#1 2020-02-03 18:20
omegadx
Next problem with konqueror
Hi to all,
i made a restart with my laptop, after restart, i opened the konqueror. The startpage is still q4os, still from the installation. I like it.
but this time there stood the following message:
Beim Laden von http://q4os.org ist folgender Fehler aufgetreten:
Keine Verbindung zu Rechner q4os.org.
Why did konqueror get no connection to the q4os url?
I don't change anything. Every other url I can reach, but not q4os.
What is there going on?
Hope someone knows what there is going on, and what I must do,that it will work again.
#2 2020-02-03 18:24
Re: Next problem with konqueror
Works ok from here... (UK)
#3 2020-02-03 18:42
omegadx
yes, I noticed it after a restart and than, ne times open, again, the mistake, after a reload, it works, but the other problem with my konqueror I can't solve.
#4 2020-02-03 18:46
I don't use it for browsing so don't really know what to suggest, have you checked the tde website for bugs?
#5 2020-02-03 18:59
omegadx
HI,
yes I have done this already. I haven't found something, the problem is, it is working, but sometimes it makes this mystery message.
Also with the other problem that I can't log in. I let konqueror work for more than 10 min. Suddenly there came the message that konqueror gave the signal sigsevd. Hope I spell it right. Perhaps i missed something by the installation? is this possible? but java is installed, i made the normal user installation. nothing more. Till now I installed only three games, nothing more. Normally there is all what I need. I must only bring it to work. easy to say, but not so easy to do specially when you stand just at the beginning.
#6 2020-02-03 19:05
If you use 32bit Q4OS installation, you most likely came across known TDE bug https://bugs.trinitydesktop.org/show_bug.cgi?id=3024 . We can only recommend you to install and use another browser, for example Firefox.
#7 2020-02-03 19:42
omegadx
Yes I am using 32 bit Q4OS. So is no chance to connect with konqueror? sad
okay, thank you for your patience.
#8 2020-02-03 20:30
No, the 32bit Konqueror-trinity web browser is buggy. We recommend to use another browser for regular web-browsing. Konqueror-trinity is usable for quick lightweight internet access only.
#9 2020-02-03 20:36
omegadx
But firefox or chrome don't support java. Maybe we will find an other way for chat. I don't want to go back to win10 anymore, it is to big, it is working on my laptop, but it needs to much space on my hd. And slowly but shurely it is getting slower and slower, don't know why. From start till open the first app, i can smoke a cigarette, or cook a pot of coffee. thats no computer after one year daily use.
#10 2020-02-03 20:46
omegadx
how can I close the threat?
#11 2020-02-03 21:02
would an alternative chat method be an option?
#12 2020-02-10 12:48
omegadx
No, because my friends are using the chat on the pc of their office, there they can't installe a spezial program. we must use than a chat url. Most time we are chatting during the nightshift. There is no other option. Bad luck.
