#1 2020-06-06 09:37
postquantum
Printscreen => Screenshot?
Hello,
How I can use the Print-Button on my keyboard to generate a screenshot of a selectable area right way?
Kind Regards
#2 2020-06-06 11:49
Re: Printscreen => Screenshot?
see this post
#3 2020-06-06 11:51
For a selectable area it's a bit interesting. I suggest you look at the KDE screenshot tools - depends on whether your using Plasma or Trinity. Please always mention this as it is important in getting help from others.
ksnapshot-trinity allows access to DCOP commands - the user manual for it has lots of options
scrot as I recall was always the tool of choice. ksnip is a Qt based cross platform tool that may also work.
Once you've worked out the commands you just need to assign that to the required key combo.
#4 2020-06-06 11:54
Sorry I didn't read "selectable area", @bins options would be the preferred method.
