#1 2015-12-21 15:43
File permissions
I have changed file permissions using command sudo chmod 400 unrar_man.txt
In Linux Mint after such manipulation I could not delete file or move it to recycle bin. I often used this to protect important files from accidental deletion.
I assume that permission Read should allow only to read contents of file but not write, modify, delete or change its contents another way. Does Konqueror behaves differently?
#2 2015-12-21 17:52
Re: File permissions
Yes, konqueror file manager behaves differently, it will remove such file the same way as 'rm' command. Write access is disabled. The default remove action is to move the file to trash bin.
#3 2016-01-28 09:58
bobby
While converting  a bash script using shc  the output files *.x.c & *.x are both set to root:root  in $HOME/Documents/folder
I can change owner in terminal to bobby:bobby but, TDE still says its root:root and will not execute the binary *.sh.x until I rebooted.
?? Is this normal where permissions are not updated in TDE until reboot (or new session ?)
Thanks,
Bobby
No Longer Using Q4OS
#4 2016-01-28 10:20
bobby
I have also seen this below error when running shell scripts & binary executable files using  shortcuts I create on Q4OS Desktop.
Only in i386 and NOT x64 Q4OS.
TQSettings:: sync: failed to open '/etc/tqt3/tqt_plugins_3.5rc.tmp' for writing
shows up 4 times in each time I see it in Terminal
#5 2016-01-28 10:42
Reproduced, it's Trinity bug. Konqueror file manager caches file's properties and they are not updated even on 'refresh' F5 key action. You can report it https://bugs.trinitydesktop.org
Yes, this is very probably Trinity minor bug, that is known. We have investigated it in the past with conclusion, that you can safely ignore it, as this is just a message when TDE searches config files to use. This is surely not related to the glitch you reported above.
#6 2016-01-28 21:57
bobby
@Q4OS Team,  Thank you for quick reply.  I will report @ Trinity Desktop bug report.
#7 2016-01-29 00:09
bobby
Thanks,
Bobby
Its been a rough 2 days roll
I was creating my own problems by doing this:
sudo shc -f file.sh
When I should of been doing this !
shc -f file.sh
The use of sudo in creating directories and files resulted with them being owned by root.
Oh My as I feel so roll but, it did come to me that it was sudo (Dang Sudo) smile
