This is odd.
Installing 3.9 TDE from q4os-3.9-x64-tde.r1.iso
My drive is set up as sda1 /
sda2 extended with:-
sda5 swap
sda6 /home
This arrangement I have used for years and with Q4OS since the days of 1.8
Going through installer, Select Replace Partition, pick current OS partition and then check 'Re-use sda6 for /home
Installer scans partitions and then crashes with segfault
Dec 30 14:27:27 localhost kernel: [ 302.681914] EXT4-fs (sda1): mounted filesystem without journal. Opts: noload
Dec 30 14:28:20 localhost kernel: [ 356.003473] sda: sda1 sda2 < sda5 sda6 >
Dec 30 14:28:21 localhost kernel: [ 356.614485] sda: sda1 sda2 < sda5 sda6 >
Dec 30 14:28:21 localhost kernel: [ 357.082949] calamares[4241]: segfault at 7f001c0001b0 ip 00007f001c0001b0 sp 00007ffe185b6bf8 error 15
Dec 30 14:28:21 localhost kernel: [ 357.082956] Code: 00 00 70 01 00 1c 00 7f 00 00 a0 88 06 1c 00 7f 00 00 a0 88 06 1c 00 7f 00 00 90 01 00 1c 00 7f 00 00 90 01 00 1c 00 7f 00 00 <a0> 01 00 1c 00 7f 00 00 a0 01 00 1c 00 7f 00 00 b0 01 00 1c 00 7f
I will try with the 3.8 installer which I know worked in the past.
UPDATE:- Curious - checked MD5 on original dl and all ok - reburned 3.9 - same problem.
DL again same md5 - burned iso and this time it doesn't crash - as they say, go figure.
