#1 2019-08-13 16:25
Arran13
Hello
How can I install Amarok?. I need this program to receive internet music from streams. When I try it on the console, the response is that there is no such «Installationskandidat» (candiade to be installed?)
#2 2019-08-13 16:58
cjoliprsf
Re: Hello
sudo apt install amarok
works on my system, Q4OS 2.7, 64 bits.
#3 2019-08-13 17:19
Re: Hello
You could also use Synaptic package manager and install Amarok as well.
#4 2019-08-13 22:57
Re: Hello
It's not currently available for Buster (Centaurus), you could try and backport it from Debian Sid following the Debian instructions.
#5 2019-08-13 23:02
Re: Hello
Amarok-trinity is available for Debian 10 in the repos when I checked before posting thru Synaptic.
Clementine is also available.
#6 2019-08-13 23:13
Re: Hello
Yes, sorry I was in Debian at the time and didn't think about the -trinity versions, so that would answer the OP's question,
sudo apt install amarok-trinity
#7 2019-08-13 23:18
Re: Hello
Im running the KDE version so I dont use them either.  I dont run the Trinity version.
