#1 2020-04-30 13:55
Elbarbudo
Install on EeePC 4G
Worked fine in minimal install ("disk" is only 4Go), so very few apps can be installed.
Just one small problem : I have a french keyboard. While in the desktop it's OK
But when I swirch to console (<Ctrl><Alt>F1) I fall back on a qwerty keyboard
I encountered this problem in old Linux distro but on these distro, the installation program set the console to the right keyboard.
Something like loadkeys fr is missing in the setup.
#2 2020-04-30 20:00
Re: Install on EeePC 4G
You could try the instructions in the Documentation for languages although I am lucky enough for default keyboards and settings are usually ok for me to get by and so I have never had to mess about with them.
