Hi,
I just installed "Look Switcher" and it's great, except after logging out and back in, my whole screen is frozen... can't force the menu to open, can open console with Ctrl-Alt-T
Locked Frozen Broken.
Short of a reinstall, what do I do?
Thanks,
Ben
It's an HP TPN-C126
That should read "CAN'T" open terminal with ctrl-alt-t
Hi,
Short of a reinstall, what do I do?Thanks,
BenIt's an HP TPN-C126
Is this on q4os TDE or KDE? Can you switch to a tty? Try pressing Ctrl + Alt + F2 that should take you to a console, log in with your credentials and remove the problematic pkg
sudo apt-get remove --purge lookswitcher
reboot
sudo systemctl reboot
and check whether or not the problem's gone.
Hope this helps!
