#1 2019-12-19 05:00
Adam33
Task button and scrollbar width
I recently got a 27-inch UHD ("4K") monitor, and my experience so far has been good, but I have noticed a couple of things I wanted to ask about.
First, can I customize the width or spacing of the task buttons on the bottom of the screen? Scaling seems to have both crammed them together and reduced their proportional width.
Second, can I increase the width of the scrollbars? When opening browsers and windows, these seem to not be included in the scaling.
As much as I love the sharp text, some things just seem a bit awkward, perhaps because this is my first time to use anything other than an old fashioned 4:5 monitor. I must admit though that having tested it more than a few hours, I'm surprised how well scaling has worked so far. It wasn't something I would have expected with Trinity Desktop.
#2 2019-12-20 21:04
Re: Task button and scrollbar width
You could try to edit the config files:
"/home/<$USER>/.trinity/share/config/taskbar_panelapplet_rc"
"/home/<$USER>/.trinity/share/config/ktaskbarrc"
section "General" , key "MinimumButtonWidth"
Scrollbars are not included in the scaling at the moment, so the answer is no unfortunately.
#3 2020-01-10 06:13
Adam33
Thanks for the tip, but that did not work in my case. ktaskbarrc did not contain that setting, though I did try adding it consistent with taskbar_panelapplet_rc using a higher value. In addition, the other settings in the latter under General were not ones in use. They referenced fonts and sizes that I'm not using and do not see. I suspect this would be a different file or setting.
