Hi
Did some support this am with AnyDesk
Notice its now loaded at start up of Trinity?
How do I disable that?
Thanks
You could try Control Centre -> TDE Components -> Service Manager some components are autoloaded there, also you could check if you are starting with a fresh session as the previous one may be auto launching some packages, starting with a fresh session always can be set in Control Centre -> TDE Components -> Session Manager in the on login section check "start with an empty session", also you could check if there is a .desktop file in /opt/trinity/share/autostart/ for anydesk.
I would imagine there are other ways it can be set to launch automatically but these are the ones I would check first.
Please check possible startup locations:
/etc/xdg/autostart/
/opt/trinity/etc/xdg/autostart/
$HOME/.trinity/Autostart/
$HOME/.config/autostart/
$HOME/.configtde/autostart/
Tried all those can't see any reference to anydesk
Did you check if you are starting a fresh session at bootup?
Yup
You could look in /etc/rc?.d/ directories (rc0.d, rc1.d etc) to see if there is something there.
$ sudo systemctl disable anydesk.service
That sorted it!
Thanks
