#1 2019-08-09 04:32
nobody9999
Manually saved session
Hello,
where is the data of a manual saved user session stored? I did a mistake changing the screen resolution to a very tiny one.
#2 2019-08-09 07:56
Re: Manually saved session
I don't use saved sessions, but couldn't you load the session make adjustments and then save the session again?
#3 2019-08-09 12:15
nobody9999
unfortunately not because the resolution is so small that I can not select anything
#4 2019-08-09 12:20
Which tool did you change resolution with ?
#5 2019-08-09 12:47
nobody9999
I can not remember, it went too fast.
Can i delete the saved session?
#6 2019-08-09 12:50
This might be a silly question, but how do you manually save a session?
#7 2019-08-09 12:54
You could try to edit the "/etc/q4os/q4base.conf" file, delete the "force_screen_dpi" line and reboot.
#8 2019-08-09 21:38
nobody9999
Unfortunately that did not solve my problem.  the desktop is still very small.  where is this stored?
