#1 2020-06-06 15:03
Update youtube-dl to Bullseye; Buster's doesn't work.
There's seem to be something wrong with youtube-dl's Buster version cause it kept giving me this error
youtube says: video not available
and tried to update but got this
youtube-dl: error: youtube-dl's self-update mechanism is disabled on Debian. Please update youtube-dl using apt(8). See https://packages.debian.org/sid/youtube-dl for the latest packaged version.
but apt kept telling me that the latest youtube-dl version was installed, so I downloaded the .deb for testing a.k.a Bullseye, installed it, fortunately it gave me no errors nor was any package replaced/updated and it didn't made any changes in sources.list file and now youtube-dl works as expected. Can you add/include youtube-dl Bullseye's version so Buster's get updated from that one?
#2 2020-07-13 21:53
robbertflord134
Re: Update youtube-dl to Bullseye; Buster's doesn't work.
I downloaded the .deb for testing a.k.a Bullseye, installed it my self, fortunately it gave me no errors, no bugs nor was any package replaced/updated and it didn't made any changes in sources.list file and now youtube-dl works as expected
#3 2020-08-03 10:23
PetarSerbia
Hello. I installed youtube-dl snap package and it work OK. Only one snap install and that is youtube-dl.
#4 2020-08-03 14:24
Ehh ... Why?? LOL
Yes, I'm aware there's a snap package available and that's reported to work but if possible I'll try to avoid snap and flatpack as well for as long as I can.
Using the one from testing/bullseye works.
#5 2020-08-08 15:31
YouTube changes break downloaders quite often -- e.g., recently in Windows and on a particular network that I use, even the latest version of youtube-dl is failing with https://www.youtube.com/watch?v=[videoID] type URLs  and only https://youtu.be/[videoID] type ones work...
#6 2021-04-05 02:41
4gAV2
you can get it from their github and auto update every week with -U
put it in your local bin
#7 2021-04-05 05:13
Add http://www.deb-multimedia.org to your repos.
