-dev (2018.4-4 Debian:10.6/stable [all])
Conf libxi-dev (2:1.7.9-1 Debian:10.6/stable [amd64])
Conf zlib1g-dev (1:1.2.11.dfsg-1 Debian:10.6/stable [amd64])
Conf libjpeg62-turbo-dev (1:1.5.2-2+b1 Debian:10.6/stable [amd64])
Conf libjpeg-dev (1:1.5.2-2 Debian:10.6/stable [all])
Conf liblcms2-dev (2.9-3 Debian:10.6/stable [amd64])
Conf libmng-dev (1.0.10+dfsg-3.1+b5 Debian:10.6/stable [amd64])
Conf libpng-dev (1.6.36-6 Debian:10.6/stable [amd64])
Conf libexpat1-dev (2.2.6-2+deb10u1 Debian:10.6/stable, Debian-Security:10/stable [amd64])
Conf libfreetype6-dev (2.9.1-3+deb10u1 Debian:10.6/stable [amd64])
Conf pkg-config (0.29-6 Debian:10.6/stable [amd64])
Conf libfontconfig1-dev (2.13.1-2 Debian:10.6/stable [amd64])
Conf libxft-dev (2.3.2-2 Debian:10.6/stable [amd64])
Conf libaudio-dev (1.9.4-6 Debian:10.6/stable [amd64])
Conf libjbig-dev (2.1-3.1+b2 Debian:10.6/stable [amd64])
Conf liblzma-dev (5.2.4-1 Debian:10.6/stable [amd64])
Conf libtiffxx5 (4.1.0+git191117-2~deb10u1 Debian:10.6/stable, Debian-Security:10/stable [amd64])
Conf libtiff-dev (4.1.0+git191117-2~deb10u1 Debian:10.6/stable, Debian-Security:10/stable [amd64])
Conf libcupsimage2-dev (2.2.10-6+deb10u3 Debian:10.6/stable [amd64])
Conf libcups2-dev (2.2.10-6+deb10u3 Debian:10.6/stable [amd64])
Conf libdrm-dev (2.4.97-1 Debian:10.6/stable [amd64])
Conf mesa-common-dev (18.3.6-2+deb10u1 Debian:10.6/stable [amd64])
Conf libglvnd-core-dev (1.1.0-1 Debian:10.6/stable [amd64])
Conf libgles1 (1.1.0-1 Debian:10.6/stable [amd64])
Conf libopengl0 (1.1.0-1 Debian:10.6/stable [amd64])
Conf libglvnd-dev (1.1.0-1 Debian:10.6/stable [amd64])
Conf libx11-xcb-dev (2:1.6.7-1+deb10u1 Debian:10.6/stable [amd64])
Conf libxcb-dri3-dev (1.13.1-2 Debian:10.6/stable [amd64])
Conf libxcb-render0-dev (1.13.1-2 Debian:10.6/stable [amd64])
Conf libxcb-randr0-dev (1.13.1-2 Debian:10.6/stable [amd64])
Conf libxcb-shape0-dev (1.13.1-2 Debian:10.6/stable [amd64])
Conf libxcb-xfixes0-dev (1.13.1-2 Debian:10.6/stable [amd64])
Conf libxcb-sync-dev (1.13.1-2 Debian:10.6/stable [amd64])
Conf libxcb-present-dev (1.13.1-2 Debian:10.6/stable [amd64])
Conf libxshmfence-dev (1.3-1 Debian:10.6/stable [amd64])
Conf libxcb-dri2-0-dev (1.13.1-2 Debian:10.6/stable [amd64])
Conf libxcb-glx0-dev (1.13.1-2 Debian:10.6/stable [amd64])
Conf x11proto-damage-dev (1:2018.4-4 Debian:10.6/stable [all])
Conf libxdamage-dev (1:1.1.4-3+b3 Debian:10.6/stable [amd64])
Conf x11proto-xf86vidmode-dev (2018.4-4 Debian:10.6/stable [all])
Conf libxxf86vm-dev (1:1.1.4-1+b2 Debian:10.6/stable [amd64])
Conf libgl1-mesa-dev (18.3.6-2+deb10u1 Debian:10.6/stable [amd64])
Conf libglu1-mesa-dev (9.0.0-2.1+b3 Debian:10.6/stable [amd64])
Conf libtqt3-headers (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Conf tqt3-dev-tools (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Conf libtqt3-mt-dev (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Conf tqt3-apps-dev (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Conf kdevdesigner-trinity (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Conf kdiff3-trinity (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Conf kdiff3-trinity-doc (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [all])
Conf khexedit-trinity (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Conf libgssrpc4 (1.17-3 Debian:10.6/stable [amd64])
Conf libkdb5-9 (1.17-3 Debian:10.6/stable [amd64])
Conf libkadm5srv-mit11 (1.17-3 Debian:10.6/stable [amd64])
Conf libkadm5clnt-mit11 (1.17-3 Debian:10.6/stable [amd64])
Conf krb5-multidev (1.17-3 Debian:10.6/stable [amd64])
Conf libattr1-dev (1:2.4.48-4 Debian:10.6/stable [amd64])
Conf libacl1-dev (2.2.53-4 Debian:10.6/stable [amd64])
Conf libart-2.0-dev (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Conf libffi-dev (3.2.1-9 Debian:10.6/stable [amd64])
Conf python3-lib2to3 (3.7.3-1 Debian:10.6/stable [all])
Conf python3-distutils (3.7.3-1 Debian:10.6/stable [all])
Conf libglib2.0-dev-bin (2.58.3-2+deb10u2 Debian:10.6/stable [amd64])
Conf libblkid-dev (2.33.1-0.1 Debian:10.6/stable [amd64])
Conf libmount-dev (2.33.1-0.1 Debian:10.6/stable [amd64])
Conf libpcre32-3 (2:8.39-12 Debian:10.6/stable [amd64])
Conf libpcrecpp0v5 (2:8.39-12 Debian:10.6/stable [amd64])
Conf libpcre3-dev (2:8.39-12 Debian:10.6/stable [amd64])
Conf libsepol1-dev (2.8-1 Debian:10.6/stable [amd64])
Conf libselinux1-dev (2.8-1+b1 Debian:10.6/stable [amd64])
Conf libglib2.0-dev (2.58.3-2+deb10u2 Debian:10.6/stable [amd64])
Conf libartsc0-trinity-dev (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Conf libasound2-dev (1.1.8-1 Debian:10.6/stable [amd64])
Conf libaudiofile-dev (0.3.6-5 Debian:10.6/stable [amd64])
Conf libogg-dev (1.3.2-1+b1 Debian:10.6/stable [amd64])
Conf libvorbis-dev (1.3.6-2 Debian:10.6/stable [amd64])
Conf libmad0-dev (0.15.1b-10 Debian:10.6/stable [amd64])
Conf libtqtinterface-dev (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Conf libarts1-trinity-dev (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Conf libaspell-dev (0.60.7~20110707-6 Debian:10.6/stable [amd64])
Conf libavahi-common-dev (0.7-4+b1 Debian:10.6/stable [amd64])
Conf libdbus-1-dev (1.12.20-0+deb10u1 Debian:10.6/stable [amd64])
Conf libavahi-client-dev (0.7-4+b1 Debian:10.6/stable [amd64])
Conf libbz2-dev (1.0.6-9.2~deb10u1 Debian:10.6/stable [amd64])
Conf libc6-dbg (2.28-10 Debian:10.6/stable [amd64])
Conf libcupsfilters-dev (1.21.6-5 Debian:10.6/stable [amd64])
Conf libdbus-1-tqt-dev (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Conf libfontenc-dev (1:1.1.3-1+b2 Debian:10.6/stable [amd64])
Conf libgts-bin (0.7.6+darcs121130-4 Debian:10.6/stable [amd64])
Conf libicu-dev (63.1-6+deb10u1 Debian:10.6/stable, Debian-Security:10/stable [amd64])
Conf libidn11-dev (1.33-2.2 Debian:10.6/stable [amd64])
Conf libilmbase-dev (2.2.1-2 Debian:10.6/stable [amd64])
Conf libjasper-dev (1.900.1-debian1-2.5debian10.0.0+5~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Conf libkrb5-dev (1.17-3 Debian:10.6/stable [amd64])
Conf libltdl-dev (2.4.6-9 Debian:10.6/stable [amd64])
Conf liblua50 (5.0.3-8+b1 Debian:10.6/stable [amd64])
Conf liblualib50 (5.0.3-8+b1 Debian:10.6/stable [amd64])
Conf lua50 (5.0.3-8+b1 Debian:10.6/stable [amd64])
Conf liblua50-dev (5.0.3-8+b1 Debian:10.6/stable [amd64])
Conf liblualib50-dev (5.0.3-8+b1 Debian:10.6/stable [amd64])
Conf libmbim-glib4 (1.18.0-1 Debian:10.6/stable [amd64])
Conf libmbim-proxy (1.18.0-1 Debian:10.6/stable [amd64])
Conf libncurses-dev (6.1+20181013-2+deb10u2 Debian:10.6/stable [amd64])
Conf libomp5-7 (1:7.0.1-8+deb10u2 Debian:10.6/stable [amd64])
Conf libomp-7-dev (1:7.0.1-8+deb10u2 Debian:10.6/stable [amd64])
Conf libopenexr-dev (2.2.1-4.1+deb10u1 Debian:10.6/stable, Debian-Security:10/stable [amd64])
Conf libpciaccess-dev (0.14-1 Debian:10.6/stable [amd64])
Conf libpixman-1-dev (0.36.0-1 Debian:10.6/stable [amd64])
Conf libpng-tools (1.6.36-6 Debian:10.6/stable [amd64])
Conf qbs-common (1.12.2+dfsg-2 Debian:10.6/stable [all])
Conf libqbscore1.12 (1.12.2+dfsg-2 Debian:10.6/stable [amd64])
Conf libqbsqtprofilesetup1.12 (1.12.2+dfsg-2 Debian:10.6/stable [amd64])
Conf libqmi-glib5 (1.22.0-1.2 Debian:10.6/stable [amd64])
Conf libqmi-proxy (1.22.0-1.2 Debian:10.6/stable [amd64])
Conf libqt5designer5 (5.11.3-4 Debian:10.6/stable [amd64])
Conf libqt5designercomponents5 (5.11.3-4 Debian:10.6/stable [amd64])
Conf libqt5help5 (5.11.3-4 Debian:10.6/stable [amd64])
Conf libqt5quicktest5 (5.11.3-4 Debian:10.6/stable [amd64])
Conf libqt5quickwidgets5 (5.11.3-4 Debian:10.6/stable [amd64])
Conf libqt5serialport5 (5.11.3-2 Debian:10.6/stable [amd64])
Conf libqt5xmlpatterns5 (5.11.3-2 Debian:10.6/stable [amd64])
Conf libsasl2-dev (2.1.27+dfsg-1+deb10u1 Debian:10.6/stable, Debian-Security:10/stable [amd64])
Conf libssl-dev (1.1.1d-0+deb10u3 Debian:10.6/stable, Debian-Security:10/stable [amd64])
Conf libtinfo-dev (6.1+20181013-2+deb10u2 Debian:10.6/stable [amd64])
Conf libtool (2.4.6-9 Debian:10.6/stable [all])
Conf libtqt3-compat-headers (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Conf libudev-dev (241-7~deb10u4 Debian:10.6/stable [amd64])
Conf x11proto-composite-dev (1:2018.4-4 Debian:10.6/stable [all])
Conf libxcomposite-dev (1:0.4.4-2 Debian:10.6/stable [amd64])
Conf libxfont-dev (1:2.0.3-1 Debian:10.6/stable [amd64])
Conf libxkbfile-dev (1:1.0.9-2+b11 Debian:10.6/stable [amd64])
Conf libxml2-dev (2.9.4+dfsg1-7+b3 Debian:10.6/stable [amd64])
Conf libxml2-utils (2.9.4+dfsg1-7+b3 Debian:10.6/stable [amd64])
Conf libxslt1-dev (1.1.32-2.2~deb10u1 Debian:10.6/stable [amd64])
Conf llvm-7-runtime (1:7.0.1-8+deb10u2 Debian:10.6/stable [amd64])
Conf llvm-7 (1:7.0.1-8+deb10u2 Debian:10.6/stable [amd64])
Conf llvm-7-dev (1:7.0.1-8+deb10u2 Debian:10.6/stable [amd64])
Conf mc-data (3:4.8.22-1 Debian:10.6/stable [all])
Conf mc (3:4.8.22-1 Debian:10.6/stable [amd64])
Conf modemmanager (1.10.0-1 Debian:10.6/stable [amd64])
Conf qdoc-qt5 (5.11.3-4 Debian:10.6/stable [amd64])
Conf qml-module-qtqml-models2 (5.11.3-4 Debian:10.6/stable [amd64])
Conf qmlscene (5.11.3-4 Debian:10.6/stable [amd64])
Conf qt3d5-doc (5.11.3+dfsg-2 Debian:10.6/stable [all])
Conf qt5-assistant (5.11.3-4 Debian:10.6/stable [amd64])
Conf qt5-qmltooling-plugins (5.11.3-4 Debian:10.6/stable [amd64])
Conf qtbase5-dev-tools (5.11.3+dfsg1-1+deb10u4 Debian:10.6/stable [amd64])
Conf qtbase5-doc (5.11.3+dfsg1-1+deb10u4 Debian:10.6/stable [all])
Conf qtcharts5-doc (5.11.3-2 Debian:10.6/stable [all])
Conf qtconnectivity5-doc (5.11.3-2 Debian:10.6/stable [all])
Conf qtcreator-data (4.8.2-1 Debian:10.6/stable [all])
Conf qtcreator (4.8.2-1 Debian:10.6/stable [amd64])
Conf qtcreator-doc (4.8.2-1 Debian:10.6/stable [all])
Conf qtdeclarative5-dev-tools (5.11.3-4 Debian:10.6/stable [amd64])
Conf qtdeclarative5-doc (5.11.3-4 Debian:10.6/stable [all])
Conf qtgraphicaleffects5-doc (5.11.3-2 Debian:10.6/stable [all])
Conf qtlocation5-doc (5.11.3+dfsg-2 Debian:10.6/stable [all])
Conf qtmultimedia5-doc (5.11.3-2 Debian:10.6/stable [all])
Conf qtquickcontrols2-5-doc (5.11.3+dfsg-2 Debian:10.6/stable [all])
Conf qtquickcontrols5-doc (5.11.3-2 Debian:10.6/stable [all])
Conf qtscript5-doc (5.11.3+dfsg-3 Debian:10.6/stable [all])
Conf qtsensors5-doc (5.11.3-2 Debian:10.6/stable [all])
Conf qtserialport5-doc (5.11.3-2 Debian:10.6/stable [all])
Conf qtsvg5-doc (5.11.3-2 Debian:10.6/stable [all])
Conf qttools5-dev-tools (5.11.3-4 Debian:10.6/stable [amd64])
Conf qttools5-doc (5.11.3-4 Debian:10.6/stable [all])
Conf qtvirtualkeyboard5-doc (5.11.3+dfsg-2 Debian:10.6/stable [all])
Conf qtwayland5-doc (5.11.3-2 Debian:10.6/stable [all])
Conf qtwebchannel5-doc (5.11.3-2 Debian:10.6/stable [all])
Conf qtwebengine5-doc (5.11.3+dfsg-2+deb10u1 Debian:10.6/stable [all])
Conf qtwebsockets5-doc (5.11.3-5 Debian:10.6/stable [all])
Conf qtwebview5-doc (5.11.3-2 Debian:10.6/stable [all])
Conf qtx11extras5-doc (5.11.3-2 Debian:10.6/stable [all])
Conf qtxmlpatterns5-dev-tools (5.11.3-2 Debian:10.6/stable [amd64])
Conf qtxmlpatterns5-doc (5.11.3-2 Debian:10.6/stable [all])
Conf reprepro (5.3.0-1 Debian:10.6/stable [amd64])
Testing installation ... Done
Downloading packages ...
Conf tdecachegrind-trinity (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Conf libr-dev (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Conf tdelibs14-trinity-dev (4:14.0.6-0debian10.0.0+0~a.2 Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Conf tdevelop-trinity-doc (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [all])
Conf tqt3-doc (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [all])
Conf tqt3-assistant (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Conf tqt3-designer (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Conf tqt3-linguist (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Conf tqt3-qtconfig (4:14.0.6-0debian10.0.0+0~a Q4OS TDE repository:10.0/qtde-buster-st [amd64])
Conf valgrind (1:3.14.0-3 Debian:10.6/stable [amd64])
Conf valgrind-dbg (1:3.14.0-3 Debian:10.6/stable [amd64])
Conf xfonts-terminus (4.40-2 Debian:10.6/stable [all])
Conf xserver-xorg-dev (2:1.20.4-1+deb10u1 Debian:10.6/stable, Debian-Security:10/stable [amd64])
Conf q4os-devpack (3.3.1-a1 localhost [all])
Conf qt5-doc (5.11.3-1 Debian:10.6/stable [all])
Suggested packages:
Need to get 425 MB/425 MB of archives.
After this operation, 1,173 MB of additional disk space will be used.
0% [Working]
Get:1 copy:/tmp/tmp.7YtraK9d9q-q4appsetup tmp-setup-repo/ checkinstall 1.6.2+git20170426.d24a630-2~bpo10+1 [114 kB]
0% [1 checkinstall 0 B/114 kB 0%]
0% [Working]
Get:2 copy:/tmp/tmp.7YtraK9d9q-q4appsetup tmp-setup-repo/ q4os-devpack 3.3.1-a1 [79.5 kB]
0% [2 q4os-devpack 0 B/79.5 kB 0%]
0% [Working]
Get:3 http://ftp.debian.org/debian buster/main amd64 libqt5positioning5 amd64 5.11.3+dfsg-2 [191 kB]
0% [3 libqt5positioning5 6,772 B/191 kB 4%] [Connecting to q4os.org (81.95.96.2
0% [3 libqt5positioning5 83.5 kB/191 kB 44%]
0% [Waiting for headers]
0% [Waiting for headers] [Waiting for headers]
Get:14 http://ftp.debian.org/debian buster/main amd64 libqt5quick5 amd64 5.11.3-4 [1,278 kB]
0% [Connecting to q4os.org] [14 libqt5quick5 2,464 B/1,278 kB 0%] [Waiting for
0% [Connecting to q4os.org (81.95.96.231)] [14 libqt5quick5 224 kB/1,278 kB 18%
1% [Connected to q4os.org (81.95.96.231)] [14 libqt5quick5 1,062 kB/1,278 kB 83
1% [Connected to q4os.org (81.95.96.231)] [Waiting for headers]
Get:32 http://ftp.debian.org/debian buster/main amd64 libqt5sensors5 amd64 5.11.3-2 [116 kB]
1% [Connected to q4os.org (81.95.96.231)] [32 libqt5sensors5 8,174 B/116 kB 7%]
Get:33 http://ftp.debian.org/debian buster/main amd64 libqt5webchannel5 amd64 5.11.3-2 [48.8 kB]
1% [Connected to q4os.org (81.95.96.231)] [33 libqt5webchannel5 4,522 B/48.8 kB
Get:34 http://ftp.debian.org/debian buster/main amd64 libqt5webkit5 amd64 5.212.0~alpha2-21 [11.7 MB]
1% [Connected to q4os.org (81.95.96.231)] [34 libqt5webkit5 4,493 B/11.7 MB 0%]
Get:4 https://q4os.org/qtderepo buster/main amd64 libcvsservice0-trinity amd64 4:14.0.6-0debian10.0.0+0~a [94.0 kB]
1% [4 libcvsservice0-trinity 16.0 kB/94.0 kB 17%] [34 libqt5webkit5 2,142 kB/11
2% [34 libqt5webkit5 5,037 kB/11.7 MB 43%]
Get:5 https://q4os.org/qtderepo buster/main amd64 tdevelop-data-trinity all 4:14.0.6-0debian10.0.0+0~a [2,426 kB]
3% [5 tdevelop-data-trinity 36.4 kB/2,426 kB 2%] [34 libqt5webkit5 8,854 kB/11.
3% [5 tdevelop-data-trinity 180 kB/2,426 kB 7%] [Waiting for headers]
Get:35 http://ftp.debian.org/debian buster/main amd64 qml-module-qtquick-window2 amd64 5.11.3-4 [32.2 kB]
3% [5 tdevelop-data-trinity 180 kB/2,426 kB 7%] [35 qml-module-qtquick-window2
Get:36 http://ftp.debian.org/debian buster/main amd64 qml-module-qtquick2 amd64 5.11.3-4 [45.6 kB]
3% [5 tdevelop-data-trinity 180 kB/2,426 kB 7%] [36 qml-module-qtquick2 17.7 kB
Get:37 http://ftp.debian.org/debian buster/main amd64 qml-module-qtgraphicaleffects amd64 5.11.3-2 [71.3 kB]
3% [5 tdevelop-data-trinity 196 kB/2,426 kB 8%] [37 qml-module-qtgraphicaleffec
4% [5 tdevelop-data-trinity 196 kB/2,426 kB 8%] [Waiting for headers]
Get:38 http://ftp.debian.org/debian buster/main amd64 qml-module-qtquick-layouts amd64 5.11.3-4 [58.5 kB]
4% [5 tdevelop-data-trinity 196 kB/2,426 kB 8%] [38 qml-module-qtquick-layouts
Get:39 http://ftp.debian.org/debian buster/main amd64 qml-module-qtquick-controls amd64 5.11.3-2 [653 kB]
4% [5 tdevelop-data-trinity 196 kB/2,426 kB 8%] [39 qml-module-qtquick-controls
4% [5 tdevelop-data-trinity 213 kB/2,426 kB 9%] [Waiting for headers]
Get:40 http://ftp.debian.org/debian buster/main amd64 binfmt-support amd64 2.2.0-2 [70.0 kB]
4% [5 tdevelop-data-trinity 213 kB/2,426 kB 9%] [40 binfmt-support 8,192 B/70.0
Get:41 http://ftp.debian.org/debian buster/main amd64 binutils-dev amd64 2.31.1-16 [2,496 kB]
4% [5 tdevelop-data-trinity 213 kB/2,426 kB 9%] [41 binutils-dev 6,485 B/2,496
5% [5 tdevelop-data-trinity 245 kB/2,426 kB 10%] [Waiting for headers]
Get:42 http://ftp.debian.org/debian buster/main amd64 bzip2-doc all 1.0.6-9.2~deb10u1 [493 kB]
5% [5 tdevelop-data-trinity 245 kB/2,426 kB 10%] [42 bzip2-doc 28.3 kB/493 kB 6
5% [5 tdevelop-data-trinity 278 kB/2,426 kB 11%] [Waiting for headers]
Get:43 http://ftp.debian.org/debian buster/main amd64 libobjc-8-dev amd64 8.3.0-6 [226 kB]
5% [5 tdevelop-data-trinity 278 kB/2,426 kB 11%] [43 libobjc-8-dev 59.5 kB/226
Get:44 http://ftp.debian.org/debian buster/main amd64 libc6-i386 amd64 2.28-10 [2,872 kB]
5% [5 tdevelop-data-trinity 278 kB/2,426 kB 11%] [44 libc6-i386 30.0 kB/2,872 k
5% [5 tdevelop-data-trinity 327 kB/2,426 kB 13%] [Waiting for headers]
Get:45 http://ftp.debian.org/debian buster/main amd64 lib32gcc1 amd64 1:8.3.0-6 [47.9 kB]
5% [5 tdevelop-data-trinity 327 kB/2,426 kB 13%] [45 lib32gcc1 4,785 B/47.9 kB
6% [5 tdevelop-data-trinity 344 kB/2,426 kB 14%]
Get:46 http://ftp.debian.org/debian buster/main amd64 lib32stdc++6 amd64 8.3.0-6 [407 kB]
6% [5 tdevelop-data-trinity 344 kB/2,426 kB 14%] [46 lib32stdc++6 58.9 kB/407 k
6% [5 tdevelop-data-trinity 376 kB/2,426 kB 16%] [Waiting for headers]
Get:47 http://ftp.debian.org/debian buster/main amd64 libclang-common-7-dev amd64 1:7.0.1-8+deb10u2 [3,158 kB]
6% [5 tdevelop-data-trinity 376 kB/2,426 kB 16%] [47 libclang-common-7-dev 44.7
6% [5 tdevelop-data-trinity 409 kB/2,426 kB 17%] [Waiting for headers]
Get:48 http://ftp.debian.org/debian buster/main amd64 libclang1-7 amd64 1:7.0.1-8+deb10u2 [5,997 kB]
6% [5 tdevelop-data-trinity 409 kB/2,426 kB 17%] [48 libclang1-7 5,307 B/5,997
7% [5 tdevelop-data-trinity 458 kB/2,426 kB 19%] [48 libclang1-7 4,458 kB/5,997
8% [5 tdevelop-data-trinity 475 kB/2,426 kB 20%] [Waiting for headers]
Get:49 http://ftp.debian.org/debian buster/main amd64 clang-7 amd64 1:7.0.1-8+deb10u2 [7,891 kB]
8% [5 tdevelop-data-trinity 524 kB/2,426 kB 22%] [49 clang-7 4,787 kB/7,891 kB
9% [5 tdevelop-data-trinity 557 kB/2,426 kB 23%] [Waiting for headers]
Get:50 http://ftp.debian.org/debian buster/main amd64 clang amd64 1:7.0-47 [7,468 B]
Get:51 http://ftp.debian.org/debian buster/main amd64 cmake-data all 3.13.4-1 [1,476 kB]
9% [5 tdevelop-data-trinity 557 kB/2,426 kB 23%] [51 cmake-data 29.3 kB/1,476 k
10% [5 tdevelop-data-trinity 557 kB/2,426 kB 23%] [Waiting for headers]
Get:52 http://ftp.debian.org/debian buster/main amd64 librhash0 amd64 1.3.8-1 [122 kB]
10% [5 tdevelop-data-trinity 557 kB/2,426 kB 23%] [52 librhash0 5,110 B/122 kB
Get:53 http://ftp.debian.org/debian buster/main amd64 libuv1 amd64 1.24.1-1 [110 kB]
10% [5 tdevelop-data-trinity 557 kB/2,426 kB 23%] [53 libuv1 3,864 B/110 kB 4%]
Get:54 http://ftp.debian.org/debian buster/main amd64 cmake amd64 3.13.4-1 [3,480 kB]
10% [5 tdevelop-data-trinity 557 kB/2,426 kB 23%] [54 cmake 3,612 B/3,480 kB 0%
11% [5 tdevelop-data-trinity 622 kB/2,426 kB 26%] [Waiting for headers]
Get:55 http://ftp.debian.org/debian buster/main amd64 comerr-dev amd64 2.1-1.44.5-1+deb10u3 [102 kB]
11% [5 tdevelop-data-trinity 622 kB/2,426 kB 26%] [55 comerr-dev 15.8 kB/102 kB
Get:56 http://ftp.debian.org/debian buster/main amd64 cvs amd64 2:1.12.13+real-27 [2,799 kB]
11% [5 tdevelop-data-trinity 622 kB/2,426 kB 26%] [56 cvs 44.3 kB/2,799 kB 2%]
11% [5 tdevelop-data-trinity 688 kB/2,426 kB 28%] [Waiting for headers]
Get:57 http://ftp.debian.org/debian buster/main amd64 libdw1 amd64 0.176-1.1 [235 kB]
11% [5 tdevelop-data-trinity 688 kB/2,426 kB 28%] [57 libdw1 62.5 kB/235 kB 27%
Get:58 http://ftp.debian.org/debian buster/main amd64 libbabeltrace1 amd64 1.5.6-2+deb10u1 [172 kB]
11% [5 tdevelop-data-trinity 688 kB/2,426 kB 28%] [58 libbabeltrace1 23.7 kB/17
Get:59 http://ftp.debian.org/debian buster/main amd64 libipt2 amd64 2.0-2 [41.7 kB]
11% [5 tdevelop-data-trinity 688 kB/2,426 kB 28%] [59 libipt2 2,344 B/41.7 kB 6
12% [5 tdevelop-data-trinity 688 kB/2,426 kB 28%] [Waiting for headers]
Get:60 http://ftp.debian.org/debian buster/main amd64 gdb amd64 8.2.1-2+b3 [3,133 kB]
12% [5 tdevelop-data-trinity 688 kB/2,426 kB 28%] [60 gdb 24.6 kB/3,133 kB 1%]
12% [5 tdevelop-data-trinity 721 kB/2,426 kB 30%] [Waiting for headers]
Get:61 http://ftp.debian.org/debian buster/main amd64 geoclue-2.0 amd64 2.5.2-1 [95.2 kB]
12% [5 tdevelop-data-trinity 721 kB/2,426 kB 30%] [61 geoclue-2.0 5,459 B/95.2
12% [5 tdevelop-data-trinity 737 kB/2,426 kB 30%] 7,332 kB/s 51s
Get:62 http://ftp.debian.org/debian buster/main amd64 gettext amd64 0.19.8.1-9 [1,303 kB]
12% [5 tdevelop-data-trinity 737 kB/2,426 kB 30%] [62 gettext 3,899 B/1,303 kB
13% [5 tdevelop-data-trinity 753 kB/2,426 kB 31%] [Waiting for headers]
Get:63 http://ftp.debian.org/debian buster/main amd64 libcdt5 amd64 2.40.1-6 [60.6 kB]
13% [5 tdevelop-data-trinity 753 kB/2,426 kB 31%] [63 libcdt5 60.6 kB/60.6 kB 1
13% [5 tdevelop-data-trinity 753 kB/2,426 kB 31%] 7,332 kB/s 50s
Get:64 http://ftp.debian.org/debian buster/main amd64 libcgraph6 amd64 2.40.1-6 [84.1 kB]
13% [5 tdevelop-data-trinity 753 kB/2,426 kB 31%] [64 libcgraph6 65.2 kB/84.1 k
Get:65 http://ftp.debian.org/debian buster/main amd64 libgts-0.7-5 amd64 0.7.6+darcs121130-4 [158 kB]
13% [5 tdevelop-data-trinity 753 kB/2,426 kB 31%] [65 libgts-0.7-5 46.2 kB/158
Get:66 http://ftp.debian.org/debian buster/main amd64 libpathplan4 amd64 2.40.1-6 [63.5 kB]
13% [5 tdevelop-data-trinity 753 kB/2,426 kB 31%] [66 libpathplan4 19.2 kB/63.5
Get:67 http://ftp.debian.org/debian buster/main amd64 libxdot4 amd64 2.40.1-6 [56.9 kB]
13% [5 tdevelop-data-trinity 753 kB/2,426 kB 31%] [67 libxdot4 20.9 kB/56.9 kB
Get:68 http://ftp.debian.org/debian buster/main amd64 libgvc6 amd64 2.40.1-6 [646 kB]
13% [5 tdevelop-data-trinity 753 kB/2,426 kB 31%] [68 libgvc6 29.0 kB/646 kB 4%
13% [5 tdevelop-data-trinity 770 kB/2,426 kB 32%] [Waiting for headers]
Get:69 http://ftp.debian.org/debian buster/main amd64 libgvpr2 amd64 2.40.1-6 [213 kB]
13% [5 tdevelop-data-trinity 770 kB/2,426 kB 32%] [69 libgvpr2 3,714 B/213 kB 2
Get:70 http://ftp.debian.org/debian buster/main amd64 liblab-gamut1 amd64 2.40.1-6 [220 kB]
13% [5 tdevelop-data-trinity 770 kB/2,426 kB 32%] [70 liblab-gamut1 10.2 kB/220
14% [5 tdevelop-data-trinity 770 kB/2,426 kB 32%] [Waiting for headers]
Get:71 http://ftp.debian.org/debian buster/main amd64 graphviz amd64 2.40.1-6 [594 kB]
14% [5 tdevelop-data-trinity 770 kB/2,426 kB 32%] [71 graphviz 2,662 B/594 kB 0
14% [5 tdevelop-data-trinity 802 kB/2,426 kB 33%] [Waiting for headers]
Get:72 http://ftp.debian.org/debian buster/main amd64 hspell amd64 1.4-3 [939 kB]
14% [5 tdevelop-data-trinity 802 kB/2,426 kB 33%] [72 hspell 58.0 kB/939 kB 6%]
Get:73 http://ftp.debian.org/debian buster/main amd64 icu-devtools amd64 63.1-6+deb10u1 [189 kB]
14% [5 tdevelop-data-trinity 802 kB/2,426 kB 33%] [73 icu-devtools 35.9 kB/189
Get:74 http://ftp.debian.org/debian buster/main amd64 libapr1 amd64 1.6.5-1+b1 [102 kB]
14% [5 tdevelop-data-trinity 802 kB/2,426 kB 33%] [74 libapr1 43.5 kB/102 kB 43
Get:75 http://ftp.debian.org/debian buster/main amd64 libaprutil1 amd64 1.6.1-4 [91.8 kB]
14% [5 tdevelop-data-trinity 802 kB/2,426 kB 33%] [75 libaprutil1 53.2 kB/91.8
14% [5 tdevelop-data-trinity 802 kB/2,426 kB 33%] 7,332 kB/s 50s
Get:76 http://ftp.debian.org/debian buster/main amd64 libserf-1-1 amd64 1.3.9-7+b10 [53.6 kB]
14% [5 tdevelop-data-trinity 802 kB/2,426 kB 33%] [76 libserf-1-1 45.5 kB/53.6
Get:77 http://ftp.debian.org/debian buster/main amd64 libutf8proc2 amd64 2.3.0-1 [53.0 kB]
14% [5 tdevelop-data-trinity 802 kB/2,426 kB 33%] [77 libutf8proc2 53.0 kB/53.0
Get:78 http://ftp.debian.org/debian buster/main amd64 libsvn1 amd64 1.10.4-1+deb10u1 [1,402 kB]
14% [5 tdevelop-data-trinity 802 kB/2,426 kB 33%] [78 libsvn1 65.5 kB/1,402 kB
15% [5 tdevelop-data-trinity 819 kB/2,426 kB 34%] [Waiting for headers]
Get:79 http://ftp.debian.org/debian buster/main amd64 x11proto-randr-dev all 2018.4-4 [3,132 B]
Get:80 http://ftp.debian.org/debian buster/main amd64 libxrender-dev amd64 1:0.9.10-1 [40.8 kB]
15% [5 tdevelop-data-trinity 819 kB/2,426 kB 34%] [80 libxrender-dev 8,729 B/40
Get:81 http://ftp.debian.org/debian buster/main amd64 libxrandr-dev amd64 2:1.5.1-1 [45.0 kB]
15% [5 tdevelop-data-trinity 819 kB/2,426 kB 34%] [81 libxrandr-dev 3,137 B/45.
Get:82 http://ftp.debian.org/debian buster/main amd64 libice-dev amd64 2:1.0.9-2 [66.8 kB]
15% [5 tdevelop-data-trinity 852 kB/2,426 kB 35%] [82 libice-dev 5,363 B/66.8 k
15% [5 tdevelop-data-trinity 852 kB/2,426 kB 35%] [Waiting for headers]
Get:83 http://ftp.debian.org/debian buster/main amd64 libsm-dev amd64 2:1.2.3-1 [38.0 kB]
15% [5 tdevelop-data-trinity 852 kB/2,426 kB 35%] [83 libsm-dev 3,313 B/38.0 kB
Get:84 http://ftp.debian.org/debian buster/main amd64 libxt-dev amd64 1:1.1.5-1+b3 [426 kB]
15% [5 tdevelop-data-trinity 852 kB/2,426 kB 35%] [84 libxt-dev 5,471 B/426 kB
15% [5 tdevelop-data-trinity 868 kB/2,426 kB 36%] 7,332 kB/s 50s
Get:85 http://ftp.debian.org/debian buster/main amd64 libxmu-headers all 2:1.1.2-2 [51.9 kB]
15% [5 tdevelop-data-trinity 868 kB/2,426 kB 36%] [85 libxmu-headers 8,607 B/51
15% [5 tdevelop-data-trinity 868 kB/2,426 kB 36%] [Waiting for headers]
Get:86 http://ftp.debian.org/debian buster/main amd64 libxmu-dev amd64 2:1.1.2-2+b3 [66.3 kB]
15% [5 tdevelop-data-trinity 868 kB/2,426 kB 36%] [86 libxmu-dev 6,920 B/66.3 k
16% [5 tdevelop-data-trinity 868 kB/2,426 kB 36%] [Waiting for headers]
Get:87 http://ftp.debian.org/debian buster/main amd64 x11proto-fixes-dev all 1:2018.4-4 [3,140 B]
Get:88 http://ftp.debian.org/debian buster/main amd64 libxfixes-dev amd64 1:5.0.3-1 [23.8 kB]
16% [5 tdevelop-data-trinity 868 kB/2,426 kB 36%] [88 libxfixes-dev 2,468 B/23.
Get:89 http://ftp.debian.org/debian buster/main amd64 libxcursor-dev amd64 1:1.1.15-2 [44.1 kB]
16% [5 tdevelop-data-trinity 868 kB/2,426 kB 36%] [89 libxcursor-dev 4,322 B/44
Get:90 http://ftp.debian.org/debian buster/main amd64 uuid-dev amd64 2.33.1-0.1 [93.6 kB]
16% [5 tdevelop-data-trinity 868 kB/2,426 kB 36%] [90 uuid-dev 6,133 B/93.6 kB
Get:91 http://ftp.debian.org/debian buster/main amd64 x11proto-xinerama-dev all 2018.4-4 [3,132 B]
16% [5 tdevelop-data-trinity 868 kB/2,426 kB 36%] [91 x11proto-xinerama-dev 3,1
Get:92 http://ftp.debian.org/debian buster/main amd64 libxinerama-dev amd64 2:1.1.4-2 [20.1 kB]
16% [5 tdevelop-data-trinity 884 kB/2,426 kB 36%] [92 libxinerama-dev 2,468 B/2
16% [5 tdevelop-data-trinity 884 kB/2,426 kB 36%] 7,332 kB/s 50s
Get:93 http://ftp.debian.org/debian buster/main amd64 x11proto-input-dev all 2018.4-4 [3,132 B]
16% [5 tdevelop-data-trinity 884 kB/2,426 kB 36%] [Waiting for headers]
Get:94 http://ftp.debian.org/debian buster/main amd64 libxi-dev amd64 2:1.7.9-1 [241 kB]
16% [5 tdevelop-data-trinity 884 kB/2,426 kB 36%] [94 libxi-dev 5,940 B/241 kB
Get:95 http://ftp.debian.org/debian buster/main amd64 zlib1g-dev amd64 1:1.2.11.dfsg-1 [214 kB]
16% [5 tdevelop-data-trinity 884 kB/2,426 kB 36%] [95 zlib1g-dev 2,382 B/214 kB
16% [5 tdevelop-data-trinity 901 kB/2,426 kB 37%] [Waiting for headers]
Get:96 http://ftp.debian.org/debian buster/main amd64 libjpeg62-turbo-dev amd64 1:1.5.2-2+b1 [208 kB]
16% [5 tdevelop-data-trinity 901 kB/2,426 kB 37%] [96 libjpeg62-turbo-dev 3,712
17% [5 tdevelop-data-trinity 901 kB/2,426 kB 37%] [Waiting for headers]
Get:97 http://ftp.debian.org/debian buster/main amd64 libjpeg-dev all 1:1.5.2-2 [57.5 kB]
17% [5 tdevelop-data-trinity 901 kB/2,426 kB 37%] [97 libjpeg-dev 3,700 B/57.5
Get:98 http://ftp.debian.org/debian buster/main amd64 liblcms2-dev amd64 2.9-3 [9,102 kB]
17% [5 tdevelop-data-trinity 917 kB/2,426 kB 38%] [98 liblcms2-dev 3,912 B/9,10
18% [5 tdevelop-data-trinity 1,048 kB/2,426 kB 43%] [98 liblcms2-dev 9,080 kB/9
18% [5 tdevelop-data-trinity 1,048 kB/2,426 kB 43%] [Waiting for headers]
Get:99 http://ftp.debian.org/debian buster/main amd64 libmng-dev amd64 1.0.10+dfsg-3.1+b5 [274 kB]
18% [5 tdevelop-data-trinity 1,048 kB/2,426 kB 43%] [99 libmng-dev 30.4 kB/274
19% [5 tdevelop-data-trinity 1,048 kB/2,426 kB 43%] [Waiting for headers]
Get:100 http://ftp.debian.org/debian buster/main amd64 libpng-dev amd64 1.6.36-6 [300 kB]
19% [5 tdevelop-data-trinity 1,048 kB/2,426 kB 43%] [100 libpng-dev 2,884 B/300
19% [5 tdevelop-data-trinity 1,065 kB/2,426 kB 44%] [Waiting for headers]
Get:101 http://ftp.debian.org/debian buster/main amd64 libexpat1-dev amd64 2.2.6-2+deb10u1 [153 kB]
19% [5 tdevelop-data-trinity 1,065 kB/2,426 kB 44%] [101 libexpat1-dev 4,842 B/
Get:102 http://ftp.debian.org/debian buster/main amd64 libfreetype6-dev amd64 2.9.1-3+deb10u1 [544 kB]
19% [5 tdevelop-data-trinity 1,065 kB/2,426 kB 44%] [102 libfreetype6-dev 756 B
Get:103 http://ftp.debian.org/debian buster/main amd64 pkg-config amd64 0.29-6 [63.5 kB]
19% [5 tdevelop-data-trinity 1,065 kB/2,426 kB 44%] [103 pkg-config 63.5 kB/63.
19% [5 tdevelop-data-trinity 1,065 kB/2,426 kB 44%] 7,332 kB/s 48s
Get:104 http://ftp.debian.org/debian buster/main amd64 libfontconfig1-dev amd64 2.13.1-2 [966 kB]
19% [5 tdevelop-data-trinity 1,065 kB/2,426 kB 44%] [104 libfontconfig1-dev 45.
Get:105 http://ftp.debian.org/debian buster/main amd64 libxft-dev amd64 2.3.2-2 [68.7 kB]
19% [5 tdevelop-data-trinity 1,065 kB/2,426 kB 44%] [105 libxft-dev 21.5 kB/68.
Get:106 http://ftp.debian.org/debian buster/main amd64 libaudio-dev amd64 1.9.4-6 [277 kB]
19% [5 tdevelop-data-trinity 1,065 kB/2,426 kB 44%] [106 libaudio-dev 17.9 kB/2
20% [5 tdevelop-data-trinity 1,081 kB/2,426 kB 45%] [Waiting for headers]
Get:107 http://ftp.debian.org/debian buster/main amd64 libjbig-dev amd64 2.1-3.1+b2 [30.5 kB]
20% [5 tdevelop-data-trinity 1,081 kB/2,426 kB 45%] [107 libjbig-dev 4,275 B/30
Get:108 http://ftp.debian.org/debian buster/main amd64 liblzma-dev amd64 5.2.4-1 [210 kB]
20% [5 tdevelop-data-trinity 1,081 kB/2,426 kB 45%] [108 liblzma-dev 2,337 B/21
Get:109 http://ftp.debian.org/debian buster/main amd64 libtiffxx5 amd64 4.1.0+git191117-2~deb10u1 [117 kB]
20% [5 tdevelop-data-trinity 1,081 kB/2,426 kB 45%] [109 libtiffxx5 1,599 B/117
20% [5 tdevelop-data-trinity 1,097 kB/2,426 kB 45%] [Waiting for headers]
Get:110 http://ftp.debian.org/debian buster/main amd64 libtiff-dev amd64 4.1.0+git191117-2~deb10u1 [394 kB]
20% [5 tdevelop-data-trinity 1,097 kB/2,426 kB 45%] [110 libtiff-dev 2,466 B/39
Get:111 http://ftp.debian.org/debian buster/main amd64 libcupsimage2-dev amd64 2.2.10-6+deb10u3 [20.7 kB]
20% [5 tdevelop-data-trinity 1,097 kB/2,426 kB 45%] [111 libcupsimage2-dev 3,67
Get:112 http://ftp.debian.org/debian buster/main amd64 libcups2-dev amd64 2.2.10-6+deb10u3 [369 kB]
20% [5 tdevelop-data-trinity 1,097 kB/2,426 kB 45%] [112 libcups2-dev 4,216 B/3
20% [5 tdevelop-data-trinity 1,114 kB/2,426 kB 46%] [Waiting for headers]
Get:113 http://ftp.debian.org/debian buster/main amd64 libdrm-dev amd64 2.4.97-1 [131 kB]
20% [5 tdevelop-data-trinity 1,114 kB/2,426 kB 46%] [113 libdrm-dev 2,874 B/131
20% [5 tdevelop-data-trinity 1,114 kB/2,426 kB 46%] 7,332 kB/s 48s
Get:114 http://ftp.debian.org/debian buster/main amd64 mesa-common-dev amd64 18.3.6-2+deb10u1 [611 kB]
20% [5 tdevelop-data-trinity 1,114 kB/2,426 kB 46%] [114 mesa-common-dev 3,300
21% [5 tdevelop-data-trinity 1,147 kB/2,426 kB 47%] [Waiting for headers]
Get:115 http://ftp.debian.org/debian buster/main amd64 libglvnd-core-dev amd64 1.1.0-1 [13.2 kB]
21% [5 tdevelop-data-trinity 1,147 kB/2,426 kB 47%] [115 libglvnd-core-dev 13.2
21% [5 tdevelop-data-trinity 1,147 kB/2,426 kB 47%] 7,332 kB/s 48s
Get:116 http://ftp.debian.org/debian buster/main amd64 libgles1 amd64 1.1.0-1 [13.8 kB]
21% [5 tdevelop-data-trinity 1,147 kB/2,426 kB 47%] [116 libgles1 13.8 kB/13.8
Get:117 http://ftp.debian.org/debian buster/main amd64 libopengl0 amd64 1.1.0-1 [33.4 kB]
21% [5 tdevelop-data-trinity 1,147 kB/2,426 kB 47%] [117 libopengl0 33.4 kB/33.
Get:118 http://ftp.debian.org/debian buster/main amd64 libglvnd-dev amd64 1.1.0-1 [5,128 B]
21% [5 tdevelop-data-trinity 1,147 kB/2,426 kB 47%] [118 libglvnd-dev 5,128 B/5
Get:119 http://ftp.debian.org/debian buster/main amd64 libx11-xcb-dev amd64 2:1.6.7-1+deb10u1 [192 kB]
21% [5 tdevelop-data-trinity 1,147 kB/2,426 kB 47%] [119 libx11-xcb-dev 15.4 kB
Get:120 http://ftp.debian.org/debian buster/main amd64 libxcb-dri3-dev amd64 1.13.1-2 [101 kB]
21% [5 tdevelop-data-trinity 1,147 kB/2,426 kB 47%] [120 libxcb-dri3-dev 2,466
Get:121 http://ftp.debian.org/debian buster/main amd64 libxcb-render0-dev amd64 1.13.1-2 [112 kB]
21% [5 tdevelop-data-trinity 1,147 kB/2,426 kB 47%] [121 libxcb-render0-dev 3,8
Get:122 http://ftp.debian.org/debian buster/main amd64 libxcb-randr0-dev amd64 1.13.1-2 [114 kB]
21% [5 tdevelop-data-trinity 1,147 kB/2,426 kB 47%] [122 libxcb-randr0-dev 2,71
21% [5 tdevelop-data-trinity 1,163 kB/2,426 kB 48%] [Waiting for headers]
Get:123 http://ftp.debian.org/debian buster/main amd64 libxcb-shape0-dev amd64 1.13.1-2 [101 kB]
21% [5 tdevelop-data-trinity 1,163 kB/2,426 kB 48%] [123 libxcb-shape0-dev 5,40
21% [5 tdevelop-data-trinity 1,163 kB/2,426 kB 48%] 7,332 kB/s 47s
Get:124 http://ftp.debian.org/debian buster/main amd64 libxcb-xfixes0-dev amd64 1.13.1-2 [105 kB]
21% [5 tdevelop-data-trinity 1,163 kB/2,426 kB 48%] [124 libxcb-xfixes0-dev 3,9
Get:125 http://ftp.debian.org/debian buster/main amd64 libxcb-sync-dev amd64 1.13.1-2 [104 kB]
21% [5 tdevelop-data-trinity 1,163 kB/2,426 kB 48%] [125 libxcb-sync-dev 5,348
22% [5 tdevelop-data-trinity 1,179 kB/2,426 kB 49%] [Waiting for headers]
Get:126 http://ftp.debian.org/debian buster/main amd64 libxcb-present-dev amd64 1.13.1-2 [101 kB]
22% [5 tdevelop-data-trinity 1,179 kB/2,426 kB 49%] [126 libxcb-present-dev 578
22% [5 tdevelop-data-trinity 1,179 kB/2,426 kB 49%] 7,332 kB/s 47s
Get:127 http://ftp.debian.org/debian buster/main amd64 libxshmfence-dev amd64 1.3-1 [8,360 B]
22% [5 tdevelop-data-trinity 1,179 kB/2,426 kB 49%] [127 libxshmfence-dev 3,747
Get:128 http://ftp.debian.org/debian buster/main amd64 libxcb-dri2-0-dev amd64 1.13.1-2 [102 kB]
22% [5 tdevelop-data-trinity 1,179 kB/2,426 kB 49%] [128 libxcb-dri2-0-dev 2,19
Get:129 http://ftp.debian.org/debian buster/main amd64 libxcb-glx0-dev amd64 1.13.1-2 [122 kB]
22% [5 tdevelop-data-trinity 1,179 kB/2,426 kB 49%] [129 libxcb-glx0-dev 2,423
Get:130 http://ftp.debian.org/debian buster/main amd64 x11proto-damage-dev all 1:2018.4-4 [3,140 B]
22% [5 tdevelop-data-trinity 1,196 kB/2,426 kB 49%] [130 x11proto-damage-dev 3,
22% [5 tdevelop-data-trinity 1,196 kB/2,426 kB 49%] 7,332 kB/s 47s
Get:131 http://ftp.debian.org/debian buster/main amd64 libxdamage-dev amd64 1:1.1.4-3+b3 [14.6 kB]
22% [5 tdevelop-data-trinity 1,228 kB/2,426 kB 51%] [131 libxdamage-dev 3,878 B
22% [5 tdevelop-data-trinity 1,245 kB/2,426 kB 51%] 7,332 kB/s 47s
Get:132 http://ftp.debian.org/debian buster/main amd64 x11proto-xf86vidmode-dev all 2018.4-4 [3,140 B]
22% [5 tdevelop-data-trinity 1,261 kB/2,426 kB 52%] [132 x11proto-xf86vidmode-d
22% [5 tdevelop-data-trinity 1,261 kB/2,426 kB 52%] [Waiting for headers]
Get:133 http://ftp.debian.org/debian buster/main amd64 libxxf86vm-dev amd64 1:1.1.4-1+b2 [25.4 kB]
22% [5 tdevelop-data-trinity 1,261 kB/2,426 kB 52%] [133 libxxf86vm-dev 1,798 B
22% [5 tdevelop-data-trinity 1,278 kB/2,426 kB 53%] [Waiting for headers]
Get:134 http://ftp.debian.org/debian buster/main amd64 libgl1-mesa-dev amd64 18.3.6-2+deb10u1 [48.0 kB]
22% [5 tdevelop-data-trinity 1,278 kB/2,426 kB 53%] [134 libgl1-mesa-dev 600 B/
22% [5 tdevelop-data-trinity 1,310 kB/2,426 kB 54%] [Waiting for headers]
Get:135 http://ftp.debian.org/debian buster/main amd64 libglu1-mesa-dev amd64 9.0.0-2.1+b3 [208 kB]
22% [5 tdevelop-data-trinity 1,310 kB/2,426 kB 54%] [135 libglu1-mesa-dev 2,810
22% [5 tdevelop-data-trinity 1,327 kB/2,426 kB 55%] [Waiting for headers]
Get:136 http://ftp.debian.org/debian buster/main amd64 libgssrpc4 amd64 1.17-3 [91.3 kB]
22% [5 tdevelop-data-trinity 1,327 kB/2,426 kB 55%] [136 libgssrpc4 297 B/91.3
23% [5 tdevelop-data-trinity 1,343 kB/2,426 kB 55%] [Waiting for headers]
Get:137 http://ftp.debian.org/debian buster/main amd64 libkdb5-9 amd64 1.17-3 [73.2 kB]
23% [5 tdevelop-data-trinity 1,343 kB/2,426 kB 55%] [137 libkdb5-9 1,288 B/73.2
23% [5 tdevelop-data-trinity 1,360 kB/2,426 kB 56%] [Waiting for headers]
Get:138 http://ftp.debian.org/debian buster/main amd64 libkadm5srv-mit11 amd64 1.17-3 [85.6 kB]
23% [5 tdevelop-data-trinity 1,360 kB/2,426 kB 56%] [138 libkadm5srv-mit11 7,26
Get:139 http://ftp.debian.org/debian buster/main amd64 libkadm5clnt-mit11 amd64 1.17-3 [73.4 kB]
23% [5 tdevelop-data-trinity 1,360 kB/2,426 kB 56%] [139 libkadm5clnt-mit11 5,2
Get:140 http://ftp.debian.org/debian buster/main amd64 krb5-multidev amd64 1.17-3 [156 kB]
23% [5 tdevelop-data-trinity 1,360 kB/2,426 kB 56%] [140 krb5-multidev 2,332 B/
23% [5 tdevelop-data-trinity 1,376 kB/2,426 kB 57%] [Waiting for headers]
Get:141 http://ftp.debian.org/debian buster/main amd64 libattr1-dev amd64 1:2.4.48-4 [34.9 kB]
23% [5 tdevelop-data-trinity 1,376 kB/2,426 kB 57%] [141 libattr1-dev 2,704 B/3
Get:142 http://ftp.debian.org/debian buster/main amd64 libacl1-dev amd64 2.2.53-4 [91.7 kB]
23% [5 tdevelop-data-trinity 1,376 kB/2,426 kB 57%] [142 libacl1-dev 3,559 B/91
Get:143 http://ftp.debian.org/debian buster/main amd64 libffi-dev amd64 3.2.1-9 [156 kB]
23% [5 tdevelop-data-trinity 1,376 kB/2,426 kB 57%] [143 libffi-dev 5,553 B/156
Get:144 http://ftp.debian.org/debian buster/main amd64 python3-lib2to3 all 3.7.3-1 [76.7 kB]
23% [5 tdevelop-data-trinity 1,376 kB/2,426 kB 57%] [144 python3-lib2to3 2,136
23% [5 tdevelop-data-trinity 1,376 kB/2,426 kB 57%] 7,332 kB/s 47s
Get:145 http://ftp.debian.org/debian buster/main amd64 python3-distutils all 3.7.3-1 [142 kB]
23% [5 tdevelop-data-trinity 1,376 kB/2,426 kB 57%] [145 python3-distutils 1,75
23% [5 tdevelop-data-trinity 1,392 kB/2,426 kB 57%] [Waiting for headers]
Get:146 http://ftp.debian.org/debian buster/main amd64 libglib2.0-dev-bin amd64 2.58.3-2+deb10u2 [157 kB]
23% [5 tdevelop-data-trinity 1,392 kB/2,426 kB 57%] [146 libglib2.0-dev-bin 2,4
24% [5 tdevelop-data-trinity 1,392 kB/2,426 kB 57%] [Waiting for headers]
Get:147 http://ftp.debian.org/debian buster/main amd64 libblkid-dev amd64 2.33.1-0.1 [225 kB]
24% [5 tdevelop-data-trinity 1,392 kB/2,426 kB 57%] [147 libblkid-dev 2,514 B/2
Get:148 http://ftp.debian.org/debian buster/main amd64 libmount-dev amd64 2.33.1-0.1 [232 kB]
24% [5 tdevelop-data-trinity 1,392 kB/2,426 kB 57%] [148 libmount-dev 3,128 B/2
24% [5 tdevelop-data-trinity 1,409 kB/2,426 kB 58%] [Waiting for headers]
Get:149 http://ftp.debian.org/debian buster/main amd64 libpcre16-3 amd64 2:8.39-12 [259 kB]
24% [5 tdevelop-data-trinity 1,409 kB/2,426 kB 58%] [149 libpcre16-3 5,362 B/25
24% [5 tdevelop-data-trinity 1,425 kB/2,426 kB 59%] [Waiting for headers]
Get:150 http://ftp.debian.org/debian buster/main amd64 libpcre32-3 amd64 2:8.39-12 [250 kB]
24% [5 tdevelop-data-trinity 1,425 kB/2,426 kB 59%] [150 libpcre32-3 2,548 B/25
Get:151 http://ftp.debian.org/debian buster/main amd64 libpcrecpp0v5 amd64 2:8.39-12 [152 kB]
24% [5 tdevelop-data-trinity 1,425 kB/2,426 kB 59%] [151 libpcrecpp0v5 2,750 B/
Get:152 http://ftp.debian.org/debian buster/main amd64 libpcre3-dev amd64 2:8.39-12 [650 kB]
24% [5 tdevelop-data-trinity 1,425 kB/2,426 kB 59%] [152 libpcre3-dev 6,484 B/6
24% [5 tdevelop-data-trinity 1,441 kB/2,426 kB 59%] [Waiting for headers]
Get:153 http://ftp.debian.org/debian buster/main amd64 libsepol1-dev amd64 2.8-1 [338 kB]
24% [5 tdevelop-data-trinity 1,441 kB/2,426 kB 59%] [153 libsepol1-dev 61.9 kB/
24% [5 tdevelop-data-trinity 1,441 kB/2,426 kB 59%] 7,332 kB/s 47s
Get:154 http://ftp.debian.org/debian buster/main amd64 libselinux1-dev amd64 2.8-1+b1 [169 kB]
24% [5 tdevelop-data-trinity 1,441 kB/2,426 kB 59%] [154 libselinux1-dev 51.3 k
25% [5 tdevelop-data-trinity 1,441 kB/2,426 kB 59%] 7,332 kB/s 47s
Get:155 http://ftp.debian.org/debian buster/main amd64 libglib2.0-dev amd64 2.58.3-2+deb10u2 [1,483 kB]
25% [5 tdevelop-data-trinity 1,441 kB/2,426 kB 59%] [155 libglib2.0-dev 12.9 kB
Get:156 http://ftp.debian.org/debian buster/main amd64 libasound2-dev amd64 1.1.8-1 [145 kB]
25% [5 tdevelop-data-trinity 1,441 kB/2,426 kB 59%] [156 libasound2-dev 36.5 kB
25% [5 tdevelop-data-trinity 1,441 kB/2,426 kB 59%] [Waiting for headers]
Get:157 http://ftp.debian.org/debian buster/main amd64 libaudiofile-dev amd64 0.3.6-5 [59.0 kB]
25% [5 tdevelop-data-trinity 1,441 kB/2,426 kB 59%] [157 libaudiofile-dev 22.5
Get:158 http://ftp.debian.org/debian buster/main amd64 libogg-dev amd64 1.3.2-1+b1 [200 kB]
25% [5 tdevelop-data-trinity 1,441 kB/2,426 kB 59%] [158 libogg-dev 4,096 B/200
Get:159 http://ftp.debian.org/debian buster/main amd64 libvorbis-dev amd64 1.3.6-2 [328 kB]
25% [5 tdevelop-data-trinity 1,441 kB/2,426 kB 59%] [159 libvorbis-dev 24.7 kB/
25% [5 tdevelop-data-trinity 1,474 kB/2,426 kB 61%] [Waiting for headers]
Get:160 http://ftp.debian.org/debian buster/main amd64 libmad0-dev amd64 0.15.1b-10 [78.7 kB]
25% [5 tdevelop-data-trinity 1,474 kB/2,426 kB 61%] [160 libmad0-dev 4,553 B/78
25% [5 tdevelop-data-trinity 1,507 kB/2,426 kB 62%] [Waiting for headers]
Get:161 http://ftp.debian.org/debian buster/main amd64 libaspell-dev amd64 0.60.7~20110707-6 [32.6 kB]
25% [5 tdevelop-data-trinity 1,507 kB/2,426 kB 62%] [161 libaspell-dev 2,157 B/
26% [5 tdevelop-data-trinity 1,507 kB/2,426 kB 62%] [Waiting for headers]
Get:162 http://ftp.debian.org/debian buster/main amd64 libavahi-common-dev amd64 0.7-4+b1 [69.3 kB]
26% [5 tdevelop-data-trinity 1,507 kB/2,426 kB 62%] [162 libavahi-common-dev 12
26% [5 tdevelop-data-trinity 1,507 kB/2,426 kB 62%] 7,332 kB/s 47s
Get:163 http://ftp.debian.org/debian buster/main amd64 libdbus-1-dev amd64 1.12.20-0+deb10u1 [251 kB]
26% [5 tdevelop-data-trinity 1,507 kB/2,426 kB 62%] [163 libdbus-1-dev 2,466 B/
26% [5 tdevelop-data-trinity 1,523 kB/2,426 kB 63%] [Waiting for headers]
Get:164 http://ftp.debian.org/debian buster/main amd64 libavahi-client-dev amd64 0.7-4+b1 [68.4 kB]
26% [5 tdevelop-data-trinity 1,523 kB/2,426 kB 63%] [164 libavahi-client-dev 2,
Get:165 http://ftp.debian.org/debian buster/main amd64 libbz2-dev amd64 1.0.6-9.2~deb10u1 [30.2 kB]
26% [5 tdevelop-data-trinity 1,523 kB/2,426 kB 63%] [165 libbz2-dev 3,601 B/30.
Get:166 http://ftp.debian.org/debian buster/main amd64 libc6-dbg amd64 2.28-10 [11.5 MB]
26% [5 tdevelop-data-trinity 1,523 kB/2,426 kB 63%] [166 libc6-dbg 3,388 B/11.5
27% [5 tdevelop-data-trinity 1,573 kB/2,426 kB 65%] [166 libc6-dbg 4,979 kB/11.
28% [5 tdevelop-data-trinity 1,654 kB/2,426 kB 68%] [166 libc6-dbg 10.0 MB/11.5
28% [5 tdevelop-data-trinity 1,671 kB/2,426 kB 69%] [Waiting for headers]
Get:167 http://ftp.debian.org/debian buster/main amd64 libcupsfilters-dev amd64 1.21.6-5 [181 kB]
28% [5 tdevelop-data-trinity 1,671 kB/2,426 kB 69%] [167 libcupsfilters-dev 27.
Get:168 http://ftp.debian.org/debian buster/main amd64 libfontenc-dev amd64 1:1.1.3-1+b2 [26.1 kB]
28% [5 tdevelop-data-trinity 1,671 kB/2,426 kB 69%] [168 libfontenc-dev 26.1 kB
28% [5 tdevelop-data-trinity 1,671 kB/2,426 kB 69%] 6,262 kB/s 53s
Get:169 http://ftp.debian.org/debian buster/main amd64 libgts-bin amd64 0.7.6+darcs121130-4 [50.8 kB]
28% [5 tdevelop-data-trinity 1,671 kB/2,426 kB 69%] [169 libgts-bin 16.1 kB/50.
Get:170 http://ftp.debian.org/debian buster/main amd64 libicu-dev amd64 63.1-6+deb10u1 [9,186 kB]
30% [5 tdevelop-data-trinity 1,753 kB/2,426 kB 72%] [170 libicu-dev 5,930 kB/9,
30% [5 tdevelop-data-trinity 1,786 kB/2,426 kB 74%] [Waiting for headers]
Get:171 http://ftp.debian.org/debian buster/main amd64 libidn11-dev amd64 1.33-2.2 [594 kB]
30% [5 tdevelop-data-trinity 1,786 kB/2,426 kB 74%] [171 libidn11-dev 14.8 kB/5
31% [5 tdevelop-data-trinity 1,786 kB/2,426 kB 74%] [Waiting for headers]
Get:172 http://ftp.debian.org/debian buster/main amd64 libilmbase-dev amd64 2.2.1-2 [76.7 kB]
31% [5 tdevelop-data-trinity 1,786 kB/2,426 kB 74%] [172 libilmbase-dev 5,205 B
Get:173 http://ftp.debian.org/debian buster/main amd64 libkrb5-dev amd64 1.17-3 [47.4 kB]
31% [5 tdevelop-data-trinity 1,786 kB/2,426 kB 74%] [173 libkrb5-dev 3,357 B/47
Get:174 http://ftp.debian.org/debian buster/main amd64 libltdl-dev amd64 2.4.6-9 [162 kB]
31% [5 tdevelop-data-trinity 1,786 kB/2,426 kB 74%] [174 libltdl-dev 3,347 B/16
Get:175 http://ftp.debian.org/debian buster/main amd64 liblua50 amd64 5.0.3-8+b1 [47.6 kB]
31% [5 tdevelop-data-trinity 1,786 kB/2,426 kB 74%] [175 liblua50 3,123 B/47.6
31% [5 tdevelop-data-trinity 1,802 kB/2,426 kB 74%] [Waiting for headers]
Get:176 http://ftp.debian.org/debian buster/main amd64 liblualib50 amd64 5.0.3-8+b1 [32.3 kB]
31% [5 tdevelop-data-trinity 1,802 kB/2,426 kB 74%] [176 liblualib50 32.3 kB/32
31% [5 tdevelop-data-trinity 1,802 kB/2,426 kB 74%] 6,262 kB/s 51s
Get:177 http://ftp.debian.org/debian buster/main amd64 lua50 amd64 5.0.3-8+b1 [24.6 kB]
31% [5 tdevelop-data-trinity 1,802 kB/2,426 kB 74%] [177 lua50 24.6 kB/24.6 kB
Get:178 http://ftp.debian.org/debian buster/main amd64 liblua50-dev amd64 5.0.3-8+b1 [54.9 kB]
31% [5 tdevelop-data-trinity 1,802 kB/2,426 kB 74%] [178 liblua50-dev 14.2 kB/5
Get:179 http://ftp.debian.org/debian buster/main amd64 liblualib50-dev amd64 5.0.3-8+b1 [33.9 kB]
31% [5 tdevelop-data-trinity 1,802 kB/2,426 kB 74%] [179 liblualib50-dev 24.4 k
Get:180 http://ftp.debian.org/debian buster/main amd64 libmbim-glib4 amd64 1.18.0-1 [157 kB]
31% [5 tdevelop-data-trinity 1,802 kB/2,426 kB 74%] [180 libmbim-glib4 55.5 kB/
Get:181 http://ftp.debian.org/debian buster/main amd64 libmbim-proxy amd64 1.18.0-1 [71.1 kB]
31% [5 tdevelop-data-trinity 1,802 kB/2,426 kB 74%] [181 libmbim-proxy 2,467 B/
Get:182 http://ftp.debian.org/debian buster/main amd64 libncurses-dev amd64 6.1+20181013-2+deb10u2 [333 kB]
31% [5 tdevelop-data-trinity 1,802 kB/2,426 kB 74%] [182 libncurses-dev 3,349 B
32% [5 tdevelop-data-trinity 1,802 kB/2,426 kB 74%] [Waiting for headers]
Get:183 http://ftp.debian.org/debian buster/main amd64 libomp5-7 amd64 1:7.0.1-8+deb10u2 [319 kB]
32% [5 tdevelop-data-trinity 1,802 kB/2,426 kB 74%] [183 libomp5-7 1,359 B/319
32% [5 tdevelop-data-trinity 1,818 kB/2,426 kB 75%] [Waiting for headers]
Get:184 http://ftp.debian.org/debian buster/main amd64 libomp-7-dev amd64 1:7.0.1-8+deb10u2 [57.8 kB]
32% [5 tdevelop-data-trinity 1,818 kB/2,426 kB 75%] [184 libomp-7-dev 2,139 B/5
Get:185 http://ftp.debian.org/debian buster/main amd64 libopenexr-dev amd64 2.2.1-4.1+deb10u1 [729 kB]
32% [5 tdevelop-data-trinity 1,818 kB/2,426 kB 75%] [185 libopenexr-dev 3,309 B
Get:186 http://ftp.debian.org/debian buster/main amd64 libpciaccess-dev amd64 0.14-1 [56.8 kB]
32% [5 tdevelop-data-trinity 1,818 kB/2,426 kB 75%] [186 libpciaccess-dev 3,277
Get:187 http://ftp.debian.org/debian buster/main amd64 libpixman-1-dev amd64 0.36.0-1 [554 kB]
32% [5 tdevelop-data-trinity 1,818 kB/2,426 kB 75%] [187 libpixman-1-dev 2,531
32% [5 tdevelop-data-trinity 1,835 kB/2,426 kB 76%] [Waiting for headers]
Get:188 http://ftp.debian.org/debian buster/main amd64 libpng-tools amd64 1.6.36-6 [140 kB]
32% [5 tdevelop-data-trinity 1,835 kB/2,426 kB 76%] [188 libpng-tools 3,069 B/1
Get:189 http://ftp.debian.org/debian buster/main amd64 qbs-common all 1.12.2+dfsg-2 [114 kB]
32% [5 tdevelop-data-trinity 1,835 kB/2,426 kB 76%] [189 qbs-common 3,495 B/114
32% [5 tdevelop-data-trinity 1,835 kB/2,426 kB 76%] 6,262 kB/s 51s
Get:190 http://ftp.debian.org/debian buster/main amd64 libqbscore1.12 amd64 1.12.2+dfsg-2 [1,053 kB]
32% [5 tdevelop-data-trinity 1,835 kB/2,426 kB 76%] [190 libqbscore1.12 3,231 B
33% [5 tdevelop-data-trinity 1,867 kB/2,426 kB 77%] [Waiting for headers]
Get:191 http://ftp.debian.org/debian buster/main amd64 libqbsqtprofilesetup1.12 amd64 1.12.2+dfsg-2 [120 kB]
33% [5 tdevelop-data-trinity 1,867 kB/2,426 kB 77%] [191 libqbsqtprofilesetup1.
33% [5 tdevelop-data-trinity 1,867 kB/2,426 kB 77%] 6,262 kB/s 50s
Get:192 http://ftp.debian.org/debian buster/main amd64 libqmi-glib5 amd64 1.22.0-1.2 [508 kB]
33% [5 tdevelop-data-trinity 1,867 kB/2,426 kB 77%] [192 libqmi-glib5 14.8 kB/5
Get:193 http://ftp.debian.org/debian buster/main amd64 libqmi-proxy amd64 1.22.0-1.2 [9,460 B]
33% [5 tdevelop-data-trinity 1,867 kB/2,426 kB 77%] [193 libqmi-proxy 9,460 B/9
Get:194 http://ftp.debian.org/debian buster/main amd64 libqt5designer5 amd64 5.11.3-4 [2,783 kB]
33% [5 tdevelop-data-trinity 1,867 kB/2,426 kB 77%] [194 libqt5designer5 16.4 k
34% [5 tdevelop-data-trinity 1,884 kB/2,426 kB 78%] [Waiting for headers]
Get:195 http://ftp.debian.org/debian buster/main amd64 libqt5designercomponents5 amd64 5.11.3-4 [711 kB]
34% [5 tdevelop-data-trinity 1,884 kB/2,426 kB 78%] [195 libqt5designercomponen
34% [5 tdevelop-data-trinity 1,900 kB/2,426 kB 78%] [Waiting for headers]
Get:196 http://ftp.debian.org/debian buster/main amd64 libqt5help5 amd64 5.11.3-4 [149 kB]
34% [5 tdevelop-data-trinity 1,900 kB/2,426 kB 78%] [196 libqt5help5 3,188 B/14
Get:197 http://ftp.debian.org/debian buster/main amd64 libqt5quicktest5 amd64 5.11.3-4 [76.6 kB]
34% [5 tdevelop-data-trinity 1,900 kB/2,426 kB 78%] [197 libqt5quicktest5 3,311
Get:198 http://ftp.debian.org/debian buster/main amd64 libqt5quickwidgets5 amd64 5.11.3-4 [50.6 kB]
34% [5 tdevelop-data-trinity 1,900 kB/2,426 kB 78%] [198 libqt5quickwidgets5 3,
Get:199 http://ftp.debian.org/debian buster/main amd64 libqt5serialport5 amd64 5.11.3-2 [35.0 kB]
34% [5 tdevelop-data-trinity 1,900 kB/2,426 kB 78%] [199 libqt5serialport5 2,75
34% [5 tdevelop-data-trinity 1,900 kB/2,426 kB 78%] 6,262 kB/s 50s
Get:200 http://ftp.debian.org/debian buster/main amd64 libqt5xmlpatterns5 amd64 5.11.3-2 [954 kB]
34% [5 tdevelop-data-trinity 1,900 kB/2,426 kB 78%] [200 libqt5xmlpatterns5 2,0
35% [5 tdevelop-data-trinity 1,917 kB/2,426 kB 79%] [Waiting for headers]
Get:201 http://ftp.debian.org/debian buster/main amd64 libsasl2-dev amd64 2.1.27+dfsg-1+deb10u1 [283 kB]
35% [5 tdevelop-data-trinity 1,917 kB/2,426 kB 79%] [201 libsasl2-dev 3,543 B/2
Get:202 http://ftp.debian.org/debian buster/main amd64 libssl-dev amd64 1.1.1d-0+deb10u3 [1,793 kB]
35% [5 tdevelop-data-trinity 1,917 kB/2,426 kB 79%] [202 libssl-dev 2,599 B/1,7
Get:203 http://ftp.debian.org/debian buster/main amd64 libtinfo-dev amd64 6.1+20181013-2+deb10u2 [940 B]
Get:204 http://ftp.debian.org/debian buster/main amd64 libtool all 2.4.6-9 [547 kB]
35% [5 tdevelop-data-trinity 1,917 kB/2,426 kB 79%] [204 libtool 4,588 B/547 kB
35% [5 tdevelop-data-trinity 1,949 kB/2,426 kB 80%] [Waiting for headers]
Get:205 http://ftp.debian.org/debian buster/main amd64 libudev-dev amd64 241-7~deb10u4 [110 kB]
35% [5 tdevelop-data-trinity 1,949 kB/2,426 kB 80%] [205 libudev-dev 39.0 kB/11
Get:206 http://ftp.debian.org/debian buster/main amd64 x11proto-composite-dev all 1:2018.4-4 [3,140 B]
36% [5 tdevelop-data-trinity 1,949 kB/2,426 kB 80%] [Waiting for headers]
Get:207 http://ftp.debian.org/debian buster/main amd64 libxcomposite-dev amd64 1:0.4.4-2 [20.1 kB]
36% [5 tdevelop-data-trinity 1,949 kB/2,426 kB 80%] [207 libxcomposite-dev 14.1
Get:208 http://ftp.debian.org/debian buster/main amd64 libxfont-dev amd64 1:2.0.3-1 [164 kB]
36% [5 tdevelop-data-trinity 1,949 kB/2,426 kB 80%] [208 libxfont-dev 11.0 kB/1
Get:209 http://ftp.debian.org/debian buster/main amd64 libxkbfile-dev amd64 1:1.0.9-2+b11 [87.3 kB]
36% [5 tdevelop-data-trinity 1,949 kB/2,426 kB 80%] [209 libxkbfile-dev 46.6 kB
Get:210 http://ftp.debian.org/debian buster/main amd64 libxml2-dev amd64 2.9.4+dfsg1-7+b3 [783 kB]
36% [5 tdevelop-data-trinity 1,949 kB/2,426 kB 80%] [210 libxml2-dev 19.8 kB/78
Get:211 http://ftp.debian.org/debian buster/main amd64 libxml2-utils amd64 2.9.4+dfsg1-7+b3 [99.7 kB]
36% [5 tdevelop-data-trinity 1,949 kB/2,426 kB 80%] [211 libxml2-utils 49.0 kB/
Get:212 http://ftp.debian.org/debian buster/main amd64 libxslt1-dev amd64 1.1.32-2.2~deb10u1 [519 kB]
36% [5 tdevelop-data-trinity 1,949 kB/2,426 kB 80%] [212 libxslt1-dev 14.4 kB/5
36% [5 tdevelop-data-trinity 1,966 kB/2,426 kB 81%] [Waiting for headers]
Get:213 http://ftp.debian.org/debian buster/main amd64 llvm-7-runtime amd64 1:7.0.1-8+deb10u2 [190 kB]
36% [5 tdevelop-data-trinity 1,966 kB/2,426 kB 81%] [213 llvm-7-runtime 18.8 kB
Get:214 http://ftp.debian.org/debian buster/main amd64 llvm-7 amd64 1:7.0.1-8+deb10u2 [4,554 kB]
36% [5 tdevelop-data-trinity 1,966 kB/2,426 kB 81%] [214 llvm-7 1,016 B/4,554 k
37% [5 tdevelop-data-trinity 2,015 kB/2,426 kB 83%] [214 llvm-7 4,352 kB/4,554
37% [5 tdevelop-data-trinity 2,015 kB/2,426 kB 83%] [Waiting for headers]
Get:215 http://ftp.debian.org/debian buster/main amd64 llvm-7-dev amd64 1:7.0.1-8+deb10u2 [21.3 MB]
38% [5 tdevelop-data-trinity 2,064 kB/2,426 kB 85%] [215 llvm-7-dev 4,206 kB/21
41% [5 tdevelop-data-trinity 2,195 kB/2,426 kB 90%] [215 llvm-7-dev 20.9 MB/21.
41% [5 tdevelop-data-trinity 2,195 kB/2,426 kB 90%] [Waiting for headers]
Get:216 http://ftp.debian.org/debian buster/main amd64 mc-data all 3:4.8.22-1 [1,292 kB]
41% [5 tdevelop-data-trinity 2,195 kB/2,426 kB 90%] [216 mc-data 45.9 kB/1,292
42% [5 tdevelop-data-trinity 2,195 kB/2,426 kB 90%] [Waiting for headers]
Get:217 http://ftp.debian.org/debian buster/main amd64 mc amd64 3:4.8.22-1 [516 kB]
42% [5 tdevelop-data-trinity 2,195 kB/2,426 kB 90%] [217 mc 21.5 kB/516 kB 4%]
42% [5 tdevelop-data-trinity 2,212 kB/2,426 kB 91%] [Waiting for headers]
Get:218 http://ftp.debian.org/debian buster/main amd64 modemmanager amd64 1.10.0-1 [1,494 kB]
42% [5 tdevelop-data-trinity 2,212 kB/2,426 kB 91%] [218 modemmanager 17.6 kB/1
42% [5 tdevelop-data-trinity 2,228 kB/2,426 kB 92%] [Waiting for headers]
Get:219 http://ftp.debian.org/debian buster/main amd64 qdoc-qt5 amd64 5.11.3-4 [467 kB]
42% [5 tdevelop-data-trinity 2,228 kB/2,426 kB 92%] [219 qdoc-qt5 20.0 kB/467 k
43% [5 tdevelop-data-trinity 2,228 kB/2,426 kB 92%] [Waiting for headers]
Get:220 http://ftp.debian.org/debian buster/main amd64 qml-module-qtqml-models2 amd64 5.11.3-4 [32.4 kB]
43% [5 tdevelop-data-trinity 2,228 kB/2,426 kB 92%] [220 qml-module-qtqml-model
Get:221 http://ftp.debian.org/debian buster/main amd64 qmlscene amd64 5.11.3-4 [43.5 kB]
43% [5 tdevelop-data-trinity 2,228 kB/2,426 kB 92%] [221 qmlscene 1,054 B/43.5
Get:222 http://ftp.debian.org/debian buster/main amd64 qt3d5-doc all 5.11.3+dfsg-2 [18.1 MB]
43% [5 tdevelop-data-trinity 2,228 kB/2,426 kB 92%] [222 qt3d5-doc 3,448 B/18.1
44% [5 tdevelop-data-trinity 2,244 kB/2,426 kB 93%] [222 qt3d5-doc 5,092 kB/18.
46% [5 tdevelop-data-trinity 2,326 kB/2,426 kB 96%] [222 qt3d5-doc 16.5 MB/18.1
46% [5 tdevelop-data-trinity 2,359 kB/2,426 kB 97%] [Waiting for headers]
Get:223 http://ftp.debian.org/debian buster/main amd64 qt5-assistant amd64 5.11.3-4 [758 kB]
46% [5 tdevelop-data-trinity 2,359 kB/2,426 kB 97%] [223 qt5-assistant 27.5 kB/
Get:224 http://ftp.debian.org/debian buster/main amd64 qt5-qmltooling-plugins amd64 5.11.3-4 [170 kB]
46% [5 tdevelop-data-trinity 2,359 kB/2,426 kB 97%] [224 qt5-qmltooling-plugins
47% [5 tdevelop-data-trinity 2,359 kB/2,426 kB 97%] [Waiting for headers]
Get:225 http://ftp.debian.org/debian buster/main amd64 qtbase5-dev-tools amd64 5.11.3+dfsg1-1+deb10u4 [770 kB]
47% [5 tdevelop-data-trinity 2,359 kB/2,426 kB 97%] [225 qtbase5-dev-tools 16.1
47% [5 tdevelop-data-trinity 2,359 kB/2,426 kB 97%] 10.1 MB/s 25s
Get:226 http://ftp.debian.org/debian buster/main amd64 qtbase5-doc all 5.11.3+dfsg1-1+deb10u4 [30.1 MB]
47% [5 tdevelop-data-trinity 2,359 kB/2,426 kB 97%] [226 qtbase5-doc 4,096 B/30
48% [5 tdevelop-data-trinity 2,424 kB/2,426 kB 100%] [226 qtbase5-doc 8,392 kB/
49% [Waiting for headers] [226 qtbase5-doc 8,993 kB/30.1 MB 30%] 10.1 MB/s 24s
Get:6 https://q4os.org/qtderepo buster/main amd64 tdevelop-trinity amd64 4:14.0.6-0debian10.0.0+0~a [5,217 kB]
52% [6 tdevelop-trinity 81.6 kB/5,217 kB 2%] [226 qtbase5-doc 29.0 MB/30.1 MB 9
53% [6 tdevelop-trinity 81.6 kB/5,217 kB 2%] [Waiting for headers]
Get:227 http://ftp.debian.org/debian buster/main amd64 qtcharts5-doc all 5.11.3-2 [5,136 kB]
53% [6 tdevelop-trinity 81.6 kB/5,217 kB 2%] [227 qtcharts5-doc 29.5 kB/5,136 k
54% [6 tdevelop-trinity 98.0 kB/5,217 kB 2%] [Waiting for headers]
Get:228 http://ftp.debian.org/debian buster/main amd64 qtconnectivity5-doc all 5.11.3-2 [2,960 kB]
54% [6 tdevelop-trinity 98.0 kB/5,217 kB 2%] [228 qtconnectivity5-doc 7,176 B/2
Get:229 http://ftp.debian.org/debian buster/main amd64 qtcreator-data all 4.8.2-1 [2,487 kB]
54% [6 tdevelop-trinity 98.0 kB/5,217 kB 2%] [229 qtcreator-data 59.5 kB/2,487
55% [6 tdevelop-trinity 114 kB/5,217 kB 2%] [Waiting for headers]
Get:230 http://ftp.debian.org/debian buster/main amd64 qtcreator amd64 4.8.2-1 [15.9 MB]
55% [6 tdevelop-trinity 114 kB/5,217 kB 2%] [230 qtcreator 4,231 B/15.9 MB 0%]
56% [6 tdevelop-trinity 164 kB/5,217 kB 3%] [230 qtcreator 8,920 kB/15.9 MB 56%
58% [6 tdevelop-trinity 196 kB/5,217 kB 4%] [230 qtcreator 14.4 MB/15.9 MB 90%]
58% [6 tdevelop-trinity 213 kB/5,217 kB 4%] [Waiting for headers]
Get:231 http://ftp.debian.org/debian buster/main amd64 qtcreator-doc all 4.8.2-1 [19.1 MB]
59% [6 tdevelop-trinity 245 kB/5,217 kB 5%] [231 qtcreator-doc 3,773 kB/19.1 MB
61% [6 tdevelop-trinity 344 kB/5,217 kB 7%] [231 qtcreator-doc 14.2 MB/19.1 MB
62% [6 tdevelop-trinity 376 kB/5,217 kB 7%] 10.1 MB/s 18s
Get:232 http://ftp.debian.org/debian buster/main amd64 qtdeclarative5-dev-tools amd64 5.11.3-4 [360 kB]
62% [6 tdevelop-trinity 393 kB/5,217 kB 8%] [232 qtdeclarative5-dev-tools 5,324
62% [6 tdevelop-trinity 458 kB/5,217 kB 9%] [232 qtdeclarative5-dev-tools 335 k
62% [6 tdevelop-trinity 458 kB/5,217 kB 9%] 10.1 MB/s 18s
Get:233 http://ftp.debian.org/debian buster/main amd64 qtdeclarative5-doc all 5.11.3-4 [15.2 MB]
62% [6 tdevelop-trinity 475 kB/5,217 kB 9%] [233 qtdeclarative5-doc 5,359 B/15.
63% [6 tdevelop-trinity 557 kB/5,217 kB 11%] [233 qtdeclarative5-doc 7,024 kB/1
64% [6 tdevelop-trinity 606 kB/5,217 kB 12%] [233 qtdeclarative5-doc 13.1 MB/15
65% [6 tdevelop-trinity 639 kB/5,217 kB 12%] [Waiting for headers]
Get:234 http://ftp.debian.org/debian buster/main amd64 qtgraphicaleffects5-doc all 5.11.3-2 [13.1 MB]
66% [6 tdevelop-trinity 704 kB/5,217 kB 13%] [234 qtgraphicaleffects5-doc 8,595
67% [6 tdevelop-trinity 721 kB/5,217 kB 14%] [Waiting for headers]
Get:235 http://ftp.debian.org/debian buster/main amd64 qtlocation5-doc all 5.11.3+dfsg-2 [3,498 kB]
67% [6 tdevelop-trinity 721 kB/5,217 kB 14%] [235 qtlocation5-doc 43.8 kB/3,498
68% [6 tdevelop-trinity 753 kB/5,217 kB 14%] [Waiting for headers]
Get:236 http://ftp.debian.org/debian buster/main amd64 qtmultimedia5-doc all 5.11.3-2 [2,436 kB]
68% [6 tdevelop-trinity 753 kB/5,217 kB 14%] [236 qtmultimedia5-doc 5,374 B/2,4
69% [6 tdevelop-trinity 770 kB/5,217 kB 15%] [Waiting for headers]
Get:237 http://ftp.debian.org/debian buster/main amd64 qtquickcontrols2-5-doc all 5.11.3+dfsg-2 [8,259 kB]
69% [6 tdevelop-trinity 802 kB/5,217 kB 15%] [237 qtquickcontrols2-5-doc 4,698
70% [6 tdevelop-trinity 819 kB/5,217 kB 16%] [Waiting for headers]
Get:238 http://ftp.debian.org/debian buster/main amd64 qtquickcontrols5-doc all 5.11.3-2 [5,772 kB]
70% [6 tdevelop-trinity 819 kB/5,217 kB 16%] [238 qtquickcontrols5-doc 65.5 kB/
71% [6 tdevelop-trinity 868 kB/5,217 kB 17%] [238 qtquickcontrols5-doc 5,361 kB
71% [6 tdevelop-trinity 868 kB/5,217 kB 17%] [Waiting for headers]
Get:239 http://ftp.debian.org/debian buster/main amd64 qtscript5-doc all 5.11.3+dfsg-3 [432 kB]
71% [6 tdevelop-trinity 868 kB/5,217 kB 17%] [239 qtscript5-doc 7,528 B/432 kB
72% [6 tdevelop-trinity 884 kB/5,217 kB 17%] [Waiting for headers]
Get:240 http://ftp.debian.org/debian buster/main amd64 qtsensors5-doc all 5.11.3-2 [2,228 kB]
72% [6 tdevelop-trinity 884 kB/5,217 kB 17%] [240 qtsensors5-doc 26.6 kB/2,228
72% [6 tdevelop-trinity 901 kB/5,217 kB 17%] [Waiting for headers]
Get:241 http://ftp.debian.org/debian buster/main amd64 qtserialport5-doc all 5.11.3-2 [331 kB]
72% [6 tdevelop-trinity 901 kB/5,217 kB 17%] [241 qtserialport5-doc 4,650 B/331
Get:242 http://ftp.debian.org/debian buster/main amd64 qtsvg5-doc all 5.11.3-2 [223 kB]
72% [6 tdevelop-trinity 901 kB/5,217 kB 17%] [242 qtsvg5-doc 3,824 B/223 kB 2%]
Get:243 http://ftp.debian.org/debian buster/main amd64 qttools5-dev-tools amd64 5.11.3-4 [1,069 kB]
72% [6 tdevelop-trinity 901 kB/5,217 kB 17%] [243 qttools5-dev-tools 3,484 B/1,
73% [6 tdevelop-trinity 901 kB/5,217 kB 17%] [Waiting for headers]
Get:244 http://ftp.debian.org/debian buster/main amd64 qttools5-doc all 5.11.3-4 [4,056 kB]
73% [6 tdevelop-trinity 901 kB/5,217 kB 17%] [244 qttools5-doc 3,864 B/4,056 kB
73% [6 tdevelop-trinity 934 kB/5,217 kB 18%] [Waiting for headers]
Get:245 http://ftp.debian.org/debian buster/main amd64 qtvirtualkeyboard5-doc all 5.11.3+dfsg-2 [883 kB]
73% [6 tdevelop-trinity 934 kB/5,217 kB 18%] [245 qtvirtualkeyboard5-doc 26.5 k
74% [6 tdevelop-trinity 950 kB/5,217 kB 18%] [Waiting for headers]
Get:246 http://ftp.debian.org/debian buster/main amd64 qtwayland5-doc all 5.11.3-2 [443 kB]
74% [6 tdevelop-trinity 950 kB/5,217 kB 18%] [246 qtwayland5-doc 2,764 B/443 kB
Get:247 http://ftp.debian.org/debian buster/main amd64 qtwebchannel5-doc all 5.11.3-2 [139 kB]
74% [6 tdevelop-trinity 950 kB/5,217 kB 18%] [247 qtwebchannel5-doc 3,438 B/139
Get:248 http://ftp.debian.org/debian buster/main amd64 qtwebengine5-doc all 5.11.3+dfsg-2+deb10u1 [2,392 kB]
74% [6 tdevelop-trinity 950 kB/5,217 kB 18%] [248 qtwebengine5-doc 2,582 B/2,39
74% [6 tdevelop-trinity 966 kB/5,217 kB 19%] [Waiting for headers]
Get:249 http://ftp.debian.org/debian buster/main amd64 qtwebsockets5-doc all 5.11.3-5 [245 kB]
74% [6 tdevelop-trinity 966 kB/5,217 kB 19%] [249 qtwebsockets5-doc 54.1 kB/245
75% [6 tdevelop-trinity 966 kB/5,217 kB 19%] [Waiting for headers]
Get:250 http://ftp.debian.org/debian buster/main amd64 qtwebview5-doc all 5.11.3-2 [89.8 kB]
75% [6 tdevelop-trinity 966 kB/5,217 kB 19%] [250 qtwebview5-doc 65.5 kB/89.8 k
75% [6 tdevelop-trinity 966 kB/5,217 kB 19%] 8,137 kB/s 14s
Get:251 http://ftp.debian.org/debian buster/main amd64 qtx11extras5-doc all 5.11.3-2 [30.0 kB]
75% [6 tdevelop-trinity 966 kB/5,217 kB 19%] [251 qtx11extras5-doc 30.0 kB/30.0
Get:252 http://ftp.debian.org/debian buster/main amd64 qtxmlpatterns5-dev-tools amd64 5.11.3-2 [31.9 kB]
75% [6 tdevelop-trinity 966 kB/5,217 kB 19%] [252 qtxmlpatterns5-dev-tools 15.5
Get:253 http://ftp.debian.org/debian buster/main amd64 qtxmlpatterns5-doc all 5.11.3-2 [610 kB]
75% [6 tdevelop-trinity 966 kB/5,217 kB 19%] [253 qtxmlpatterns5-doc 45.1 kB/61
Get:254 http://ftp.debian.org/debian buster/main amd64 reprepro amd64 5.3.0-1 [457 kB]
75% [6 tdevelop-trinity 966 kB/5,217 kB 19%] [254 reprepro 27.6 kB/457 kB 6%]
Get:255 http://ftp.debian.org/debian buster/main amd64 valgrind amd64 1:3.14.0-3 [15.7 MB]
75% [6 tdevelop-trinity 966 kB/5,217 kB 19%] [255 valgrind 3,850 B/15.7 MB 0%]
77% [6 tdevelop-trinity 1,048 kB/5,217 kB 20%] [255 valgrind 9,808 kB/15.7 MB 6
78% [6 tdevelop-trinity 1,097 kB/5,217 kB 21%] [255 valgrind 14.5 MB/15.7 MB 92
78% [6 tdevelop-trinity 1,114 kB/5,217 kB 21%] [Waiting for headers]
Get:256 http://ftp.debian.org/debian buster/main amd64 valgrind-dbg amd64 1:3.14.0-3 [74.5 MB]
78% [6 tdevelop-trinity 1,114 kB/5,217 kB 21%] [256 valgrind-dbg 56.4 kB/74.5 M
79% [6 tdevelop-trinity 1,179 kB/5,217 kB 23%] [256 valgrind-dbg 5,416 kB/74.5
92% [6 tdevelop-trinity 1,720 kB/5,217 kB 33%] [256 valgrind-dbg 72.4 MB/74.5 M
92% [6 tdevelop-trinity 1,720 kB/5,217 kB 33%] [Waiting for headers]
Get:257 http://ftp.debian.org/debian buster/main amd64 xfonts-terminus all 4.40-2 [1,346 kB]
92% [6 tdevelop-trinity 1,720 kB/5,217 kB 33%] [257 xfonts-terminus 65.5 kB/1,3
93% [6 tdevelop-trinity 1,736 kB/5,217 kB 33%] [Waiting for headers]
Get:258 http://ftp.debian.org/debian buster/main amd64 xserver-xorg-dev amd64 2:1.20.4-1+deb10u1 [2,409 kB]
93% [6 tdevelop-trinity 1,753 kB/5,217 kB 34%] [258 xserver-xorg-dev 1,836 kB/2
93% [6 tdevelop-trinity 1,753 kB/5,217 kB 34%] [Waiting for headers]
Get:259 http://ftp.debian.org/debian buster/main amd64 qt5-doc all 5.11.3-1 [3,781 kB]
93% [6 tdevelop-trinity 1,753 kB/5,217 kB 34%] [259 qt5-doc 4,534 B/3,781 kB 0%
94% [6 tdevelop-trinity 2,228 kB/5,217 kB 43%] 10.5 MB/s 1s
95% [6 tdevelop-trinity 4,898 kB/5,217 kB 94%] 3,329 kB/s 5s
95% [Waiting for headers] 3,329 kB/s 5s
Get:7 https://q4os.org/qtderepo buster/main amd64 libtqt3-headers amd64 4:14.0.6-0debian10.0.0+0~a [254 kB]
95% [7 libtqt3-headers 16.0 kB/254 kB 6%] 3,329 kB/s 5s
Get:8 https://q4os.org/qtderepo buster/main amd64 tqt3-dev-tools amd64 4:14.0.6-0debian10.0.0+0~a [953 kB]
95% [8 tqt3-dev-tools 3,505 B/953 kB 0%] 3,329 kB/s 5s
95% [Waiting for headers] 3,329 kB/s 4s
Get:9 https://q4os.org/qtderepo buster/main amd64 libtqt3-mt-dev amd64 4:14.0.6-0debian10.0.0+0~a [20.3 kB]
95% [9 libtqt3-mt-dev 16.1 kB/20.3 kB 79%] 3,329 kB/s 4s
Get:10 https://q4os.org/qtderepo buster/main amd64 tqt3-apps-dev amd64 4:14.0.6-0debian10.0.0+0~a [996 kB]
95% [10 tqt3-apps-dev 12.9 kB/996 kB 1%] 3,329 kB/s 4s
96% [Waiting for headers] 3,329 kB/s 4s
Get:11 https://q4os.org/qtderepo buster/main amd64 kdevdesigner-trinity amd64 4:14.0.6-0debian10.0.0+0~a [1,052 kB]
96% [11 kdevdesigner-trinity 8,192 B/1,052 kB 1%] 3,329 kB/s 4s
Get:12 https://q4os.org/qtderepo buster/main amd64 kdiff3-trinity amd64 4:14.0.6-0debian10.0.0+0~a [491 kB]
96% [12 kdiff3-trinity 4,096 B/491 kB 1%] 3,329 kB/s 4s
96% [Working] 3,329 kB/s 4s
Get:13 https://q4os.org/qtderepo buster/main amd64 kdiff3-trinity-doc all 4:14.0.6-0debian10.0.0+0~a [651 kB]
96% [13 kdiff3-trinity-doc 8,192 B/651 kB 1%] 3,329 kB/s 4s
96% [Waiting for headers] 3,329 kB/s 3s
Get:15 https://q4os.org/qtderepo buster/main amd64 khexedit-trinity amd64 4:14.0.6-0debian10.0.0+0~a [389 kB]
96% [15 khexedit-trinity 16.0 kB/389 kB 4%] 3,329 kB/s 3s
96% [Working] 3,329 kB/s 3s
Get:16 https://q4os.org/qtderepo buster/main amd64 libart-2.0-dev amd64 4:14.0.6-0debian10.0.0+0~a [82.6 kB]
96% [16 libart-2.0-dev 16.0 kB/82.6 kB 19%] 3,329 kB/s 3s
Get:17 https://q4os.org/qtderepo buster/main amd64 libartsc0-trinity-dev amd64 4:14.0.6-0debian10.0.0+0~a [189 kB]
96% [17 libartsc0-trinity-dev 16.0 kB/189 kB 8%] 3,329 kB/s 3s
97% [Waiting for headers] 3,329 kB/s 3s
Get:18 https://q4os.org/qtderepo buster/main amd64 libtqtinterface-dev amd64 4:14.0.6-0debian10.0.0+0~a [161 kB]
97% [18 libtqtinterface-dev 16.0 kB/161 kB 10%] 3,329 kB/s 3s
Get:19 https://q4os.org/qtderepo buster/main amd64 libarts1-trinity-dev amd64 4:14.0.6-0debian10.0.0+0~a [165 kB]
97% [19 libarts1-trinity-dev 16.0 kB/165 kB 10%] 3,329 kB/s 3s
Get:20 https://q4os.org/qtderepo buster/main amd64 libdbus-1-tqt-dev amd64 4:14.0.6-0debian10.0.0+0~a [97.6 kB]
97% [20 libdbus-1-tqt-dev 16.0 kB/97.6 kB 16%] 3,329 kB/s 3s
Get:21 https://q4os.org/qtderepo buster/main amd64 libjasper-dev amd64 1.900.1-debian1-2.5debian10.0.0+5~a [524 kB]
97% [21 libjasper-dev 16.0 kB/524 kB 3%] 3,329 kB/s 3s
97% [Waiting for headers] 1,482 kB/s 7s
Get:22 https://q4os.org/qtderepo buster/main amd64 libtqt3-compat-headers amd64 4:14.0.6-0debian10.0.0+0~a [52.1 kB]
97% [22 libtqt3-compat-headers 16.1 kB/52.1 kB 31%] 1,482 kB/s 7s
Get:23 https://q4os.org/qtderepo buster/main amd64 tdecachegrind-trinity amd64 4:14.0.6-0debian10.0.0+0~a [441 kB]
97% [23 tdecachegrind-trinity 10.0 kB/441 kB 2%] 1,482 kB/s 7s
Get:24 https://q4os.org/qtderepo buster/main amd64 libr-dev amd64 4:14.0.6-0debian10.0.0+0~a [38.7 kB]
97% [24 libr-dev 16.1 kB/38.7 kB 41%] 1,482 kB/s 7s
Get:25 https://q4os.org/qtderepo buster/main amd64 tdelibs14-trinity-dev amd64 4:14.0.6-0debian10.0.0+0~a.2 [1,159 kB]
97% [25 tdelibs14-trinity-dev 16.0 kB/1,159 kB 1%] 1,482 kB/s 7s
98% [Waiting for headers] 1,482 kB/s 6s
Get:26 https://q4os.org/qtderepo buster/main amd64 tdevelop-trinity-doc all 4:14.0.6-0debian10.0.0+0~a [2,860 kB]
98% [26 tdevelop-trinity-doc 8,035 B/2,860 kB 0%] 1,482 kB/s 6s
98% [26 tdevelop-trinity-doc 2,441 kB/2,860 kB 85%] 1,482 kB/s 5s
98% [Waiting for headers] 1,482 kB/s 4s
Get:27 https://q4os.org/qtderepo buster/main amd64 tqt3-doc all 4:14.0.6-0debian10.0.0+0~a [3,964 kB]
99% [27 tqt3-doc 2,850 kB/3,964 kB 72%] 1,482 kB/s 2s
99% [Waiting for headers] 1,482 kB/s 2s
Get:28 https://q4os.org/qtderepo buster/main amd64 tqt3-assistant amd64 4:14.0.6-0debian10.0.0+0~a [242 kB]
99% [28 tqt3-assistant 28.7 kB/242 kB 12%] 1,482 kB/s 2s
99% [Working] 1,482 kB/s 1s
Get:29 https://q4os.org/qtderepo buster/main amd64 tqt3-designer amd64 4:14.0.6-0debian10.0.0+0~a [2,498 kB]
99% [29 tqt3-designer 16.0 kB/2,498 kB 1%] 1,482 kB/s 1s
100% [Waiting for headers] 1,482 kB/s 0s
Get:30 https://q4os.org/qtderepo buster/main amd64 tqt3-linguist amd64 4:14.0.6-0debian10.0.0+0~a [265 kB]
100% [30 tqt3-linguist 11.3 kB/265 kB 4%] 1,482 kB/s 0s
Get:31 https://q4os.org/qtderepo buster/main amd64 tqt3-qtconfig amd64 4:14.0.6-0debian10.0.0+0~a [52.3 kB]
100% [31 tqt3-qtconfig 8,417 B/52.3 kB 16%] 1,482 kB/s 0s
100% [Working] 1,482 kB/s 0s
Fetched 425 MB in 58s (7,394 kB/s)
Download complete and in download only mode
Downloading packages ... Done
Copying system packages ...
Reading package lists... 100%
Reading package lists... Done
Building dependency tree
Reading state information... 0%
The following packages were automatically installed and are no longer required:
libappindicator3-1 libindicator3-7
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
binfmt-support binutils-dev bzip2-doc checkinstall clang clang-7 cmake
cmake-data comerr-dev cvs gdb geoclue-2.0 gettext graphviz hspell
icu-devtools kdevdesigner-trinity kdiff3-trinity kdiff3-trinity-doc
khexedit-trinity krb5-multidev lib32gcc1 lib32stdc++6 libacl1-dev libapr1
libaprutil1 libart-2.0-dev libarts1-trinity-dev libartsc0-trinity-dev
libasound2-dev libaspell-dev libattr1-dev libaudio-dev libaudiofile-dev
libavahi-client-dev libavahi-common-dev libbabeltrace1 libblkid-dev
libbz2-dev libc6-dbg libc6-i386 libcdt5 libcgraph6 libclang-common-7-dev
libclang1-7 libcups2-dev libcupsfilters-dev libcupsimage2-dev
libcvsservice0-trinity libdbus-1-dev libdbus-1-tqt-dev libdrm-dev libdw1
libexpat1-dev libffi-dev libfontconfig1-dev libfontenc-dev libfreetype6-dev
libgl1-mesa-dev libgles1 libglib2.0-dev libglib2.0-dev-bin libglu1-mesa-dev
libglvnd-core-dev libglvnd-dev libgssrpc4 libgts-0.7-5 libgts-bin libgvc6
libgvpr2 libice-dev libicu-dev libidn11-dev libilmbase-dev libipt2
libjasper-dev libjbig-dev libjpeg-dev libjpeg62-turbo-dev libjsoncpp1
libkadm5clnt-mit11 libkadm5srv-mit11 libkdb5-9 libkrb5-dev liblab-gamut1
liblcms2-dev libltdl-dev liblua50 liblua50-dev liblualib50 liblualib50-dev
liblzma-dev libmad0-dev libmbim-glib4 libmbim-proxy libmng-dev libmount-dev
libncurses-dev libobjc-8-dev libogg-dev libomp-7-dev libomp5-7
libopenexr-dev libopengl0 libpathplan4 libpciaccess-dev libpcre16-3
libpcre3-dev libpcre32-3 libpcrecpp0v5 libpixman-1-dev libpng-dev
libpng-tools libqbscore1.12 libqbsqtprofilesetup1.12 libqmi-glib5
libqmi-proxy libqt5designer5 libqt5designercomponents5 libqt5help5
libqt5positioning5 libqt5quick5 libqt5quicktest5 libqt5quickwidgets5
libqt5sensors5 libqt5serialport5 libqt5webchannel5 libqt5webkit5
libqt5xmlpatterns5 libr-dev librhash0 libsasl2-dev libselinux1-dev
libsepol1-dev libserf-1-1 libsm-dev libssl-dev libsvn1 libtiff-dev
libtiffxx5 libtinfo-dev libtool libtqt3-compat-headers libtqt3-headers
libtqt3-mt-dev libtqtinterface-dev libudev-dev libutf8proc2 libuv1
libvorbis-dev libx11-xcb-dev libxcb-dri2-0-dev libxcb-dri3-dev
libxcb-glx0-dev libxcb-present-dev libxcb-randr0-dev libxcb-render0-dev
libxcb-shape0-dev libxcb-sync-dev libxcb-xfixes0-dev libxcomposite-dev
libxcursor-dev libxdamage-dev libxdot4 libxfixes-dev libxfont-dev libxft-dev
libxi-dev libxinerama-dev libxkbfile-dev libxml2-dev libxml2-utils
libxmu-dev libxmu-headers libxrandr-dev libxrender-dev libxshmfence-dev
libxslt1-dev libxt-dev libxxf86vm-dev llvm-7 llvm-7-dev llvm-7-runtime lua50
mc mc-data mesa-common-dev modemmanager pkg-config python3-distutils
python3-lib2to3 qbs-common qdoc-qt5 qml-module-qtgraphicaleffects
qml-module-qtqml-models2 qml-module-qtquick-controls
qml-module-qtquick-layouts qml-module-qtquick-window2 qml-module-qtquick2
qmlscene qt3d5-doc qt5-assistant qt5-doc qt5-qmltooling-plugins
qtbase5-dev-tools qtbase5-doc qtcharts5-doc qtconnectivity5-doc qtcreator
qtcreator-data qtcreator-doc qtdeclarative5-dev-tools qtdeclarative5-doc
qtgraphicaleffects5-doc qtlocation5-doc qtmultimedia5-doc
qtquickcontrols2-5-doc qtquickcontrols5-doc qtscript5-doc qtsensors5-doc
qtserialport5-doc qtsvg5-doc qttools5-dev-tools qttools5-doc
qtvirtualkeyboard5-doc qtwayland5-doc qtwebchannel5-doc qtwebengine5-doc
qtwebsockets5-doc qtwebview5-doc qtx11extras5-doc qtxmlpatterns5-dev-tools
qtxmlpatterns5-doc reprepro tdecachegrind-trinity tdelibs14-trinity-dev
tdevelop-data-trinity tdevelop-trinity tdevelop-trinity-doc tqt3-apps-dev
tqt3-assistant tqt3-designer tqt3-dev-tools tqt3-doc tqt3-linguist
tqt3-qtconfig uuid-dev valgrind valgrind-dbg x11proto-composite-dev
x11proto-damage-dev x11proto-fixes-dev x11proto-input-dev x11proto-randr-dev
x11proto-xf86vidmode-dev x11proto-xinerama-dev xfonts-terminus
xserver-xorg-dev zlib1g-dev
Suggested packages:
clang-7-doc cmake-doc ninja-build doc-base mksh rcs gdb-doc gdbserver
gettext-doc autopoint libasprintf-dev libgettextpo-dev graphviz-doc krb5-doc
libasound2-doc aspell-doc freetype2-doc libglib2.0-doc krb5-user libice-doc
icu-doc libtool-doc liblzma-doc ncurses-doc libomp-7-doc libsm-doc
libssl-doc gfortran | fortran95-compiler gcj-jdk libtqt3-i18n libxt-doc
llvm-7-doc arj catdvi | texlive-binaries dbview djvulibre-bin epub-utils gv
links | w3m | lynx odt2txt python-boto python-tz qtbase5-dev clazy git
kate-data subversion inoticoming lzip tdecachegrind-converters-trinity
tdesdk-trinity-doc-html sgmltools-lite kbabel-trinity tdeiconedit-trinity
tdesdk-scripts-trinity exuberant-ctags tdelibs14-trinity-doc
libtqtinterface-doc valgrind-mpi kcachegrind alleyoop valkyrie
xfonts-terminus-oblique
Recommended packages:
valgrind-callgrind-trinity | valgrind-calltree-trinity
python3-lib2to3 q4os-devpack qbs-common qdoc-qt5
qml-module-qtgraphicaleffects qml-module-qtqml-models2
qml-module-qtquick-controls qml-module-qtquick-layouts
qml-module-qtquick-window2 qml-module-qtquick2 qmlscene qt3d5-doc
qt5-assistant qt5-doc qt5-qmltooling-plugins qtbase5-dev-tools qtbase5-doc
qtcharts5-doc qtconnectivity5-doc qtcreator qtcreator-data qtcreator-doc
qtdeclarative5-dev-tools qtdeclarative5-doc qtgraphicaleffects5-doc
qtlocation5-doc qtmultimedia5-doc qtquickcontrols2-5-doc
qtquickcontrols5-doc qtscript5-doc qtsensors5-doc qtserialport5-doc
qtsvg5-doc qttools5-dev-tools qttools5-doc qtvirtualkeyboard5-doc
qtwayland5-doc qtwebchannel5-doc qtwebengine5-doc qtwebsockets5-doc
qtwebview5-doc qtx11extras5-doc qtxmlpatterns5-dev-tools qtxmlpatterns5-doc
reprepro tdecachegrind-trinity tdelibs14-trinity-dev tdevelop-data-trinity
tdevelop-trinity tdevelop-trinity-doc tqt3-apps-dev tqt3-assistant
tqt3-designer tqt3-dev-tools tqt3-doc tqt3-linguist tqt3-qtconfig uuid-dev
valgrind valgrind-dbg x11proto-composite-dev x11proto-damage-dev
0 upgraded, 260 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/425 MB of archives.
After this operation, 1,173 MB of additional disk space will be used.
Extracting templates from packages: 100%
Selecting previously unselected package libqt5positioning5:amd64.
(Reading database ... 100%
(Reading database ... 249277 files and directories currently installed.)
Preparing to unpack .../000-libqt5positioning5_5.11.3+dfsg-2_amd64.deb ...
Unpacking libqt5positioning5:amd64 (5.11.3+dfsg-2) ...
Selecting previously unselected package libqt5quick5:amd64.
Preparing to unpack .../001-libqt5quick5_5.11.3-4_amd64.deb ...
Unpacking libqt5quick5:amd64 (5.11.3-4) ...
Selecting previously unselected package libqt5sensors5:amd64.
Preparing to unpack .../002-libqt5sensors5_5.11.3-2_amd64.deb ...
Unpacking libqt5sensors5:amd64 (5.11.3-2) ...
Selecting previously unselected package libqt5webchannel5:amd64.
Preparing to unpack .../003-libqt5webchannel5_5.11.3-2_amd64.deb ...
Unpacking libqt5webchannel5:amd64 (5.11.3-2) ...
Selecting previously unselected package libqt5webkit5:amd64.
Preparing to unpack .../004-libqt5webkit5_5.212.0~alpha2-21_amd64.deb ...
Unpacking libqt5webkit5:amd64 (5.212.0~alpha2-21) ...
Selecting previously unselected package qml-module-qtquick-window2:amd64.
Preparing to unpack .../005-qml-module-qtquick-window2_5.11.3-4_amd64.deb ...
Unpacking qml-module-qtquick-window2:amd64 (5.11.3-4) ...
Selecting previously unselected package qml-module-qtquick2:amd64.
Preparing to unpack .../006-qml-module-qtquick2_5.11.3-4_amd64.deb ...
Unpacking qml-module-qtquick2:amd64 (5.11.3-4) ...
Selecting previously unselected package qml-module-qtgraphicaleffects:amd64.
Preparing to unpack .../007-qml-module-qtgraphicaleffects_5.11.3-2_amd64.deb ...
Unpacking qml-module-qtgraphicaleffects:amd64 (5.11.3-2) ...
Selecting previously unselected package qml-module-qtquick-layouts:amd64.
Preparing to unpack .../008-qml-module-qtquick-layouts_5.11.3-4_amd64.deb ...
Unpacking qml-module-qtquick-layouts:amd64 (5.11.3-4) ...
Selecting previously unselected package qml-module-qtquick-controls:amd64.
Preparing to unpack .../009-qml-module-qtquick-controls_5.11.3-2_amd64.deb ...
Unpacking qml-module-qtquick-controls:amd64 (5.11.3-2) ...
Selecting previously unselected package binfmt-support.
Preparing to unpack .../010-binfmt-support_2.2.0-2_amd64.deb ...
Unpacking binfmt-support (2.2.0-2) ...
Selecting previously unselected package binutils-dev.
Preparing to unpack .../011-binutils-dev_2.31.1-16_amd64.deb ...
Unpacking binutils-dev (2.31.1-16) ...
Selecting previously unselected package bzip2-doc.
Preparing to unpack .../012-bzip2-doc_1.0.6-9.2~deb10u1_all.deb ...
Unpacking bzip2-doc (1.0.6-9.2~deb10u1) ...
Selecting previously unselected package checkinstall.
Preparing to unpack .../013-checkinstall_1.6.2+git20170426.d24a630-2~bpo10+1_amd64.deb ...
Unpacking checkinstall (1.6.2+git20170426.d24a630-2~bpo10+1) ...
Selecting previously unselected package libobjc-8-dev:amd64.
Preparing to unpack .../014-libobjc-8-dev_8.3.0-6_amd64.deb ...
Unpacking libobjc-8-dev:amd64 (8.3.0-6) ...
Selecting previously unselected package libc6-i386.
Preparing to unpack .../015-libc6-i386_2.28-10_amd64.deb ...
Unpacking libc6-i386 (2.28-10) ...
Selecting previously unselected package lib32gcc1.
Preparing to unpack .../016-lib32gcc1_1%3a8.3.0-6_amd64.deb ...
Unpacking lib32gcc1 (1:8.3.0-6) ...
Selecting previously unselected package lib32stdc++6.
Preparing to unpack .../017-lib32stdc++6_8.3.0-6_amd64.deb ...
Unpacking lib32stdc++6 (8.3.0-6) ...
Selecting previously unselected package libclang-common-7-dev.
Preparing to unpack .../018-libclang-common-7-dev_1%3a7.0.1-8+deb10u2_amd64.deb ...
Unpacking libclang-common-7-dev (1:7.0.1-8+deb10u2) ...
Selecting previously unselected package libclang1-7.
Preparing to unpack .../019-libclang1-7_1%3a7.0.1-8+deb10u2_amd64.deb ...
Unpacking libclang1-7 (1:7.0.1-8+deb10u2) ...
Selecting previously unselected package clang-7.
Preparing to unpack .../020-clang-7_1%3a7.0.1-8+deb10u2_amd64.deb ...
Unpacking clang-7 (1:7.0.1-8+deb10u2) ...
Selecting previously unselected package clang.
Preparing to unpack .../021-clang_1%3a7.0-47_amd64.deb ...
Unpacking clang (1:7.0-47) ...
Selecting previously unselected package cmake-data.
Preparing to unpack .../022-cmake-data_3.13.4-1_all.deb ...
Unpacking cmake-data (3.13.4-1) ...
Selecting previously unselected package libjsoncpp1:amd64.
Preparing to unpack .../023-libjsoncpp1_1.7.4-3_amd64.deb ...
Unpacking libjsoncpp1:amd64 (1.7.4-3) ...
Selecting previously unselected package librhash0:amd64.
Preparing to unpack .../024-librhash0_1.3.8-1_amd64.deb ...
Unpacking librhash0:amd64 (1.3.8-1) ...
Selecting previously unselected package libuv1:amd64.
Preparing to unpack .../025-libuv1_1.24.1-1_amd64.deb ...
Unpacking libuv1:amd64 (1.24.1-1) ...
Selecting previously unselected package cmake.
Preparing to unpack .../026-cmake_3.13.4-1_amd64.deb ...
Unpacking cmake (3.13.4-1) ...
Selecting previously unselected package comerr-dev:amd64.
Preparing to unpack .../027-comerr-dev_2.1-1.44.5-1+deb10u3_amd64.deb ...
Unpacking comerr-dev:amd64 (2.1-1.44.5-1+deb10u3) ...
Selecting previously unselected package cvs.
Preparing to unpack .../028-cvs_2%3a1.12.13+real-27_amd64.deb ...
Unpacking cvs (2:1.12.13+real-27) ...
Selecting previously unselected package libdw1:amd64.
Preparing to unpack .../029-libdw1_0.176-1.1_amd64.deb ...
Unpacking libdw1:amd64 (0.176-1.1) ...
Selecting previously unselected package libbabeltrace1:amd64.
Preparing to unpack .../030-libbabeltrace1_1.5.6-2+deb10u1_amd64.deb ...
Unpacking libbabeltrace1:amd64 (1.5.6-2+deb10u1) ...
Selecting previously unselected package libipt2.
Preparing to unpack .../031-libipt2_2.0-2_amd64.deb ...
Unpacking libipt2 (2.0-2) ...
Selecting previously unselected package gdb.
Preparing to unpack .../032-gdb_8.2.1-2+b3_amd64.deb ...
Unpacking gdb (8.2.1-2+b3) ...
Selecting previously unselected package geoclue-2.0.
Preparing to unpack .../033-geoclue-2.0_2.5.2-1_amd64.deb ...
Unpacking geoclue-2.0 (2.5.2-1) ...
Selecting previously unselected package gettext.
Preparing to unpack .../034-gettext_0.19.8.1-9_amd64.deb ...
Unpacking gettext (0.19.8.1-9) ...
Selecting previously unselected package libcdt5.
Preparing to unpack .../035-libcdt5_2.40.1-6_amd64.deb ...
Unpacking libcdt5 (2.40.1-6) ...
Selecting previously unselected package libcgraph6.
Preparing to unpack .../036-libcgraph6_2.40.1-6_amd64.deb ...
Unpacking libcgraph6 (2.40.1-6) ...
Selecting previously unselected package libgts-0.7-5:amd64.
Preparing to unpack .../037-libgts-0.7-5_0.7.6+darcs121130-4_amd64.deb ...
Unpacking libgts-0.7-5:amd64 (0.7.6+darcs121130-4) ...
Selecting previously unselected package libpathplan4.
Preparing to unpack .../038-libpathplan4_2.40.1-6_amd64.deb ...
Unpacking libpathplan4 (2.40.1-6) ...
Selecting previously unselected package libxdot4.
Preparing to unpack .../039-libxdot4_2.40.1-6_amd64.deb ...
Unpacking libxdot4 (2.40.1-6) ...
Selecting previously unselected package libgvc6.
Preparing to unpack .../040-libgvc6_2.40.1-6_amd64.deb ...
Unpacking libgvc6 (2.40.1-6) ...
Selecting previously unselected package libgvpr2.
Preparing to unpack .../041-libgvpr2_2.40.1-6_amd64.deb ...
Unpacking libgvpr2 (2.40.1-6) ...
Selecting previously unselected package liblab-gamut1.
Preparing to unpack .../042-liblab-gamut1_2.40.1-6_amd64.deb ...
Unpacking liblab-gamut1 (2.40.1-6) ...
Selecting previously unselected package graphviz.
Preparing to unpack .../043-graphviz_2.40.1-6_amd64.deb ...
Unpacking graphviz (2.40.1-6) ...
Selecting previously unselected package hspell.
Preparing to unpack .../044-hspell_1.4-3_amd64.deb ...
Unpacking hspell (1.4-3) ...
Selecting previously unselected package icu-devtools.
Preparing to unpack .../045-icu-devtools_63.1-6+deb10u1_amd64.deb ...
Unpacking icu-devtools (63.1-6+deb10u1) ...
Selecting previously unselected package libapr1:amd64.
Preparing to unpack .../046-libapr1_1.6.5-1+b1_amd64.deb ...
Unpacking libapr1:amd64 (1.6.5-1+b1) ...
Selecting previously unselected package libcvsservice0-trinity.
Preparing to unpack .../047-libcvsservice0-trinity_4%3a14.0.6-0debian10.0.0+0~a_amd64.deb ...
Unpacking libcvsservice0-trinity (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package libaprutil1:amd64.
Preparing to unpack .../048-libaprutil1_1.6.1-4_amd64.deb ...
Unpacking libaprutil1:amd64 (1.6.1-4) ...
Selecting previously unselected package libserf-1-1:amd64.
Preparing to unpack .../049-libserf-1-1_1.3.9-7+b10_amd64.deb ...
Unpacking libserf-1-1:amd64 (1.3.9-7+b10) ...
Selecting previously unselected package libutf8proc2:amd64.
Preparing to unpack .../050-libutf8proc2_2.3.0-1_amd64.deb ...
Unpacking libutf8proc2:amd64 (2.3.0-1) ...
Selecting previously unselected package libsvn1:amd64.
Preparing to unpack .../051-libsvn1_1.10.4-1+deb10u1_amd64.deb ...
Unpacking libsvn1:amd64 (1.10.4-1+deb10u1) ...
Selecting previously unselected package tdevelop-data-trinity.
Preparing to unpack .../052-tdevelop-data-trinity_4%3a14.0.6-0debian10.0.0+0~a_all.deb ...
Unpacking tdevelop-data-trinity (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package tdevelop-trinity.
Preparing to unpack .../053-tdevelop-trinity_4%3a14.0.6-0debian10.0.0+0~a_amd64.deb ...
Unpacking tdevelop-trinity (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package x11proto-randr-dev.
Preparing to unpack .../054-x11proto-randr-dev_2018.4-4_all.deb ...
Unpacking x11proto-randr-dev (2018.4-4) ...
Selecting previously unselected package libxrender-dev:amd64.
Preparing to unpack .../055-libxrender-dev_1%3a0.9.10-1_amd64.deb ...
Unpacking libxrender-dev:amd64 (1:0.9.10-1) ...
Selecting previously unselected package libxrandr-dev:amd64.
Preparing to unpack .../056-libxrandr-dev_2%3a1.5.1-1_amd64.deb ...
Unpacking libxrandr-dev:amd64 (2:1.5.1-1) ...
Selecting previously unselected package libice-dev:amd64.
Preparing to unpack .../057-libice-dev_2%3a1.0.9-2_amd64.deb ...
Unpacking libice-dev:amd64 (2:1.0.9-2) ...
Selecting previously unselected package libsm-dev:amd64.
Preparing to unpack .../058-libsm-dev_2%3a1.2.3-1_amd64.deb ...
Unpacking libsm-dev:amd64 (2:1.2.3-1) ...
Selecting previously unselected package libxt-dev:amd64.
Preparing to unpack .../059-libxt-dev_1%3a1.1.5-1+b3_amd64.deb ...
Unpacking libxt-dev:amd64 (1:1.1.5-1+b3) ...
Selecting previously unselected package libxmu-headers.
Preparing to unpack .../060-libxmu-headers_2%3a1.1.2-2_all.deb ...
Unpacking libxmu-headers (2:1.1.2-2) ...
Selecting previously unselected package libxmu-dev:amd64.
Preparing to unpack .../061-libxmu-dev_2%3a1.1.2-2+b3_amd64.deb ...
Unpacking libxmu-dev:amd64 (2:1.1.2-2+b3) ...
Selecting previously unselected package x11proto-fixes-dev.
Preparing to unpack .../062-x11proto-fixes-dev_1%3a2018.4-4_all.deb ...
Unpacking x11proto-fixes-dev (1:2018.4-4) ...
Selecting previously unselected package libxfixes-dev:amd64.
Preparing to unpack .../063-libxfixes-dev_1%3a5.0.3-1_amd64.deb ...
Unpacking libxfixes-dev:amd64 (1:5.0.3-1) ...
Selecting previously unselected package libxcursor-dev:amd64.
Preparing to unpack .../064-libxcursor-dev_1%3a1.1.15-2_amd64.deb ...
Unpacking libxcursor-dev:amd64 (1:1.1.15-2) ...
Selecting previously unselected package uuid-dev:amd64.
Preparing to unpack .../065-uuid-dev_2.33.1-0.1_amd64.deb ...
Unpacking uuid-dev:amd64 (2.33.1-0.1) ...
Selecting previously unselected package x11proto-xinerama-dev.
Preparing to unpack .../066-x11proto-xinerama-dev_2018.4-4_all.deb ...
Unpacking x11proto-xinerama-dev (2018.4-4) ...
Selecting previously unselected package libxinerama-dev:amd64.
Preparing to unpack .../067-libxinerama-dev_2%3a1.1.4-2_amd64.deb ...
Unpacking libxinerama-dev:amd64 (2:1.1.4-2) ...
Selecting previously unselected package x11proto-input-dev.
Preparing to unpack .../068-x11proto-input-dev_2018.4-4_all.deb ...
Unpacking x11proto-input-dev (2018.4-4) ...
Selecting previously unselected package libxi-dev:amd64.
Preparing to unpack .../069-libxi-dev_2%3a1.7.9-1_amd64.deb ...
Unpacking libxi-dev:amd64 (2:1.7.9-1) ...
Selecting previously unselected package zlib1g-dev:amd64.
Preparing to unpack .../070-zlib1g-dev_1%3a1.2.11.dfsg-1_amd64.deb ...
Unpacking zlib1g-dev:amd64 (1:1.2.11.dfsg-1) ...
Selecting previously unselected package libjpeg62-turbo-dev:amd64.
Preparing to unpack .../071-libjpeg62-turbo-dev_1%3a1.5.2-2+b1_amd64.deb ...
Unpacking libjpeg62-turbo-dev:amd64 (1:1.5.2-2+b1) ...
Selecting previously unselected package libjpeg-dev.
Preparing to unpack .../072-libjpeg-dev_1%3a1.5.2-2_all.deb ...
Unpacking libjpeg-dev (1:1.5.2-2) ...
Selecting previously unselected package liblcms2-dev:amd64.
Preparing to unpack .../073-liblcms2-dev_2.9-3_amd64.deb ...
Unpacking liblcms2-dev:amd64 (2.9-3) ...
Selecting previously unselected package libmng-dev:amd64.
Preparing to unpack .../074-libmng-dev_1.0.10+dfsg-3.1+b5_amd64.deb ...
Unpacking libmng-dev:amd64 (1.0.10+dfsg-3.1+b5) ...
Selecting previously unselected package libpng-dev:amd64.
Preparing to unpack .../075-libpng-dev_1.6.36-6_amd64.deb ...
Unpacking libpng-dev:amd64 (1.6.36-6) ...
Selecting previously unselected package libexpat1-dev:amd64.
Preparing to unpack .../076-libexpat1-dev_2.2.6-2+deb10u1_amd64.deb ...
Unpacking libexpat1-dev:amd64 (2.2.6-2+deb10u1) ...
Selecting previously unselected package libfreetype6-dev:amd64.
Preparing to unpack .../077-libfreetype6-dev_2.9.1-3+deb10u1_amd64.deb ...
Unpacking libfreetype6-dev:amd64 (2.9.1-3+deb10u1) ...
Selecting previously unselected package pkg-config.
Preparing to unpack .../078-pkg-config_0.29-6_amd64.deb ...
Unpacking pkg-config (0.29-6) ...
Selecting previously unselected package libfontconfig1-dev:amd64.
Preparing to unpack .../079-libfontconfig1-dev_2.13.1-2_amd64.deb ...
Unpacking libfontconfig1-dev:amd64 (2.13.1-2) ...
Selecting previously unselected package libxft-dev:amd64.
Preparing to unpack .../080-libxft-dev_2.3.2-2_amd64.deb ...
Unpacking libxft-dev:amd64 (2.3.2-2) ...
Selecting previously unselected package libaudio-dev:amd64.
Preparing to unpack .../081-libaudio-dev_1.9.4-6_amd64.deb ...
Unpacking libaudio-dev:amd64 (1.9.4-6) ...
Selecting previously unselected package libjbig-dev:amd64.
Preparing to unpack .../082-libjbig-dev_2.1-3.1+b2_amd64.deb ...
Unpacking libjbig-dev:amd64 (2.1-3.1+b2) ...
Selecting previously unselected package liblzma-dev:amd64.
Preparing to unpack .../083-liblzma-dev_5.2.4-1_amd64.deb ...
Unpacking liblzma-dev:amd64 (5.2.4-1) ...
Selecting previously unselected package libtiffxx5:amd64.
Preparing to unpack .../084-libtiffxx5_4.1.0+git191117-2~deb10u1_amd64.deb ...
Unpacking libtiffxx5:amd64 (4.1.0+git191117-2~deb10u1) ...
Selecting previously unselected package libtiff-dev:amd64.
Preparing to unpack .../085-libtiff-dev_4.1.0+git191117-2~deb10u1_amd64.deb ...
Unpacking libtiff-dev:amd64 (4.1.0+git191117-2~deb10u1) ...
Selecting previously unselected package libcupsimage2-dev:amd64.
Preparing to unpack .../086-libcupsimage2-dev_2.2.10-6+deb10u3_amd64.deb ...
Unpacking libcupsimage2-dev:amd64 (2.2.10-6+deb10u3) ...
Selecting previously unselected package libcups2-dev:amd64.
Preparing to unpack .../087-libcups2-dev_2.2.10-6+deb10u3_amd64.deb ...
Unpacking libcups2-dev:amd64 (2.2.10-6+deb10u3) ...
Selecting previously unselected package libdrm-dev:amd64.
Preparing to unpack .../088-libdrm-dev_2.4.97-1_amd64.deb ...
Unpacking libdrm-dev:amd64 (2.4.97-1) ...
Selecting previously unselected package mesa-common-dev:amd64.
Preparing to unpack .../089-mesa-common-dev_18.3.6-2+deb10u1_amd64.deb ...
Unpacking mesa-common-dev:amd64 (18.3.6-2+deb10u1) ...
Selecting previously unselected package libglvnd-core-dev:amd64.
Preparing to unpack .../090-libglvnd-core-dev_1.1.0-1_amd64.deb ...
Unpacking libglvnd-core-dev:amd64 (1.1.0-1) ...
Selecting previously unselected package libgles1:amd64.
Preparing to unpack .../091-libgles1_1.1.0-1_amd64.deb ...
Unpacking libgles1:amd64 (1.1.0-1) ...
Selecting previously unselected package libopengl0:amd64.
Preparing to unpack .../092-libopengl0_1.1.0-1_amd64.deb ...
Unpacking libopengl0:amd64 (1.1.0-1) ...
Selecting previously unselected package libglvnd-dev:amd64.
Preparing to unpack .../093-libglvnd-dev_1.1.0-1_amd64.deb ...
Unpacking libglvnd-dev:amd64 (1.1.0-1) ...
Selecting previously unselected package libx11-xcb-dev:amd64.
Preparing to unpack .../094-libx11-xcb-dev_2%3a1.6.7-1+deb10u1_amd64.deb ...
Unpacking libx11-xcb-dev:amd64 (2:1.6.7-1+deb10u1) ...
Selecting previously unselected package libxcb-dri3-dev:amd64.
Preparing to unpack .../095-libxcb-dri3-dev_1.13.1-2_amd64.deb ...
Unpacking libxcb-dri3-dev:amd64 (1.13.1-2) ...
Selecting previously unselected package libxcb-render0-dev:amd64.
Preparing to unpack .../096-libxcb-render0-dev_1.13.1-2_amd64.deb ...
Unpacking libxcb-render0-dev:amd64 (1.13.1-2) ...
Selecting previously unselected package libxcb-randr0-dev:amd64.
Preparing to unpack .../097-libxcb-randr0-dev_1.13.1-2_amd64.deb ...
Unpacking libxcb-randr0-dev:amd64 (1.13.1-2) ...
Selecting previously unselected package libxcb-shape0-dev:amd64.
Preparing to unpack .../098-libxcb-shape0-dev_1.13.1-2_amd64.deb ...
Unpacking libxcb-shape0-dev:amd64 (1.13.1-2) ...
Selecting previously unselected package libxcb-xfixes0-dev:amd64.
Preparing to unpack .../099-libxcb-xfixes0-dev_1.13.1-2_amd64.deb ...
Unpacking libxcb-xfixes0-dev:amd64 (1.13.1-2) ...
Selecting previously unselected package libxcb-sync-dev:amd64.
Preparing to unpack .../100-libxcb-sync-dev_1.13.1-2_amd64.deb ...
Unpacking libxcb-sync-dev:amd64 (1.13.1-2) ...
Selecting previously unselected package libxcb-present-dev:amd64.
Preparing to unpack .../101-libxcb-present-dev_1.13.1-2_amd64.deb ...
Unpacking libxcb-present-dev:amd64 (1.13.1-2) ...
Selecting previously unselected package libxshmfence-dev:amd64.
Preparing to unpack .../102-libxshmfence-dev_1.3-1_amd64.deb ...
Unpacking libxshmfence-dev:amd64 (1.3-1) ...
Selecting previously unselected package libxcb-dri2-0-dev:amd64.
Preparing to unpack .../103-libxcb-dri2-0-dev_1.13.1-2_amd64.deb ...
Unpacking libxcb-dri2-0-dev:amd64 (1.13.1-2) ...
Selecting previously unselected package libxcb-glx0-dev:amd64.
Preparing to unpack .../104-libxcb-glx0-dev_1.13.1-2_amd64.deb ...
Unpacking libxcb-glx0-dev:amd64 (1.13.1-2) ...
Selecting previously unselected package x11proto-damage-dev.
Preparing to unpack .../105-x11proto-damage-dev_1%3a2018.4-4_all.deb ...
Unpacking x11proto-damage-dev (1:2018.4-4) ...
Selecting previously unselected package libxdamage-dev:amd64.
Preparing to unpack .../106-libxdamage-dev_1%3a1.1.4-3+b3_amd64.deb ...
Unpacking libxdamage-dev:amd64 (1:1.1.4-3+b3) ...
Selecting previously unselected package x11proto-xf86vidmode-dev.
Preparing to unpack .../107-x11proto-xf86vidmode-dev_2018.4-4_all.deb ...
Unpacking x11proto-xf86vidmode-dev (2018.4-4) ...
Selecting previously unselected package libxxf86vm-dev:amd64.
Preparing to unpack .../108-libxxf86vm-dev_1%3a1.1.4-1+b2_amd64.deb ...
Unpacking libxxf86vm-dev:amd64 (1:1.1.4-1+b2) ...
Selecting previously unselected package libgl1-mesa-dev:amd64.
Preparing to unpack .../109-libgl1-mesa-dev_18.3.6-2+deb10u1_amd64.deb ...
Unpacking libgl1-mesa-dev:amd64 (18.3.6-2+deb10u1) ...
Selecting previously unselected package libglu1-mesa-dev:amd64.
Preparing to unpack .../110-libglu1-mesa-dev_9.0.0-2.1+b3_amd64.deb ...
Unpacking libglu1-mesa-dev:amd64 (9.0.0-2.1+b3) ...
Selecting previously unselected package libtqt3-headers.
Preparing to unpack .../111-libtqt3-headers_4%3a14.0.6-0debian10.0.0+0~a_amd64.deb ...
Unpacking libtqt3-headers (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package tqt3-dev-tools.
Preparing to unpack .../112-tqt3-dev-tools_4%3a14.0.6-0debian10.0.0+0~a_amd64.deb ...
Unpacking tqt3-dev-tools (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package libtqt3-mt-dev.
Preparing to unpack .../113-libtqt3-mt-dev_4%3a14.0.6-0debian10.0.0+0~a_amd64.deb ...
Unpacking libtqt3-mt-dev (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package tqt3-apps-dev.
Preparing to unpack .../114-tqt3-apps-dev_4%3a14.0.6-0debian10.0.0+0~a_amd64.deb ...
Unpacking tqt3-apps-dev (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package kdevdesigner-trinity.
Preparing to unpack .../115-kdevdesigner-trinity_4%3a14.0.6-0debian10.0.0+0~a_amd64.deb ...
Unpacking kdevdesigner-trinity (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package kdiff3-trinity.
Preparing to unpack .../116-kdiff3-trinity_4%3a14.0.6-0debian10.0.0+0~a_amd64.deb ...
Unpacking kdiff3-trinity (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package kdiff3-trinity-doc.
Preparing to unpack .../117-kdiff3-trinity-doc_4%3a14.0.6-0debian10.0.0+0~a_all.deb ...
Unpacking kdiff3-trinity-doc (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package khexedit-trinity.
Preparing to unpack .../118-khexedit-trinity_4%3a14.0.6-0debian10.0.0+0~a_amd64.deb ...
Unpacking khexedit-trinity (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package libgssrpc4:amd64.
Preparing to unpack .../119-libgssrpc4_1.17-3_amd64.deb ...
Unpacking libgssrpc4:amd64 (1.17-3) ...
Selecting previously unselected package libkdb5-9:amd64.
Preparing to unpack .../120-libkdb5-9_1.17-3_amd64.deb ...
Unpacking libkdb5-9:amd64 (1.17-3) ...
Selecting previously unselected package libkadm5srv-mit11:amd64.
Preparing to unpack .../121-libkadm5srv-mit11_1.17-3_amd64.deb ...
Unpacking libkadm5srv-mit11:amd64 (1.17-3) ...
Selecting previously unselected package libkadm5clnt-mit11:amd64.
Preparing to unpack .../122-libkadm5clnt-mit11_1.17-3_amd64.deb ...
Unpacking libkadm5clnt-mit11:amd64 (1.17-3) ...
Selecting previously unselected package krb5-multidev:amd64.
Preparing to unpack .../123-krb5-multidev_1.17-3_amd64.deb ...
Unpacking krb5-multidev:amd64 (1.17-3) ...
Selecting previously unselected package libattr1-dev:amd64.
Preparing to unpack .../124-libattr1-dev_1%3a2.4.48-4_amd64.deb ...
Unpacking libattr1-dev:amd64 (1:2.4.48-4) ...
Selecting previously unselected package libacl1-dev:amd64.
Preparing to unpack .../125-libacl1-dev_2.2.53-4_amd64.deb ...
Unpacking libacl1-dev:amd64 (2.2.53-4) ...
Selecting previously unselected package libart-2.0-dev.
Preparing to unpack .../126-libart-2.0-dev_4%3a14.0.6-0debian10.0.0+0~a_amd64.deb ...
Unpacking libart-2.0-dev (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package libffi-dev:amd64.
Preparing to unpack .../127-libffi-dev_3.2.1-9_amd64.deb ...
Unpacking libffi-dev:amd64 (3.2.1-9) ...
Selecting previously unselected package python3-lib2to3.
Preparing to unpack .../128-python3-lib2to3_3.7.3-1_all.deb ...
Unpacking python3-lib2to3 (3.7.3-1) ...
Selecting previously unselected package python3-distutils.
Preparing to unpack .../129-python3-distutils_3.7.3-1_all.deb ...
Unpacking python3-distutils (3.7.3-1) ...
Selecting previously unselected package libglib2.0-dev-bin.
Preparing to unpack .../130-libglib2.0-dev-bin_2.58.3-2+deb10u2_amd64.deb ...
Unpacking libglib2.0-dev-bin (2.58.3-2+deb10u2) ...
Selecting previously unselected package libblkid-dev:amd64.
Preparing to unpack .../131-libblkid-dev_2.33.1-0.1_amd64.deb ...
Unpacking libblkid-dev:amd64 (2.33.1-0.1) ...
Selecting previously unselected package libmount-dev:amd64.
Preparing to unpack .../132-libmount-dev_2.33.1-0.1_amd64.deb ...
Unpacking libmount-dev:amd64 (2.33.1-0.1) ...
Selecting previously unselected package libpcre16-3:amd64.
Preparing to unpack .../133-libpcre16-3_2%3a8.39-12_amd64.deb ...
Unpacking libpcre16-3:amd64 (2:8.39-12) ...
Selecting previously unselected package libpcre32-3:amd64.
Preparing to unpack .../134-libpcre32-3_2%3a8.39-12_amd64.deb ...
Unpacking libpcre32-3:amd64 (2:8.39-12) ...
Selecting previously unselected package libpcrecpp0v5:amd64.
Preparing to unpack .../135-libpcrecpp0v5_2%3a8.39-12_amd64.deb ...
Unpacking libpcrecpp0v5:amd64 (2:8.39-12) ...
Selecting previously unselected package libpcre3-dev:amd64.
Preparing to unpack .../136-libpcre3-dev_2%3a8.39-12_amd64.deb ...
Unpacking libpcre3-dev:amd64 (2:8.39-12) ...
Selecting previously unselected package libsepol1-dev:amd64.
Preparing to unpack .../137-libsepol1-dev_2.8-1_amd64.deb ...
Unpacking libsepol1-dev:amd64 (2.8-1) ...
Selecting previously unselected package libselinux1-dev:amd64.
Preparing to unpack .../138-libselinux1-dev_2.8-1+b1_amd64.deb ...
Unpacking libselinux1-dev:amd64 (2.8-1+b1) ...
Selecting previously unselected package libglib2.0-dev:amd64.
Preparing to unpack .../139-libglib2.0-dev_2.58.3-2+deb10u2_amd64.deb ...
Unpacking libglib2.0-dev:amd64 (2.58.3-2+deb10u2) ...
Selecting previously unselected package libartsc0-trinity-dev.
Preparing to unpack .../140-libartsc0-trinity-dev_4%3a14.0.6-0debian10.0.0+0~a_amd64.deb ...
Unpacking libartsc0-trinity-dev (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package libasound2-dev:amd64.
Preparing to unpack .../141-libasound2-dev_1.1.8-1_amd64.deb ...
Unpacking libasound2-dev:amd64 (1.1.8-1) ...
Selecting previously unselected package libaudiofile-dev:amd64.
Preparing to unpack .../142-libaudiofile-dev_0.3.6-5_amd64.deb ...
Unpacking libaudiofile-dev:amd64 (0.3.6-5) ...
Selecting previously unselected package libogg-dev:amd64.
Preparing to unpack .../143-libogg-dev_1.3.2-1+b1_amd64.deb ...
Unpacking libogg-dev:amd64 (1.3.2-1+b1) ...
Selecting previously unselected package libvorbis-dev:amd64.
Preparing to unpack .../144-libvorbis-dev_1.3.6-2_amd64.deb ...
Unpacking libvorbis-dev:amd64 (1.3.6-2) ...
Selecting previously unselected package libmad0-dev.
Preparing to unpack .../145-libmad0-dev_0.15.1b-10_amd64.deb ...
Unpacking libmad0-dev (0.15.1b-10) ...
Selecting previously unselected package libtqtinterface-dev.
Preparing to unpack .../146-libtqtinterface-dev_4%3a14.0.6-0debian10.0.0+0~a_amd64.deb ...
Unpacking libtqtinterface-dev (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package libarts1-trinity-dev.
Preparing to unpack .../147-libarts1-trinity-dev_4%3a14.0.6-0debian10.0.0+0~a_amd64.deb ...
Unpacking libarts1-trinity-dev (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package libaspell-dev:amd64.
Preparing to unpack .../148-libaspell-dev_0.60.7~20110707-6_amd64.deb ...
Unpacking libaspell-dev:amd64 (0.60.7~20110707-6) ...
Selecting previously unselected package libavahi-common-dev:amd64.
Preparing to unpack .../149-libavahi-common-dev_0.7-4+b1_amd64.deb ...
Unpacking libavahi-common-dev:amd64 (0.7-4+b1) ...
Selecting previously unselected package libdbus-1-dev:amd64.
Preparing to unpack .../150-libdbus-1-dev_1.12.20-0+deb10u1_amd64.deb ...
Unpacking libdbus-1-dev:amd64 (1.12.20-0+deb10u1) ...
Selecting previously unselected package libavahi-client-dev:amd64.
Preparing to unpack .../151-libavahi-client-dev_0.7-4+b1_amd64.deb ...
Unpacking libavahi-client-dev:amd64 (0.7-4+b1) ...
Selecting previously unselected package libbz2-dev:amd64.
Preparing to unpack .../152-libbz2-dev_1.0.6-9.2~deb10u1_amd64.deb ...
Unpacking libbz2-dev:amd64 (1.0.6-9.2~deb10u1) ...
Selecting previously unselected package libc6-dbg:amd64.
Preparing to unpack .../153-libc6-dbg_2.28-10_amd64.deb ...
Unpacking libc6-dbg:amd64 (2.28-10) ...
Selecting previously unselected package libcupsfilters-dev:amd64.
Preparing to unpack .../154-libcupsfilters-dev_1.21.6-5_amd64.deb ...
Unpacking libcupsfilters-dev:amd64 (1.21.6-5) ...
Selecting previously unselected package libdbus-1-tqt-dev.
Preparing to unpack .../155-libdbus-1-tqt-dev_4%3a14.0.6-0debian10.0.0+0~a_amd64.deb ...
Unpacking libdbus-1-tqt-dev (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package libfontenc-dev:amd64.
Preparing to unpack .../156-libfontenc-dev_1%3a1.1.3-1+b2_amd64.deb ...
Unpacking libfontenc-dev:amd64 (1:1.1.3-1+b2) ...
Selecting previously unselected package libgts-bin.
Preparing to unpack .../157-libgts-bin_0.7.6+darcs121130-4_amd64.deb ...
Unpacking libgts-bin (0.7.6+darcs121130-4) ...
Selecting previously unselected package libicu-dev:amd64.
Preparing to unpack .../158-libicu-dev_63.1-6+deb10u1_amd64.deb ...
Unpacking libicu-dev:amd64 (63.1-6+deb10u1) ...
Selecting previously unselected package libidn11-dev:amd64.
Preparing to unpack .../159-libidn11-dev_1.33-2.2_amd64.deb ...
Unpacking libidn11-dev:amd64 (1.33-2.2) ...
Selecting previously unselected package libilmbase-dev.
Preparing to unpack .../160-libilmbase-dev_2.2.1-2_amd64.deb ...
Unpacking libilmbase-dev (2.2.1-2) ...
Selecting previously unselected package libjasper-dev.
Preparing to unpack .../161-libjasper-dev_1.900.1-debian1-2.5debian10.0.0+5~a_amd64.deb ...
Unpacking libjasper-dev (1.900.1-debian1-2.5debian10.0.0+5~a) ...
Selecting previously unselected package libkrb5-dev:amd64.
Preparing to unpack .../162-libkrb5-dev_1.17-3_amd64.deb ...
Unpacking libkrb5-dev:amd64 (1.17-3) ...
Selecting previously unselected package libltdl-dev:amd64.
Preparing to unpack .../163-libltdl-dev_2.4.6-9_amd64.deb ...
Unpacking libltdl-dev:amd64 (2.4.6-9) ...
Selecting previously unselected package liblua50.
Preparing to unpack .../164-liblua50_5.0.3-8+b1_amd64.deb ...
Unpacking liblua50 (5.0.3-8+b1) ...
Selecting previously unselected package liblualib50.
Preparing to unpack .../165-liblualib50_5.0.3-8+b1_amd64.deb ...
Unpacking liblualib50 (5.0.3-8+b1) ...
Selecting previously unselected package lua50.
Preparing to unpack .../166-lua50_5.0.3-8+b1_amd64.deb ...
Unpacking lua50 (5.0.3-8+b1) ...
Selecting previously unselected package liblua50-dev.
Preparing to unpack .../167-liblua50-dev_5.0.3-8+b1_amd64.deb ...
Unpacking liblua50-dev (5.0.3-8+b1) ...
Selecting previously unselected package liblualib50-dev.
Preparing to unpack .../168-liblualib50-dev_5.0.3-8+b1_amd64.deb ...
Unpacking liblualib50-dev (5.0.3-8+b1) ...
Selecting previously unselected package libmbim-glib4:amd64.
Preparing to unpack .../169-libmbim-glib4_1.18.0-1_amd64.deb ...
Unpacking libmbim-glib4:amd64 (1.18.0-1) ...
Selecting previously unselected package libmbim-proxy.
Preparing to unpack .../170-libmbim-proxy_1.18.0-1_amd64.deb ...
Unpacking libmbim-proxy (1.18.0-1) ...
Selecting previously unselected package libncurses-dev:amd64.
Preparing to unpack .../171-libncurses-dev_6.1+20181013-2+deb10u2_amd64.deb ...
Unpacking libncurses-dev:amd64 (6.1+20181013-2+deb10u2) ...
Selecting previously unselected package libomp5-7:amd64.
Preparing to unpack .../172-libomp5-7_1%3a7.0.1-8+deb10u2_amd64.deb ...
Unpacking libomp5-7:amd64 (1:7.0.1-8+deb10u2) ...
Selecting previously unselected package libomp-7-dev.
Preparing to unpack .../173-libomp-7-dev_1%3a7.0.1-8+deb10u2_amd64.deb ...
Unpacking libomp-7-dev (1:7.0.1-8+deb10u2) ...
Selecting previously unselected package libopenexr-dev.
Preparing to unpack .../174-libopenexr-dev_2.2.1-4.1+deb10u1_amd64.deb ...
Unpacking libopenexr-dev (2.2.1-4.1+deb10u1) ...
Selecting previously unselected package libpciaccess-dev:amd64.
Preparing to unpack .../175-libpciaccess-dev_0.14-1_amd64.deb ...
Unpacking libpciaccess-dev:amd64 (0.14-1) ...
Selecting previously unselected package libpixman-1-dev:amd64.
Preparing to unpack .../176-libpixman-1-dev_0.36.0-1_amd64.deb ...
Unpacking libpixman-1-dev:amd64 (0.36.0-1) ...
Selecting previously unselected package libpng-tools.
Preparing to unpack .../177-libpng-tools_1.6.36-6_amd64.deb ...
Unpacking libpng-tools (1.6.36-6) ...
Selecting previously unselected package qbs-common.
Preparing to unpack .../178-qbs-common_1.12.2+dfsg-2_all.deb ...
Unpacking qbs-common (1.12.2+dfsg-2) ...
Selecting previously unselected package libqbscore1.12:amd64.
Preparing to unpack .../179-libqbscore1.12_1.12.2+dfsg-2_amd64.deb ...
Unpacking libqbscore1.12:amd64 (1.12.2+dfsg-2) ...
Selecting previously unselected package libqbsqtprofilesetup1.12:amd64.
Preparing to unpack .../180-libqbsqtprofilesetup1.12_1.12.2+dfsg-2_amd64.deb ...
Unpacking libqbsqtprofilesetup1.12:amd64 (1.12.2+dfsg-2) ...
Selecting previously unselected package libqmi-glib5:amd64.
Preparing to unpack .../181-libqmi-glib5_1.22.0-1.2_amd64.deb ...
Unpacking libqmi-glib5:amd64 (1.22.0-1.2) ...
Selecting previously unselected package libqmi-proxy.
Preparing to unpack .../182-libqmi-proxy_1.22.0-1.2_amd64.deb ...
Unpacking libqmi-proxy (1.22.0-1.2) ...
Selecting previously unselected package libqt5designer5:amd64.
Preparing to unpack .../183-libqt5designer5_5.11.3-4_amd64.deb ...
Unpacking libqt5designer5:amd64 (5.11.3-4) ...
Selecting previously unselected package libqt5designercomponents5:amd64.
Preparing to unpack .../184-libqt5designercomponents5_5.11.3-4_amd64.deb ...
Unpacking libqt5designercomponents5:amd64 (5.11.3-4) ...
Selecting previously unselected package libqt5help5:amd64.
Preparing to unpack .../185-libqt5help5_5.11.3-4_amd64.deb ...
Unpacking libqt5help5:amd64 (5.11.3-4) ...
Selecting previously unselected package libqt5quicktest5:amd64.
Preparing to unpack .../186-libqt5quicktest5_5.11.3-4_amd64.deb ...
Unpacking libqt5quicktest5:amd64 (5.11.3-4) ...
Selecting previously unselected package libqt5quickwidgets5:amd64.
Preparing to unpack .../187-libqt5quickwidgets5_5.11.3-4_amd64.deb ...
Unpacking libqt5quickwidgets5:amd64 (5.11.3-4) ...
Selecting previously unselected package libqt5serialport5:amd64.
Preparing to unpack .../188-libqt5serialport5_5.11.3-2_amd64.deb ...
Unpacking libqt5serialport5:amd64 (5.11.3-2) ...
Selecting previously unselected package libqt5xmlpatterns5:amd64.
Preparing to unpack .../189-libqt5xmlpatterns5_5.11.3-2_amd64.deb ...
Unpacking libqt5xmlpatterns5:amd64 (5.11.3-2) ...
Selecting previously unselected package libsasl2-dev.
Preparing to unpack .../190-libsasl2-dev_2.1.27+dfsg-1+deb10u1_amd64.deb ...
Unpacking libsasl2-dev (2.1.27+dfsg-1+deb10u1) ...
Selecting previously unselected package libssl-dev:amd64.
Preparing to unpack .../191-libssl-dev_1.1.1d-0+deb10u3_amd64.deb ...
Unpacking libssl-dev:amd64 (1.1.1d-0+deb10u3) ...
Selecting previously unselected package libtinfo-dev:amd64.
Preparing to unpack .../192-libtinfo-dev_6.1+20181013-2+deb10u2_amd64.deb ...
Unpacking libtinfo-dev:amd64 (6.1+20181013-2+deb10u2) ...
Selecting previously unselected package libtool.
Preparing to unpack .../193-libtool_2.4.6-9_all.deb ...
Unpacking libtool (2.4.6-9) ...
Selecting previously unselected package libtqt3-compat-headers.
Preparing to unpack .../194-libtqt3-compat-headers_4%3a14.0.6-0debian10.0.0+0~a_amd64.deb ...
Unpacking libtqt3-compat-headers (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package libudev-dev:amd64.
Preparing to unpack .../195-libudev-dev_241-7~deb10u4_amd64.deb ...
Unpacking libudev-dev:amd64 (241-7~deb10u4) ...
Selecting previously unselected package x11proto-composite-dev.
Preparing to unpack .../196-x11proto-composite-dev_1%3a2018.4-4_all.deb ...
Unpacking x11proto-composite-dev (1:2018.4-4) ...
Selecting previously unselected package libxcomposite-dev:amd64.
Preparing to unpack .../197-libxcomposite-dev_1%3a0.4.4-2_amd64.deb ...
Unpacking libxcomposite-dev:amd64 (1:0.4.4-2) ...
Selecting previously unselected package libxfont-dev.
Preparing to unpack .../198-libxfont-dev_1%3a2.0.3-1_amd64.deb ...
Unpacking libxfont-dev (1:2.0.3-1) ...
Selecting previously unselected package libxkbfile-dev:amd64.
Preparing to unpack .../199-libxkbfile-dev_1%3a1.0.9-2+b11_amd64.deb ...
Unpacking libxkbfile-dev:amd64 (1:1.0.9-2+b11) ...
Selecting previously unselected package libxml2-dev:amd64.
Preparing to unpack .../200-libxml2-dev_2.9.4+dfsg1-7+b3_amd64.deb ...
Unpacking libxml2-dev:amd64 (2.9.4+dfsg1-7+b3) ...
Selecting previously unselected package libxml2-utils.
Preparing to unpack .../201-libxml2-utils_2.9.4+dfsg1-7+b3_amd64.deb ...
Unpacking libxml2-utils (2.9.4+dfsg1-7+b3) ...
Selecting previously unselected package libxslt1-dev:amd64.
Preparing to unpack .../202-libxslt1-dev_1.1.32-2.2~deb10u1_amd64.deb ...
Unpacking libxslt1-dev:amd64 (1.1.32-2.2~deb10u1) ...
Selecting previously unselected package llvm-7-runtime.
Preparing to unpack .../203-llvm-7-runtime_1%3a7.0.1-8+deb10u2_amd64.deb ...
Unpacking llvm-7-runtime (1:7.0.1-8+deb10u2) ...
Selecting previously unselected package llvm-7.
Preparing to unpack .../204-llvm-7_1%3a7.0.1-8+deb10u2_amd64.deb ...
Unpacking llvm-7 (1:7.0.1-8+deb10u2) ...
Selecting previously unselected package llvm-7-dev.
Preparing to unpack .../205-llvm-7-dev_1%3a7.0.1-8+deb10u2_amd64.deb ...
Unpacking llvm-7-dev (1:7.0.1-8+deb10u2) ...
Selecting previously unselected package mc-data.
Preparing to unpack .../206-mc-data_3%3a4.8.22-1_all.deb ...
Unpacking mc-data (3:4.8.22-1) ...
Selecting previously unselected package mc.
Preparing to unpack .../207-mc_3%3a4.8.22-1_amd64.deb ...
Unpacking mc (3:4.8.22-1) ...
Selecting previously unselected package modemmanager.
Preparing to unpack .../208-modemmanager_1.10.0-1_amd64.deb ...
Unpacking modemmanager (1.10.0-1) ...
Selecting previously unselected package qdoc-qt5.
Preparing to unpack .../209-qdoc-qt5_5.11.3-4_amd64.deb ...
Unpacking qdoc-qt5 (5.11.3-4) ...
Selecting previously unselected package qml-module-qtqml-models2:amd64.
Preparing to unpack .../210-qml-module-qtqml-models2_5.11.3-4_amd64.deb ...
Unpacking qml-module-qtqml-models2:amd64 (5.11.3-4) ...
Selecting previously unselected package qmlscene.
Preparing to unpack .../211-qmlscene_5.11.3-4_amd64.deb ...
Unpacking qmlscene (5.11.3-4) ...
Selecting previously unselected package qt3d5-doc.
Preparing to unpack .../212-qt3d5-doc_5.11.3+dfsg-2_all.deb ...
Unpacking qt3d5-doc (5.11.3+dfsg-2) ...
Selecting previously unselected package qt5-assistant.
Preparing to unpack .../213-qt5-assistant_5.11.3-4_amd64.deb ...
Unpacking qt5-assistant (5.11.3-4) ...
Selecting previously unselected package qt5-qmltooling-plugins:amd64.
Preparing to unpack .../214-qt5-qmltooling-plugins_5.11.3-4_amd64.deb ...
Unpacking qt5-qmltooling-plugins:amd64 (5.11.3-4) ...
Selecting previously unselected package qtbase5-dev-tools.
Preparing to unpack .../215-qtbase5-dev-tools_5.11.3+dfsg1-1+deb10u4_amd64.deb ...
Unpacking qtbase5-dev-tools (5.11.3+dfsg1-1+deb10u4) ...
Selecting previously unselected package qtbase5-doc.
Preparing to unpack .../216-qtbase5-doc_5.11.3+dfsg1-1+deb10u4_all.deb ...
Unpacking qtbase5-doc (5.11.3+dfsg1-1+deb10u4) ...
Selecting previously unselected package qtcharts5-doc.
Preparing to unpack .../217-qtcharts5-doc_5.11.3-2_all.deb ...
Unpacking qtcharts5-doc (5.11.3-2) ...
Selecting previously unselected package qtconnectivity5-doc.
Preparing to unpack .../218-qtconnectivity5-doc_5.11.3-2_all.deb ...
Unpacking qtconnectivity5-doc (5.11.3-2) ...
Selecting previously unselected package qtcreator-data.
Preparing to unpack .../219-qtcreator-data_4.8.2-1_all.deb ...
Unpacking qtcreator-data (4.8.2-1) ...
Selecting previously unselected package qtcreator.
Preparing to unpack .../220-qtcreator_4.8.2-1_amd64.deb ...
Unpacking qtcreator (4.8.2-1) ...
Selecting previously unselected package qtcreator-doc.
Preparing to unpack .../221-qtcreator-doc_4.8.2-1_all.deb ...
Unpacking qtcreator-doc (4.8.2-1) ...
Selecting previously unselected package qtdeclarative5-dev-tools.
Preparing to unpack .../222-qtdeclarative5-dev-tools_5.11.3-4_amd64.deb ...
Unpacking qtdeclarative5-dev-tools (5.11.3-4) ...
Selecting previously unselected package qtdeclarative5-doc.
Preparing to unpack .../223-qtdeclarative5-doc_5.11.3-4_all.deb ...
Unpacking qtdeclarative5-doc (5.11.3-4) ...
Selecting previously unselected package qtgraphicaleffects5-doc.
Preparing to unpack .../224-qtgraphicaleffects5-doc_5.11.3-2_all.deb ...
Unpacking qtgraphicaleffects5-doc (5.11.3-2) ...
Selecting previously unselected package qtlocation5-doc.
Preparing to unpack .../225-qtlocation5-doc_5.11.3+dfsg-2_all.deb ...
Unpacking qtlocation5-doc (5.11.3+dfsg-2) ...
Selecting previously unselected package qtmultimedia5-doc.
Preparing to unpack .../226-qtmultimedia5-doc_5.11.3-2_all.deb ...
Unpacking qtmultimedia5-doc (5.11.3-2) ...
Selecting previously unselected package qtquickcontrols2-5-doc.
Preparing to unpack .../227-qtquickcontrols2-5-doc_5.11.3+dfsg-2_all.deb ...
Unpacking qtquickcontrols2-5-doc (5.11.3+dfsg-2) ...
Selecting previously unselected package qtquickcontrols5-doc.
Preparing to unpack .../228-qtquickcontrols5-doc_5.11.3-2_all.deb ...
Unpacking qtquickcontrols5-doc (5.11.3-2) ...
Selecting previously unselected package qtscript5-doc.
Preparing to unpack .../229-qtscript5-doc_5.11.3+dfsg-3_all.deb ...
Unpacking qtscript5-doc (5.11.3+dfsg-3) ...
Selecting previously unselected package qtsensors5-doc.
Preparing to unpack .../230-qtsensors5-doc_5.11.3-2_all.deb ...
Unpacking qtsensors5-doc (5.11.3-2) ...
Selecting previously unselected package qtserialport5-doc.
Preparing to unpack .../231-qtserialport5-doc_5.11.3-2_all.deb ...
Unpacking qtserialport5-doc (5.11.3-2) ...
Selecting previously unselected package qtsvg5-doc.
Preparing to unpack .../232-qtsvg5-doc_5.11.3-2_all.deb ...
Unpacking qtsvg5-doc (5.11.3-2) ...
Selecting previously unselected package qttools5-dev-tools.
Preparing to unpack .../233-qttools5-dev-tools_5.11.3-4_amd64.deb ...
Unpacking qttools5-dev-tools (5.11.3-4) ...
Selecting previously unselected package qttools5-doc.
Preparing to unpack .../234-qttools5-doc_5.11.3-4_all.deb ...
Unpacking qttools5-doc (5.11.3-4) ...
Selecting previously unselected package qtvirtualkeyboard5-doc.
Preparing to unpack .../235-qtvirtualkeyboard5-doc_5.11.3+dfsg-2_all.deb ...
Unpacking qtvirtualkeyboard5-doc (5.11.3+dfsg-2) ...
Selecting previously unselected package qtwayland5-doc.
Preparing to unpack .../236-qtwayland5-doc_5.11.3-2_all.deb ...
Unpacking qtwayland5-doc (5.11.3-2) ...
Selecting previously unselected package qtwebchannel5-doc.
Preparing to unpack .../237-qtwebchannel5-doc_5.11.3-2_all.deb ...
Unpacking qtwebchannel5-doc (5.11.3-2) ...
Selecting previously unselected package qtwebengine5-doc.
Preparing to unpack .../238-qtwebengine5-doc_5.11.3+dfsg-2+deb10u1_all.deb ...
Unpacking qtwebengine5-doc (5.11.3+dfsg-2+deb10u1) ...
Selecting previously unselected package qtwebsockets5-doc.
Preparing to unpack .../239-qtwebsockets5-doc_5.11.3-5_all.deb ...
Unpacking qtwebsockets5-doc (5.11.3-5) ...
Selecting previously unselected package qtwebview5-doc.
Preparing to unpack .../240-qtwebview5-doc_5.11.3-2_all.deb ...
Unpacking qtwebview5-doc (5.11.3-2) ...
Selecting previously unselected package qtx11extras5-doc.
Preparing to unpack .../241-qtx11extras5-doc_5.11.3-2_all.deb ...
Unpacking qtx11extras5-doc (5.11.3-2) ...
Selecting previously unselected package qtxmlpatterns5-dev-tools.
Preparing to unpack .../242-qtxmlpatterns5-dev-tools_5.11.3-2_amd64.deb ...
Unpacking qtxmlpatterns5-dev-tools (5.11.3-2) ...
Selecting previously unselected package qtxmlpatterns5-doc.
Preparing to unpack .../243-qtxmlpatterns5-doc_5.11.3-2_all.deb ...
Unpacking qtxmlpatterns5-doc (5.11.3-2) ...
Selecting previously unselected package reprepro.
Preparing to unpack .../244-reprepro_5.3.0-1_amd64.deb ...
Unpacking reprepro (5.3.0-1) ...
Selecting previously unselected package tdecachegrind-trinity.
Preparing to unpack .../245-tdecachegrind-trinity_4%3a14.0.6-0debian10.0.0+0~a_amd64.deb ...
Unpacking tdecachegrind-trinity (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package libr-dev.
Preparing to unpack .../246-libr-dev_4%3a14.0.6-0debian10.0.0+0~a_amd64.deb ...
Unpacking libr-dev (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package tdelibs14-trinity-dev.
Preparing to unpack .../247-tdelibs14-trinity-dev_4%3a14.0.6-0debian10.0.0+0~a.2_amd64.deb ...
Unpacking tdelibs14-trinity-dev (4:14.0.6-0debian10.0.0+0~a.2) ...
Selecting previously unselected package tdevelop-trinity-doc.
Preparing to unpack .../248-tdevelop-trinity-doc_4%3a14.0.6-0debian10.0.0+0~a_all.deb ...
Unpacking tdevelop-trinity-doc (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package tqt3-doc.
Preparing to unpack .../249-tqt3-doc_4%3a14.0.6-0debian10.0.0+0~a_all.deb ...
Unpacking tqt3-doc (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package tqt3-assistant.
Preparing to unpack .../250-tqt3-assistant_4%3a14.0.6-0debian10.0.0+0~a_amd64.deb ...
Unpacking tqt3-assistant (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package tqt3-designer.
Preparing to unpack .../251-tqt3-designer_4%3a14.0.6-0debian10.0.0+0~a_amd64.deb ...
Unpacking tqt3-designer (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package tqt3-linguist.
Preparing to unpack .../252-tqt3-linguist_4%3a14.0.6-0debian10.0.0+0~a_amd64.deb ...
Unpacking tqt3-linguist (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package tqt3-qtconfig.
Preparing to unpack .../253-tqt3-qtconfig_4%3a14.0.6-0debian10.0.0+0~a_amd64.deb ...
Unpacking tqt3-qtconfig (4:14.0.6-0debian10.0.0+0~a) ...
Selecting previously unselected package valgrind.
Preparing to unpack .../254-valgrind_1%3a3.14.0-3_amd64.deb ...
Unpacking valgrind (1:3.14.0-3) ...
Selecting previously unselected package valgrind-dbg.
Preparing to unpack .../255-valgrind-dbg_1%3a3.14.0-3_amd64.deb ...
Unpacking valgrind-dbg (1:3.14.0-3) ...
Selecting previously unselected package xfonts-terminus.
Preparing to unpack .../256-xfonts-terminus_4.40-2_all.deb ...
Unpacking xfonts-terminus (4.40-2) ...
Selecting previously unselected package xserver-xorg-dev.
Preparing to unpack .../257-xserver-xorg-dev_2%3a1.20.4-1+deb10u1_amd64.deb ...
Unpacking xserver-xorg-dev (2:1.20.4-1+deb10u1) ...
Selecting previously unselected package q4os-devpack.
Preparing to unpack .../258-q4os-devpack_3.3.1-a1_all.deb ...
Unpacking q4os-devpack (3.3.1-a1) ...
Selecting previously unselected package qt5-doc.
Preparing to unpack .../259-qt5-doc_5.11.3-1_all.deb ...
Unpacking qt5-doc (5.11.3-1) ...
Setting up qt3d5-doc (5.11.3+dfsg-2) ...
Setting up libpcrecpp0v5:amd64 (2:8.39-12) ...
Setting up libxdot4 (2.40.1-6) ...
Setting up qtcharts5-doc (5.11.3-2) ...
Setting up bzip2-doc (1.0.6-9.2~deb10u1) ...
Setting up kdiff3-trinity-doc (4:14.0.6-0debian10.0.0+0~a) ...
Setting up libx11-xcb-dev:amd64 (2:1.6.7-1+deb10u1) ...
Setting up libdw1:amd64 (0.176-1.1) ...
Setting up qtwayland5-doc (5.11.3-2) ...
Setting up tdecachegrind-trinity (4:14.0.6-0debian10.0.0+0~a) ...
Setting up libdrm-dev:amd64 (2.4.97-1) ...
Setting up qtx11extras5-doc (5.11.3-2) ...
Setting up libncurses-dev:amd64 (6.1+20181013-2+deb10u2) ...
Setting up qtxmlpatterns5-doc (5.11.3-2) ...
Setting up libxmu-headers (2:1.1.2-2) ...
Setting up gettext (0.19.8.1-9) ...
Setting up libpixman-1-dev:amd64 (0.36.0-1) ...
Setting up libpciaccess-dev:amd64 (0.14-1) ...
Setting up libglvnd-core-dev:amd64 (1.1.0-1) ...
Setting up libpcre16-3:amd64 (2:8.39-12) ...
Setting up qtsensors5-doc (5.11.3-2) ...
Setting up libattr1-dev:amd64 (1:2.4.48-4) ...
Setting up libqt5designer5:amd64 (5.11.3-4) ...
Setting up qtbase5-doc (5.11.3+dfsg1-1+deb10u4) ...
Setting up libice-dev:amd64 (2:1.0.9-2) ...
Setting up qtquickcontrols2-5-doc (5.11.3+dfsg-2) ...
Setting up libpng-tools (1.6.36-6) ...
Setting up libtool (2.4.6-9) ...
Setting up libqt5xmlpatterns5:amd64 (5.11.3-2) ...
Setting up libxshmfence-dev:amd64 (1.3-1) ...
Setting up libsm-dev:amd64 (2:1.2.3-1) ...
Setting up x11proto-randr-dev (2018.4-4) ...
Setting up cvs (2:1.12.13+real-27) ...
Allowing use of questionable username.
Adding group `_cvsadmin' (GID 123) ...
Done.
Setting up tqt3-qtconfig (4:14.0.6-0debian10.0.0+0~a) ...
update-alternatives: using /usr/bin/tqtconfig to provide /usr/bin/qtconfig (qtconfig) in auto mode
update-alternatives: warning: skip creation of /usr/share/man/man1/qtconfig.1.gz because associated file /usr/share/man/man1/qtconfig-tqt3.1.gz (of link group qtconfig) doesn't exist
Setting up libutf8proc2:amd64 (2.3.0-1) ...
Setting up libtqt3-headers (4:14.0.6-0debian10.0.0+0~a) ...
Setting up libqt5positioning5:amd64 (5.11.3+dfsg-2) ...
Setting up liblab-gamut1 (2.40.1-6) ...
Setting up libsepol1-dev:amd64 (2.8-1) ...
Setting up libjbig-dev:amd64 (2.1-3.1+b2) ...
Setting up libaspell-dev:amd64 (0.60.7~20110707-6) ...
Setting up libapr1:amd64 (1.6.5-1+b1) ...
Setting up libxcb-dri3-dev:amd64 (1.13.1-2) ...
Setting up binutils-dev (2.31.1-16) ...
Setting up geoclue-2.0 (2.5.2-1) ...
geoclue.service is a disabled or a static unit, not starting it.
Setting up libqt5serialport5:amd64 (5.11.3-2) ...
Setting up tdevelop-trinity-doc (4:14.0.6-0debian10.0.0+0~a) ...
Setting up libqt5designercomponents5:amd64 (5.11.3-4) ...
Setting up qttools5-doc (5.11.3-4) ...
Setting up libogg-dev:amd64 (1.3.2-1+b1) ...
Setting up qtwebchannel5-doc (5.11.3-2) ...
Setting up libffi-dev:amd64 (3.2.1-9) ...
Setting up x11proto-xinerama-dev (2018.4-4) ...
Setting up libqt5help5:amd64 (5.11.3-4) ...
Setting up libopengl0:amd64 (1.1.0-1) ...
Setting up libcvsservice0-trinity (4:14.0.6-0debian10.0.0+0~a) ...
Setting up libaudio-dev:amd64 (1.9.4-6) ...
Setting up libc6-dbg:amd64 (2.28-10) ...
Setting up qtdeclarative5-doc (5.11.3-4) ...
Setting up qtwebsockets5-doc (5.11.3-5) ...
Setting up hspell (1.4-3) ...
Setting up libgts-0.7-5:amd64 (0.7.6+darcs121130-4) ...
Setting up tqt3-dev-tools (4:14.0.6-0debian10.0.0+0~a) ...
update-alternatives: using /usr/bin/tqmoc to provide /usr/bin/moc (moc) in auto mode
update-alternatives: using /usr/bin/tquic to provide /usr/bin/uic (uic) in auto mode
update-alternatives: using /usr/bin/tqlupdate to provide /usr/bin/lupdate (lupdate) in auto mode
update-alternatives: warning: not replacing /usr/share/man/man1/lupdate.1.gz with a link
update-alternatives: using /usr/bin/tqlrelease to provide /usr/bin/lrelease (lrelease) in auto mode
update-alternatives: warning: not replacing /usr/share/man/man1/lrelease.1.gz with a link
update-alternatives: using /usr/bin/tqmake to provide /usr/bin/qmake (qmake) in auto mode
Setting up libltdl-dev:amd64 (2.4.6-9) ...
Setting up libaudiofile-dev:amd64 (0.3.6-5) ...
Setting up qtbase5-dev-tools (5.11.3+dfsg1-1+deb10u4) ...
Setting up qbs-common (1.12.2+dfsg-2) ...
Setting up libgssrpc4:amd64 (1.17-3) ...
Setting up libobjc-8-dev:amd64 (8.3.0-6) ...
Setting up libsasl2-dev (2.1.27+dfsg-1+deb10u1) ...
Setting up libxcb-dri2-0-dev:amd64 (1.13.1-2) ...
Setting up libuv1:amd64 (1.24.1-1) ...
Setting up x11proto-damage-dev (1:2018.4-4) ...
Setting up qtmultimedia5-doc (5.11.3-2) ...
Setting up libexpat1-dev:amd64 (2.2.6-2+deb10u1) ...
Setting up x11proto-composite-dev (1:2018.4-4) ...
Setting up qtscript5-doc (5.11.3+dfsg-3) ...
Setting up libjpeg62-turbo-dev:amd64 (1:1.5.2-2+b1) ...
Setting up libxt-dev:amd64 (1:1.1.5-1+b3) ...
Setting up tqt3-doc (4:14.0.6-0debian10.0.0+0~a) ...
Setting up uuid-dev:amd64 (2.33.1-0.1) ...
Setting up libpathplan4 (2.40.1-6) ...
Setting up libcupsfilters-dev:amd64 (1.21.6-5) ...
Setting up libgles1:amd64 (1.1.0-1) ...
Setting up comerr-dev:amd64 (2.1-1.44.5-1+deb10u3) ...
Setting up libssl-dev:amd64 (1.1.1d-0+deb10u3) ...
Setting up libpcre32-3:amd64 (2:8.39-12) ...
Setting up x11proto-input-dev (2018.4-4) ...
Setting up liblua50 (5.0.3-8+b1) ...
Setting up libomp5-7:amd64 (1:7.0.1-8+deb10u2) ...
Setting up binfmt-support (2.2.0-2) ...
Created symlink /etc/systemd/system/multi-user.target.wants/binfmt-support.service → /lib/systemd/system/binfmt-support.service.
Setting up icu-devtools (63.1-6+deb10u1) ...
Setting up libipt2 (2.0-2) ...
Setting up pkg-config (0.29-6) ...
Setting up libr-dev (4:14.0.6-0debian10.0.0+0~a) ...
Setting up tdevelop-data-trinity (4:14.0.6-0debian10.0.0+0~a) ...
Setting up libudev-dev:amd64 (241-7~deb10u4) ...
Setting up qtwebengine5-doc (5.11.3+dfsg-2+deb10u1) ...
Setting up libxinerama-dev:amd64 (2:1.1.4-2) ...
Setting up libqt5webchannel5:amd64 (5.11.3-2) ...
Setting up libxcb-render0-dev:amd64 (1.13.1-2) ...
Setting up libxcb-glx0-dev:amd64 (1.13.1-2) ...
Setting up qtwebview5-doc (5.11.3-2) ...
Setting up libmad0-dev (0.15.1b-10) ...
Setting up libbabeltrace1:amd64 (1.5.6-2+deb10u1) ...
Setting up mc-data (3:4.8.22-1) ...
Setting up qtsvg5-doc (5.11.3-2) ...
Setting up libxcb-shape0-dev:amd64 (1.13.1-2) ...
Setting up qtgraphicaleffects5-doc (5.11.3-2) ...
Setting up liblcms2-dev:amd64 (2.9-3) ...
Setting up liblzma-dev:amd64 (5.2.4-1) ...
Setting up zlib1g-dev:amd64 (1:1.2.11.dfsg-1) ...
Setting up qtlocation5-doc (5.11.3+dfsg-2) ...
Setting up x11proto-xf86vidmode-dev (2018.4-4) ...
Setting up checkinstall (1.6.2+git20170426.d24a630-2~bpo10+1) ...
Setting up qtcreator-data (4.8.2-1) ...
Setting up khexedit-trinity (4:14.0.6-0debian10.0.0+0~a) ...
Setting up qtserialport5-doc (5.11.3-2) ...
Setting up libkdb5-9:amd64 (1.17-3) ...
Setting up qtvirtualkeyboard5-doc (5.11.3+dfsg-2) ...
Setting up librhash0:amd64 (1.3.8-1) ...
Setting up libavahi-common-dev:amd64 (0.7-4+b1) ...
Setting up qtxmlpatterns5-dev-tools (5.11.3-2) ...
Setting up qml-module-qtqml-models2:amd64 (5.11.3-4) ...
Setting up liblualib50 (5.0.3-8+b1) ...
Setting up libc6-i386 (2.28-10) ...
Setting up libxcb-sync-dev:amd64 (1.13.1-2) ...
Setting up mesa-common-dev:amd64 (18.3.6-2+deb10u1) ...
Setting up cmake-data (3.13.4-1) ...
Setting up libcdt5 (2.40.1-6) ...
Setting up libxcb-xfixes0-dev:amd64 (1.13.1-2) ...
Setting up libcgraph6 (2.40.1-6) ...
Setting up kdiff3-trinity (4:14.0.6-0debian10.0.0+0~a) ...
Setting up libqbscore1.12:amd64 (1.12.2+dfsg-2) ...
Setting up qtcreator-doc (4.8.2-1) ...
Setting up libkadm5srv-mit11:amd64 (1.17-3) ...
Setting up libclang1-7 (1:7.0.1-8+deb10u2) ...
Setting up libqt5sensors5:amd64 (5.11.3-2) ...
Setting up libxml2-utils (2.9.4+dfsg1-7+b3) ...
Setting up x11proto-fixes-dev (1:2018.4-4) ...
Setting up libjasper-dev (1.900.1-debian1-2.5debian10.0.0+5~a) ...
Setting up libasound2-dev:amd64 (1.1.8-1) ...
Setting up reprepro (5.3.0-1) ...
Setting up valgrind (1:3.14.0-3) ...
Setting up libqt5quick5:amd64 (5.11.3-4) ...
Setting up python3-lib2to3 (3.7.3-1) ...
Setting up libxrender-dev:amd64 (1:0.9.10-1) ...
Setting up libicu-dev:amd64 (63.1-6+deb10u1) ...
Setting up libmbim-glib4:amd64 (1.18.0-1) ...
Setting up libilmbase-dev (2.2.1-2) ...
Setting up libjsoncpp1:amd64 (1.7.4-3) ...
Setting up libtqt3-compat-headers (4:14.0.6-0debian10.0.0+0~a) ...
Setting up libtiffxx5:amd64 (4.1.0+git191117-2~deb10u1) ...
Setting up libacl1-dev:amd64 (2.2.53-4) ...
Setting up qtquickcontrols5-doc (5.11.3-2) ...
Setting up qtconnectivity5-doc (5.11.3-2) ...
Setting up libaprutil1:amd64 (1.6.1-4) ...
Setting up libbz2-dev:amd64 (1.0.6-9.2~deb10u1) ...
Setting up libxkbfile-dev:amd64 (1:1.0.9-2+b11) ...
Setting up xfonts-terminus (4.40-2) ...
Setting up python3-distutils (3.7.3-1) ...
Setting up libvorbis-dev:amd64 (1.3.6-2) ...
Setting up libglib2.0-dev-bin (2.58.3-2+deb10u2) ...
Setting up tqt3-assistant (4:14.0.6-0debian10.0.0+0~a) ...
update-alternatives: using /usr/bin/tqassistant to provide /usr/bin/assistant (assistant) in auto mode
Setting up libtinfo-dev:amd64 (6.1+20181013-2+deb10u2) ...
Setting up libkadm5clnt-mit11:amd64 (1.17-3) ...
Setting up libblkid-dev:amd64 (2.33.1-0.1) ...
Setting up libgts-bin (0.7.6+darcs121130-4) ...
Setting up libart-2.0-dev (4:14.0.6-0debian10.0.0+0~a) ...
Setting up libqt5quicktest5:amd64 (5.11.3-4) ...
Setting up libidn11-dev:amd64 (1.33-2.2) ...
Setting up llvm-7-runtime (1:7.0.1-8+deb10u2) ...
Setting up mc (3:4.8.22-1) ...
update-alternatives: using /usr/bin/mcview to provide /usr/bin/view (view) in auto mode
Setting up llvm-7 (1:7.0.1-8+deb10u2) ...
Setting up libpcre3-dev:amd64 (2:8.39-12) ...
Setting up qtdeclarative5-dev-tools (5.11.3-4) ...
Setting up qmlscene (5.11.3-4) ...
Setting up qdoc-qt5 (5.11.3-4) ...
Setting up libxxf86vm-dev:amd64 (1:1.1.4-1+b2) ...
Setting up libpng-dev:amd64 (1.6.36-6) ...
Setting up libserf-1-1:amd64 (1.3.9-7+b10) ...
Setting up libjpeg-dev (1:1.5.2-2) ...
Setting up libfontenc-dev:amd64 (1:1.1.3-1+b2) ...
Setting up libmng-dev:amd64 (1.0.10+dfsg-3.1+b5) ...
Setting up libglvnd-dev:amd64 (1.1.0-1) ...
Setting up qml-module-qtquick-window2:amd64 (5.11.3-4) ...
Setting up valgrind-dbg (1:3.14.0-3) ...
Setting up libmbim-proxy (1.18.0-1) ...
Setting up libqt5webkit5:amd64 (5.212.0~alpha2-21) ...
Setting up libxmu-dev:amd64 (2:1.1.2-2+b3) ...
Setting up lib32gcc1 (1:8.3.0-6) ...
Setting up qml-module-qtquick-layouts:amd64 (5.11.3-4) ...
Setting up lua50 (5.0.3-8+b1) ...
update-alternatives: using /usr/bin/lua50 to provide /usr/bin/lua (lua-interpreter) in auto mode
update-alternatives: using /usr/bin/luac50 to provide /usr/bin/luac (lua-compiler) in auto mode
Setting up libfreetype6-dev:amd64 (2.9.1-3+deb10u1) ...
Setting up qt5-qmltooling-plugins:amd64 (5.11.3-4) ...
Setting up libqt5quickwidgets5:amd64 (5.11.3-4) ...
Setting up libomp-7-dev (1:7.0.1-8+deb10u2) ...
Setting up libxfixes-dev:amd64 (1:5.0.3-1) ...
Setting up qt5-doc (5.11.3-1) ...
Setting up libxrandr-dev:amd64 (2:1.5.1-1) ...
Setting up libxml2-dev:amd64 (2.9.4+dfsg1-7+b3) ...
Setting up libopenexr-dev (2.2.1-4.1+deb10u1) ...
Setting up gdb (8.2.1-2+b3) ...
Setting up libtiff-dev:amd64 (4.1.0+git191117-2~deb10u1) ...
Setting up libdbus-1-dev:amd64 (1.12.20-0+deb10u1) ...
Setting up liblua50-dev (5.0.3-8+b1) ...
update-alternatives: using /usr/bin/lua-config50 to provide /usr/bin/lua-config (lua-configuration) in auto mode
Setting up lib32stdc++6 (8.3.0-6) ...
Setting up libxcb-randr0-dev:amd64 (1.13.1-2) ...
Setting up libxcb-present-dev:amd64 (1.13.1-2) ...
Setting up libgvc6 (2.40.1-6) ...
Setting up liblualib50-dev (5.0.3-8+b1) ...
Setting up qt5-assistant (5.11.3-4) ...
Setting up libgvpr2 (2.40.1-6) ...
Setting up libqbsqtprofilesetup1.12:amd64 (1.12.2+dfsg-2) ...
Setting up libclang-common-7-dev (1:7.0.1-8+deb10u2) ...
Setting up qttools5-dev-tools (5.11.3-4) ...
Setting up cmake (3.13.4-1) ...
Setting up libxi-dev:amd64 (2:1.7.9-1) ...
Setting up libsvn1:amd64 (1.10.4-1+deb10u1) ...
Setting up qml-module-qtquick2:amd64 (5.11.3-4) ...
Setting up libmount-dev:amd64 (2.33.1-0.1) ...
Setting up krb5-multidev:amd64 (1.17-3) ...
Setting up libxdamage-dev:amd64 (1:1.1.4-3+b3) ...
Setting up graphviz (2.40.1-6) ...
Setting up clang-7 (1:7.0.1-8+deb10u2) ...
Setting up llvm-7-dev (1:7.0.1-8+deb10u2) ...
Setting up libfontconfig1-dev:amd64 (2.13.1-2) ...
Setting up libxslt1-dev:amd64 (1.1.32-2.2~deb10u1) ...
Setting up libselinux1-dev:amd64 (2.8-1+b1) ...
Setting up libxcomposite-dev:amd64 (1:0.4.4-2) ...
Setting up libxcursor-dev:amd64 (1:1.1.15-2) ...
Setting up tdevelop-trinity (4:14.0.6-0debian10.0.0+0~a) ...
Setting up libxfont-dev (1:2.0.3-1) ...
Setting up libqmi-glib5:amd64 (1.22.0-1.2) ...
Setting up libavahi-client-dev:amd64 (0.7-4+b1) ...
Setting up libkrb5-dev:amd64 (1.17-3) ...
Setting up libglib2.0-dev:amd64 (2.58.3-2+deb10u2) ...
Setting up clang (1:7.0-47) ...
Setting up qml-module-qtgraphicaleffects:amd64 (5.11.3-2) ...
Setting up libgl1-mesa-dev:amd64 (18.3.6-2+deb10u1) ...
Setting up libxft-dev:amd64 (2.3.2-2) ...
Setting up xserver-xorg-dev (2:1.20.4-1+deb10u1) ...
Setting up qml-module-qtquick-controls:amd64 (5.11.3-2) ...
Setting up libqmi-proxy (1.22.0-1.2) ...
Setting up qtcreator (4.8.2-1) ...
Setting up libglu1-mesa-dev:amd64 (9.0.0-2.1+b3) ...
Setting up modemmanager (1.10.0-1) ...
Created symlink /etc/systemd/system/dbus-org.freedesktop.ModemManager1.service → /lib/systemd/system/ModemManager.service.
Created symlink /etc/systemd/system/multi-user.target.wants/ModemManager.service → /lib/systemd/system/ModemManager.service.
Setting up libcupsimage2-dev:amd64 (2.2.10-6+deb10u3) ...
Setting up libcups2-dev:amd64 (2.2.10-6+deb10u3) ...
Setting up libtqt3-mt-dev (4:14.0.6-0debian10.0.0+0~a) ...
Setting up tqt3-apps-dev (4:14.0.6-0debian10.0.0+0~a) ...
Setting up kdevdesigner-trinity (4:14.0.6-0debian10.0.0+0~a) ...
Setting up tqt3-linguist (4:14.0.6-0debian10.0.0+0~a) ...
update-alternatives: using /usr/bin/tqlinguist to provide /usr/bin/linguist (linguist) in auto mode
update-alternatives: warning: skip creation of /usr/share/man/man1/linguist.1.gz because associated file /usr/share/man/man1/linguist-tqt3.1.gz (of link group linguist) doesn't exist
Setting up tqt3-designer (4:14.0.6-0debian10.0.0+0~a) ...
update-alternatives: using /usr/bin/tqdesigner to provide /usr/bin/designer (designer) in auto mode
update-alternatives: warning: skip creation of /usr/share/man/man1/designer.1.gz because associated file /usr/share/man/man1/designer-tqt3.1.gz (of link group designer) doesn't exist
Setting up libtqtinterface-dev (4:14.0.6-0debian10.0.0+0~a) ...
Setting up libdbus-1-tqt-dev (4:14.0.6-0debian10.0.0+0~a) ...
Processing triggers for libglib2.0-0:amd64 (2.58.3-2+deb10u2) ...
Processing triggers for libc-bin (2.28-10) ...
Processing triggers for systemd (241-7~deb10u4) ...
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for dbus (1.12.20-0+deb10u1) ...
Processing triggers for shared-mime-info (1.10-1) ...
Processing triggers for fontconfig (2.13.1-2) ...
Processing triggers for desktop-file-utils (0.23-4) ...
Setting up libartsc0-trinity-dev (4:14.0.6-0debian10.0.0+0~a) ...
Processing triggers for mime-support (3.62) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Setting up libarts1-trinity-dev (4:14.0.6-0debian10.0.0+0~a) ...
Setting up tdelibs14-trinity-dev (4:14.0.6-0debian10.0.0+0~a.2) ...
Setting up q4os-devpack (3.3.1-a1) ...
Copying system packages ... Done
Postinstall operations ...
Postinstall operations ... Done
Checking installation ...
Checking installation ... OK
Update system cache ...
Update system cache ... Done
Finishing installation ...
Installation successfully completed :-)
#4 2020-10-09 17:19
Re: Dev Pack Installer Problem
Yes, the log has been overwritten already. We conclude the issue could be some temporary repositories unavailability. If you encounter it again, you can post the log file here. It would be better to attach it as a file, click Post reply > Choose file ..
