#1 2020-10-04 11:24
charityAMG
How to add the "Adjust Brightness" icon in Taskbar?
I have just installed the OS on my laptop. I want to slide to change brightness of screen. How to add the "Adjust Brightness" icon into Taskbar?. Thanks.
#2 2020-10-04 11:57
charityAMG
Re: How to add the "Adjust Brightness" icon in Taskbar?
I use the q4os 2.7 with tde
#3 2020-10-04 17:22
The easiest way to control display brightness is to install "tdepowersave-trinity", it may be already installed, and simply hover your mouse over the icon in system tray, and use the mouse scroll wheel to adjust brightness up or down. You could also install and use "klcddimmer-trinity" package in Trinity, however you will need to configure it to use a brightness control backend, for example "xbacklight".
#4 2020-10-08 14:16
wove
I did not know you could do that with tdepowersave-trinity. That is pretty slick. Thanks for pointing that out.
bill
