#1 2019-04-28 10:00
Centaurus 3.6 TDE R2 - GTK apps broken by config tools
After installation I added T/bird and Firefox - which both ran as expected
Although I do not normally use it anymore I decided to install the Control Centre utility for configuring GTK applications to check how a GTK theme would behave.
That theme was not installed at this time.
I installed:-
robin@flopsy:~$
Start-Date: 2019-04-28  06:54:05
Commandline: /usr/sbin/synaptic
Requested-By: robin (1000)
Install: gtk-qt-engine-trinity:amd64 (4:14.0.6-0debian10.0.0+0~a), kgtk-qt3-trin
ity:amd64 (4:14.0.6-0debian10.0.0+0~a), gtk3-tqt-engine-trinity:amd64 (4:14.0.6-
0debian10.0.0+0~a, automatic)
End-Date: 2019-04-28  06:54:08
Following reboot neither Firefox nor Thunderbird would run
(thunderbird:947): Gtk-ERROR **: 09:43:41.324: GTK+ 2.x symbols detected. Using GTK+ 2.x and GTK+ 3 in the same process is not supported
ExceptionHandler::GenerateDump cloned child 969
ExceptionHandler::SendContinueSignalToChild sent continue signal to child
ExceptionHandler::WaitForContinueSignal waiting for continue signal...
Trace/breakpoint trap
robin@flopsy:~$ firefox
(firefox-esr:1025): Gtk-ERROR **: 09:46:15.111: GTK+ 2.x symbols detected. Using GTK+ 2.x and GTK+ 3 in the same process is not supported
ExceptionHandler::GenerateDump cloned child 1031
robin@flopsy:~$
(crashreporter:1034): Gtk-ERROR **: 09:46:15.230: GTK+ 2.x symbols detected. Using GTK+ 2.x and GTK+ 3 in the same process is not supported
Removing the installed packages resolved the problem. I have not installed this utility on any version of Centaurus before so I do not know if this is a new bug or a recent arrival.
#2 2019-04-29 10:25
Re: Centaurus 3.6 TDE R2 - GTK apps broken by config tools
We can confirm the issue, it's reproducible on Q4OS Scorpion as well as Centaurus, we are going to investigate that. A feedback will be posted here as soon as a new information will be available.
#3 2019-04-30 13:26
It is reproducible on a plain Debian/Trinity stable system as well, so considered as a Trinity bug. The culprit is the "kgtk-qt3-trinity" package, it's the one that causes crashes of some GTK3 applications. We will pass that at the Trinity bug tracker. Thanks for reporting.
#4 2019-04-30 15:11
Thanks very much for the update.
#5 2019-04-30 21:29
