#1 2019-12-28 19:12
notlurking
TDE crash
Hello I like very much the TDE desktop but have been running to a problem with some crashes. They happen when I try to use the panel adjustment. I specifically wanted to put the panel on back on top after mysterioulsy going down. When I try to do that the panel adjustment does not open properly and before I can click on the selections it crashes and then it freezes. I have submitted a few crash reports already. Thanks
#2 2019-12-31 05:59
Re: TDE crash
There are a whole number of possible causes. TBH the quickest solution would probably be to re-set the desktop config to default.
Go to http://www.q4os.org/dqa011.html and look at 4.7.
If you decide to copy and paste that command please remove the $ and space at the start.
