#1 2020-03-19 23:53
jeffneedle
[SOLVED] Need Wine32
Using latest Q4OS, fully updated.  After successfully installing Wine from the repos, I can't install an app.  Says I need wine32.  But wine32 isn't in the repos.  How can I get this?  Thanks.
#2 2020-03-20 08:11
Re: [SOLVED] Need Wine32
The most native way would be to install Wine layer from the Q4OS software centre.
Alternatively, you need to add "i386" architecture:
$ sudo dpkg --add-architecture i386
$ sudo apt update
$ sudo apt install wine32
#3 2020-03-20 21:51
jeffneedle
Bingo!  Worked perfectly.  Thanks!
#4 2020-03-20 22:46
Hey jeff, out of curiosity did you use the Q4OS software centre or the manual route? or both?
#5 2020-03-20 22:50
jeffneedle
Manual route.  Wine32 isn't in the default repos.
#6 2020-03-20 23:15
Ok, thanks. smile
