Hi,
I have tried to install Q4OS 3.10 Centaurus on a couple of Lenovo x120e computers. On the most recent attempt, I was installing over an earlier Q4OS that was running Stretch. Even so, whenever I attempt, I get the error
Boost.Python error in job "bootloader".
Command 'grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=Q4OS --force' returned non-zero exit status 1.
Installing for x86_64-efi platform. grub-install: warning: Cannot set EFI variable Boot000A. grub-install: warning: efivarfs_set_variable: writing to fd 7 failed: No space left on device. grub-install: warning: _efi_set_variable_mode: ops->set_variable() failed: No space left on device. grub-install: error: failed to register the EFI boot entry: No space left on device.
Traceback:
File "/usr/lib/x86_64-linux-gnu/calamares/modules/bootloader/main.py", line 444, in run
prepare_bootloader(fw_type)
File "/usr/lib/x86_64-linux-gnu/calamares/modules/bootloader/main.py", line 411, in prepare_bootloader
install_grub(efi_directory, fw_type)
File "/usr/lib/x86_64-linux-gnu/calamares/modules/bootloader/main.py", line 285, in install_grub
"--force"])
File "<string>", line 8, in <module>
My guess is this error is not Q4OS specific but a Calamares error. Still, it is a nuisance. Does anyone know how to get around this?
Thanks
Kendew
No space left in the EFI partition. How did you command Calamares to partition the disk drive at the partitioning step ?
Thanks for the reply.
I proceeded through the graphical Calamares interface. As Q4OS was already installed, I didn't really do anything with partitions. Since I wasn't interested in keeping the previous Q4OS installation, I selected to erase disc and install only Centaurus 3.10. Calamares proposed the new partition setup viewed alongside with the old. And I selected to proceed. There was no error at this point. The installation seemed to be going well until after twenty minutes or so the error message (shown above) appeared.
I also tried this on a different Lenovo x120e laptop on which CentOS was installed. This time I set flags and mount points, but still the same error. It's a mystery to me.
The problem is probably in the NVRAM. Deleting some dump files or useless boot entries with efibootmgr should allow to add a new entry for GRUB. Please see the first reply from https://unix.stackexchange.com/question … ion-failed
