#1 2020-02-17 00:27
MichelVn
problem with extension .desktop : Impossible to Install Tor
Hello,
I'm starting with Linux and I'd like to use your distribution.
I've a problem when I try to Install Tor.
I double click on the "Tor Browser Setup.desktop" and I receive the following error message :
"Le service « /home/user/Bureau/start-tor-browser.desktop » est mal formaté."         Yes, I speak french ;-)
After some researches on internet, I don't find any solution .
I use your 32bit distribution with TDE desktop.
Thanks to help me.
Michaël.
#2 2020-02-17 13:54
Re: problem with extension .desktop : Impossible to Install Tor
Where did you get the "Tor Browser Setup.desktop" shortcut ?
#3 2020-02-17 14:09
Tomsonas
MichelVn wrote:
Hello,
Thanks to help me.
Michaël.
Had the exact problem as I installed Tor yesterday.
You should move tor-browser_en-US (or it might be tor-browser_fr-FR if you downloaded the French version, so replace the folder's name I'm using with the one you have) to /opt
sudo mv tor-browser_en-US /opt
Then switch directory to /opt/tor-browser_en-US and run this:
cat start-tor-browser.desktop
Then you will need to copy everything under Exec that starts with sh and ends with dummy %k. Paste and run it in terminal. Now Tor should start and the .desktop file should be fixed as well, you may copy it to ~/.local/share/applications if you wish to see Tor on application menu with
 cp /opt/tor-browser_en-US/start-tor-browser.desktop ~/.local/share/applications
Again, if you have a different folder name, make sure you replace tor-browser_en-US with whatever name your Tor folder is called.
#4 2020-02-18 15:37
MichelVn
Thanks Tomsonas, thanks to you I can start Tor with the command under the Exec (sh ... %K) in a terminal, but not with the Tor shortcut (start-tor-browser.desktop).
Have you any idea for a solution ?
Michael
#5 2020-02-18 15:42
MichelVn
To complete my post :
I receive the following same message :
#6 2020-02-18 19:03
MichelVn
I found the solution:
On the desktop, right click, create a new one, Link to an application...
In the Application tab at the command line choose Browse
browse to "/opt/tor-browser_en/Browser", the choose "start-tor-browser"
Confirm with OK
And it runs
Have a good day.
M/
