#1 2019-12-05 01:31
jpb
Can Q4OS run Lightworks
I just read about Q4OS, thinking about leaving Ubuntustudio. I do Video editing and would like to know if there is anyone running Lightworks on this distro and is there any issuses . lwks.com
Thanks
J
#2 2019-12-05 09:31
Re: Can Q4OS run Lightworks
I haven't tried it but I see no reason that it would not work, try downloading the DEB file and you can install it using apt with the following command which will also install any dependencies.
sudo apt install ./lightworks.deb
Just replace lightworks.deb with the actual filename of the downloaded deb file, and don't forget the ./ before the filename as this will tell apt to install from a file and not from a repository.
#3 2020-01-06 01:06
jpb
Sorry for being so slow.
I'll have some time shortly to try it out on a laptop.
As long as lightwork, darktable work I'll be quite happy. I am getting tired of Ubuntu
