#1 2020-05-19 22:22
NibblesMctwitch
Live ISO
Hello,
When i boot the live iso it goes to the command line, not the graphical environment have any ideas what I need to do?
Asus X570 MB
AMD Razen 7 3700x
32 gig of 3600hz ram
Need any more info let me know
#2 2020-05-19 23:27
Re: Live ISO
Your system is unlikely to be supported ootb with the Stable version, you could try the testing image (available from the downloads page) and see if you have better luck.
#3 2020-05-20 04:39
NibblesMctwitch
Re: Live ISO
Now that I think about it the weekend before last I tried to install it and the same thing happen the difference is the MB CPU and memory was intel I switched it out last Friday, the only thing the same is my GPU and my hard drives.
#4 2020-05-20 04:46
NibblesMctwitch
Re: Live ISO
Testing Version does not work either.
#5 2020-05-20 07:29
Re: Live ISO
What GPU do you have?
#6 2020-05-20 10:41
Re: Live ISO
You could also Ubuntu Quark testing give a try
https://www.q4os.org/forum/viewtopic.php?id=3028
https://sourceforge.net/projects/ubuntu … s/testing/
and post a result here.
#7 2020-05-20 14:51
NibblesMctwitch
Re: Live ISO
EVGA Geforce RTX 2070 Super
#8 2020-05-20 14:57
NibblesMctwitch
Re: Live ISO
I will give it a shot and report back.
#9 2020-05-20 15:25
NibblesMctwitch
Re: Live ISO
No does not work and by the characters, I see on the screen I'm guessing something to do with the GPU.
On the first one, I got to the boot screen and was able to pick a choice, on the 2 testing versions I just get garbage on the screen.
Also if you need any further help with this let me know I'm retired and have all kinds of time.
#10 2020-05-20 17:18
Re: Live ISO
Could it be that you need the Nvidia proprietary driver? I don't recall if it is actually installed in the live session, I would guess not as it would likely cause issues with other gpu set-ups by doing that.
You could try booting into recovery (or failsafe) mode and see if that works.
#11 2020-05-20 22:13
NibblesMctwitch
Re: Live ISO
Ok, I did that and it got to about 3/4 finished and I got an error "can not find a medium with a live file system" so to make sure I downloaded it again used a different USB stick and a different image writer.   At this point, I don't think this distro is in my future.
Chuck
#12 2020-05-21 07:38
Re: Live ISO
I think you might have issues with most (but not all) Linux (especially Debian based) OS's due to how new your hardware is, but you could try Mint or Ubuntu (some variants are better than others) they might get you further.
#13 2020-05-21 14:57
NibblesMctwitch
Re: Live ISO
Thanks for your help, I'm just a distro hopper I have 7 HD and 3 Distros on this machine I keep Manjaro as my dailiy runner.
#14 2020-05-21 15:38
Re: Live ISO
In that case as you already have the other os's running maybe you could run inxi -F from one of them and we could see which firmware/drivers are needed and I'm sure the devs would help to find out if it is possible to get your hardware running OOTB. Obviously other hardware spec packages are available and would likely give the required info, so the output from any of them should be sufficient.
#15 2020-05-21 20:08
NibblesMctwitch
Re: Live ISO
Here it is:
> inxi -F
System:    Host: manjaro-pc Kernel: 5.4.40-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.18.5 Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-E GAMING v: Rev X.0x serial: <root required>
           UEFI: American Megatrends v: 1408 date: 04/01/2020
CPU:       Topology: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP L2 cache: 4096 KiB
           Speed: 3727 MHz min/max: 2200/3700 MHz Core speeds (MHz): 1: 3700 2: 3688 3: 3707 4: 3695 5: 3672 6: 3692 7: 3693
           8: 3674 9: 3717 10: 3707 11: 3721 12: 3711 13: 3700 14: 3700 15: 3700 16: 3706
Graphics:  Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER] driver: nvidia v: 440.82
           Display: x11 server: X.Org 1.20.8 driver: nvidia resolution: 2560x1080~60Hz
           OpenGL: renderer: GeForce RTX 2070 SUPER/PCIe/SSE2 v: 4.6.0 NVIDIA 440.82
Audio:     Device-1: NVIDIA TU104 HD Audio driver: snd_hda_intel
           Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio driver: snd_hda_intel
           Sound Server: ALSA v: k5.4.40-1-MANJARO
Network:   Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi
           IF: wlp5s0 state: down mac: f2:b6:12:43:2a:89
           Device-2: Realtek RTL8125 2.5GbE driver: r8169
           IF: enp6s0 state: down mac: d4:5d:64:53:e9:95
           Device-3: Intel I211 Gigabit Network driver: igb
           IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: d4:5d:64:53:e9:96
Drives:    Local Storage: total: 11.83 TiB used: 92.55 GiB (0.8%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 960 EVO 250GB size: 232.89 GiB
           ID-2: /dev/nvme1n1 vendor: Seagate model: BarraCuda 510 SSD ZP250CM30001 size: 232.89 GiB
           ID-3: /dev/sda vendor: Seagate model: ST4000DM005-2DP166 size: 3.64 TiB
           ID-4: /dev/sdb vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
           ID-5: /dev/sdc vendor: Seagate model: ST4000DM005-2DP166 size: 3.64 TiB
           ID-6: /dev/sdd vendor: Seagate model: ST4000DM005-2DP166 size: 3.64 TiB
           ID-7: /dev/sde vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
Partition: ID-1: / size: 227.94 GiB used: 15.02 GiB (6.6%) fs: ext4 dev: /dev/nvme0n1p2
Sensors:   System Temperatures: cpu: 41.2 C mobo: N/A gpu: nvidia temp: 43 C
           Fan Speeds (RPM): N/A gpu: nvidia fan: 0%
Info:      Processes: 392 Uptime: 3h 34m Memory: 31.34 GiB used: 3.61 GiB (11.5%) Shell: fish inxi: 3.0.37
chuck@manjaro-pc /home/chuck  ❯❯❯❯❯❯❯
#16 2020-05-22 10:36
Re: Live ISO
The same video driver is in Buster-backports repository (add using "sudo qrepoadd --gui" and select buster backports) which is most likely the culprit, but I would guess you need to get the system installed before you could try it, maybe a cli install and then add the video driver?
#17 2020-05-22 10:51
Re: Live ISO
Dai_trying wrote:
... maybe a cli install and then add the video driver?
Yes, that should work, you need to use the "install-cd" Q4OS media https://www.q4os.org/downloads1.html
#18 2020-05-23 21:15
NibblesMctwitch
Re: Live ISO
I got it installed on a VM so now I will try your suggestion for the SSD.
#19 2020-05-25 05:30
NibblesMctwitch
Re: Live ISO
I have tried everything you guys have suggested and nothing, so I officially give up.
#20 2020-05-25 23:24
NibblesMctwitch
Re: Live ISO
Turns out the problem (Still unknown) happens on all Debian related distros not just yours.
