I have noticed the following small problem in the 32 bit TDE version of Q4OS (3.10 r2). The file /etc/xdg/autostart/polkit-tde-authentication-agent-1.desktop contains the following line:
Exec=/usr/lib/x86_64-linux-gnu/libexec/polkit-tde-authentication-agent-1
which is trying to run the 64-bit version of the program. It should be:
Exec=/usr/lib/i386-linux-gnu/libexec/polkit-tde-authentication-agent-1
Yes, we can confirm the bug, it will be fixed as soon as possible. Thanks for reporting.
The issue is fixed, you only need to update your system:
$ sudo apt update
$ sudo apt dist-upgrade
Thanks - all fixed now!
