Hi everyone! Hope you're all having a nice life and a wonderful 2020!
I was using my computer, surfing the net and chromium suddenly close. I tried running it again but it started and crashed afterwards. Running chromium from a terminal gave some error regarding sandbox, I thought maybe logging out and logging in back might fix the problem but plasma didn't start so I changed to tty2 and ran
sudo systemctl reboot
and when booting got this error
Failed to isolate default target: unit sysinit.target not found. Freezing execution
System won't boot. Been googling for a solution to no avail. Can anyone tell me how to fix this, if possible, please? Runing Q4OS 3.10 Centaurus KDE. I'm writing this from a live USB while trying to figure this issue out.Thanks in advance for all your answers.
EDIT: I solved it ... kind of; had to reinstall the system cause was unabel to find a reliable solution. BTW, wanted to try Gemini but ran into a couple of issues with the installer, don't know whether or not this is a known bug and been already dealt with but just thought you might want to know. Here some screenshots
First, it complaint that it couldn't find package install-debian. I rebooted and tried again
In the second and last attempt, it complaint that it couldn't create partitions or something like that. I was trying to install to a USB device which Centaurus did without problem.
