Hi ,how can I change screen resolution of asus eeepc 1015bx , i want test 1024×768 . i don't speak good english excuse me.
one way -
Assuming Q4OS
Right click on desktop
select "Configure Desktop..."
select "Display"
"Size & Orientation" tab
use "Screen Size" drop down to select from choices.
Thanks, but i can not select what i want. Although the screen resolution on the 1000 series is 1024x600, it has pixel mapping (memory addressing) which covers a virtual 1024x768 desktop, so is it possible via xrandr to do that?
Well, it looks like we have reach the limit of my knowledge!
I don't have a eeepc but there are others on here that do, so hopefully some of them can help you!
Large a Thank you for your implication
With Q4OS Scorpion, Trinity desktop, Bourbon menu:
Left click the following:
Menu button at bottom left of screen
Control panel, which takes you to settings
Peripherals
Display, which takes you to Size & Orientation tab
Choose the Screen size (resolution)
Apply, then OK
(Basically the same as JimW's directions, but the long way.)
