I decided to use Q4OS Scorpion for now, because Centaurus has some problems, which I really don't like, and Scorpion works better on my hardware.
Unfortunatelly, I have found some problems in Q4OS Scorpion. Not so important as in Centaurus (KMix), but still need to be solved.
1. I have installed LibreOffice 6 using Q4OS Software Centre. On my notebook it was slow and sluggish, so I decided to remove it using Q4OS Software Centre.
https://drive.google.com/file/d/1Q86Jd0 … sp=sharing
https://drive.google.com/file/d/1Uxp47O … sp=sharing
But, even after removal I have found some of its components installed, and I was able to launch Libre Office writer.
https://drive.google.com/file/d/1AV7SzN … sp=sharing
https://drive.google.com/file/d/1NjPj-V … sp=sharing
Also, In Synaptic package manager, there were some packages remained installed.
https://drive.google.com/file/d/15ElbuO … sp=sharing
So the problem is - Q4OS Software centre does not remove Libre Office completely.
2. When I try to Browse folder in Gwenview-trinity after opening file, it returns Error.
Video: https://drive.google.com/file/d/1ymxqsB … sp=sharing
3. When I try to print scanned image in Kooka-trinity, It generates many pages, then just hangs. So I am unable to print using Kooka-trinity.
Video: https://drive.google.com/file/d/12Wr9H1 … sp=sharing
I can print successfuly using OpenOffice, Chromium and other utilities, so my printer works well. The problem is only with kooka-trinity.
https://drive.google.com/file/d/11lHHqK … sp=sharing
4. I have uninstalled geeqie, but I still have its entry in Start Menu.
https://drive.google.com/file/d/1fqjfXL … sp=sharing
5. Expanding dialog window does not working properly.
Video: https://drive.google.com/file/d/1okDxgp … sp=sharing
Thanks for the detailed report, we will check all the mentioned a post a feedback later.
Dear q4osteam!
A month passed, but still no answer.
We will reply in a few days, please be patient. Anyway, thanks for the detailed helpful reports, could we use your screenshots and videos for a bug reporting at the Trinity developers ?
Of course you can use them.
We can confirm all mentioned issues in Q4OS except 4., they are reproducible.
1. Q4OS bug, now fixed.
2. Trinity bug - we will report it
3. Trinity bug - we will report it
4. Looks like a Q4OS glitch, it will be investigated
5. Trinity bug - we will report it
