#1 2019-10-11 00:23
Bdar85
Help required installation issues on Vista machine Q4OS for newbie
Hi, I am new to Linux and Q4OS. I have been trying to install on an old windows Vista machine. I have managed to create a bootable USB from the Iso file and changed bios to boot from there. I get as far as the screen where you select the installation option. I can get no further. None of the keys work and the computer just hangs at that screen. What do I need to do, can anyone help? Sorry if I have posted in the wrong place.
Thanks, Brian
#2 2019-10-11 11:25
Re: Help required installation issues on Vista machine Q4OS for newbie
What installation iso do you try to boot ? Please specify the full name of the .iso file.
#3 2019-10-11 16:03
Bdar85
Hi I used the following link Q4OS Centaurus, Trinity, install-cd - 32bit / i386. My vista machine is a core duo 1.5ghz with 2 gig RAM. Hope it helps
