I have several q4os Systems running and on one of them I can start Windows exe files without using Wine explicitely. I can start an exe from the bash command prompt by ./Blackbox.exe although double clicking the exe in Konqueror does not work. As far as I remember, I did not configure anything special, it worked out of the box after using the setup_xpq4*.esh script, but on the other systems I have to use wine to start the program.
Any ideas why and what steps are necessary that a system recognizes PE32 file as executables (beside setting the executable bit) and uses wine automagically as program loader?
The answer is found in the second answer by daisy in https://unix.stackexchange.com/question … e-programs which refers to the binfmt filesystem (I had never heard of it before, but it looks very interesting). The respective Debian package has the name wine-binfmt and after installing this package, the first of the other two systems works also.
There is a tutorial about binfmt here: https://web.archive.org/web/20220303035 … nfmt_misc/ and some hints at: https://www.linux.com/news/how-launch-w … x-directly. Apparently the kernel documentation binfmt_misc.txt can now only be found only at https://lwn.net/Articles/679310/, a html version is at https://www.kernel.org/doc/html/latest/ … -misc.html.
In the end, I think that on the system where it worked, I had done an 'apt search wine' and installed by chance also the wine-binfmt package not exactly knowing what it really does nor completely understanding what I was doing ...
